Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
I HAVE THIS MODEL 139.536 i GET THE 5 FLASHES AND THE DOOR IS STUCK IN THE OPEN POSITION NOW. wE HAVE IN THE PAST HAD PROBLEMS WITH THE DOOR JUST OPENING ON ITS OWN AS WELL. ANY THOUGHTS?
    President:
  • 3,197 Answers
The trolley may be jammed against the bolt just in front of the motor unit. If so remove the bolt and then run the opener until the door is closed. Now locate the 'up limit' control on the side of the motor unit and turn this control 2 full turns in the opposite direction of the arrow printed on the cover. Remember to replace the bolt.
Posted on Dec 14, 2009
Passenger door is stuck in lock position
Now I understand!
While not with a Maserati, in the past when this has happened to me, I was able to simply trip the latch and close the door.
Better targeted video:
Jan 09, 2015 | 2005 Maserati Quattroporte
Dx a lidlatch lock problem
The door latch is stuck in closed position. Unit lug the unit and it should reset itself. You will have to replace the door latch.
Jan 07, 2015 | Kenmore Washing Machines
The door is going down within about two inches of the floor and then goes back up. It has been doing this occasionally for the past few weeks, but now it will not stay down. The light flashes 10 times each...
Anytime the light flashes 10 times when the door reverses to the open position it is a door sensor problem. Make sure the small light on each sensor is lit and not flickering. Tweak them a little. If you cannot get both lights to come on you have bad sensors.
Sep 16, 2011 | Sears Craftsman LiftMaster Chamberlain...
I have a craftsman 1/2hp that stopped working. There is a small green light on the back of the opener that flashes five times and then stops for a second and then repeats the flashing. It may be model...
You don't say but I am going to assume the door is stuck in the open position. Loosen the chain enough to relieve the tension on the trolley. Now run the opener until the door closes. While the door is closed locate the 'up limit' control on the side of the motor unit. Turn this control 2 full turns in the opposite direction of the arrow printed on the cover. Tighten the chain.
Jun 03, 2011 | Sears Craftsman LiftMaster Chamberlain...
I have a Sears Garage door opener (139.53800SRT)was working and then just quit working. None of the remotes or wall switch work. When I press a switch I hear a few click in the opener and then nothing. ...
The code for 5 flashes is " Motor overheated or possible RPM sensor failure. Unplug to reset." Also if the door is stuck in the open position it could be the trolley is jammed against the bolt just in front of the motor unit.
Feb 07, 2010 | Sears Craftsman LiftMaster Chamberlain...
With the door disconnected, the chain moves about a foot then stops, the light flashes, and the chain moves back to its starting position.
If the main light flashes 10 times when the door reverses to the open position it is a door sensor problem. Make sure they are pointed at one another and the small light on each is lit and not flickering. If tweaking them a bit doesn't correct the situation you could have a bad sensor.
Oct 07, 2009 | Sears Craftsman LiftMaster Chamberlain...
Motor humms but door doesn't go up or down!
5 flashes is the code for "RPM sensor board or motor overload." If your door is stuck in the open position the trolley may be jammed against a bolt just in front of the motor unit. Remove the bolt and run the opener until the door is closed. Now locate the 'up limit' control on the side of the motor unit and turn it a couple turns in the opposite direction of the arrow printed on the cover. Be sure to replace the bolt.
Sep 28, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman garage door opener will not work. model # 139.53648SRT2
The code it is sending by flashing 5 times is 'RPM sensor or motor overload'. Is the door stuck in the open position?
Jul 08, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman 1/2HP Door Opener won't stay closed
Loosen the chain and run the opener until the sprocket runs in the counter clockwise direction and stops. Now with the door in the open position replace the chain. This will get everything back into sync but I hope you remembered where all those controls were. You need to put them back in their original positions.
Jun 06, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
489 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
