Question about Microsoft Windows XP Home Edition
Cd burning itunes begins burning cd gets to ''writing'' then states ''the attempt to burn disk failed. An unknown error occurred (4300}
    Novelist:
  • 137 Answers
Usually when you get a 4300 error when you are writing to a disk it means one of two things.
1. The communication from the motherboard to the cd-rom is bad. Meaning a bad or loose cable connected to the cd-rom drive.
or
2. You have another cd-rom drive installed or another IDE device installed in your PC and they are both set up on Master or Slave and the operating system is having an issue sending the data to the right device.
If neither of these are YOUR issue, then I would take the CD-ROM drive out and check it on a friends/family member's pc to make sure it's not the drive itself.
Posted on Dec 18, 2009
I have an Acer Extensa 4620Z and I am trying to burn a cd from itunes and am having much difficulty doing so. When I click to burn, it begins to start for about 1 second and then stops with the message:...
The problem with iTunes is that it uses its own/modifies the disc drive driver. What you can try is uninstall iTunes and performing what is called the Upper/Lower Filter Fix. This involves hitting "Start" and then selecting "Run" from the start menu. If that isn't in the Start menu, you can hold the Windows Key and hit 'R'. When the Run dialog box opens, type "regedit" in the box and click "OK" or "Run". This will open the Registry Editor window. Expand HKEY_LOCAL_MACHINE, then SYSTEM, then CurrentControlSet, then Control, then Class. This should reveal a bunch of items with seemingly random characters in their name. Select the top most and arrow down until the item at the top in the right-side column says DVD/CD-ROM Drives. Below that, you should see two potential keys, LowerFilters and UpperFilters. Right-click on these and select Delete. Then, restart, and reinstall iTunes. It should correct the issue.
Aug 27, 2011 | Acer Extensa 4620 Notebook
While trying to burn a cd i get error message 4450 ?
Try testing the CD first. There are reports that this error will occur but still produce a functional CD. Next try reducing the write speed, this will fix the problem in some cases. Next try burning with CD with a different program like Nero. iTunes appears to be a problematic application for this error. It is possible that the CD burner is near the end of it's life.
Feb 28, 2011 | Acer Aspire One Netbook 8.9" Notebook
My cd burner was working two weeks earlier, but now it merely starts the burning process before delivering the following message: ''The attempt to burn a disc failed. Unknown error occurred (4000).'' How...
Is either the problem comes from your CD writer Lense that might be so weak to burn in which we call for a replace or probably your CD that you want to write on is bad . so you have to test another CD that is working fine on the writer first and if that persist you will only change the CD writer is weak for writing on CD
Mar 11, 2010 | Computers & Internet
Error message when trying to burn a disc in i Tunes
The problem is with your optical unit, (TSST****), it must be firmware-updated, which version of iTunes do you have?
Dec 09, 2017 | Apple iTunes
I get unknown error code 4260 when trying to burn cd
This is a disk error issue make sure if on windows you have the drivers for your CD drive(start>right click computer>click device manager) and also try an different make of blank disk.
TDK maxel and sony disks are notoriously bad on burning..
verbatin and imation disks burn without this error, stick to CD-R or CD+R disks the re-writables are notrious for not writing properly
this may solve your problem hope it helps
Oct 03, 2009 | Microsoft Windows XP Home Edition
Unknown Error 4900 on i Tunes and Windows Vista
I accidently lock the ipod and i forget how to unlock
Jul 29, 2008 | Apple iPod nano
Burning to cd
According to hp help and support
When using iTunes for Windows you may get a disc failed error. An unknown error occurred (4280)
In this situation, if you attempt to burn a disc, the following error message may display: The attempt to burn a disc failed. An unknown error occurred (4280) You can resolve this error message by modifying a file in the iTunes CD Configuration folder. First, you need to verify the model of optical drive present. Verifying the Model of the CDRW/DVD Drive Verify that your PC has a Sony CD-RW/DVD CRX830E optical drive installed:
  1. Open iTunes.
  2. In the iTunes Help menu, click Run CD Diagnostics .
  3. Insert an audio CD in the optical drive.
  4. Click OK .
  5. View the results in the CD Diagnostics window:
    • If IDE/CdRomSONY_CDRW/DVD_CRX830E is listed, proceed with the procedure below to resolve the error message.
    • If another drive name is listed, this document does not apply to your computer.
Resolving the Error Message When an IDE/CdRomSONY_CDRW/DVD_CRX830E model optical drive is present, do the following steps to resolve the error message: CAUTION: Take care in using the following steps.
  1. Close iTunes and any other files and software that are open.
  2. Click Start , My Computer , Drive C: , Program Files , iTunes , and CD Configuration to view the files in the CD Configuration folder.
  3. Locate the file gcdrtype.cfg in the CD Configuration folder.
  4. Right-click the file gcdrtype.cfg .
  5. In the drop-down menu, click Open (you may need to select Notepad ) to edit the file gcdrtype.cfg in Notepad .
  6. In the Notepad window, scroll to the bottom lines of the file gcdrtype.cfg .
  7. Locate the line that reads: DRVGENERALFLAGS = MODESEL_NOPAGE01 | MODESEL_NOPAGE05
  8. At the end of this line add " | NOSENDOPC " (the first character is a blank space), so the line then reads: DRVGENERALFLAGS = MODESEL_NOPAGE01 | MODESEL_NOPAGE05 | NOSENDOPC
  9. At the top of the Notepad window, click File , Save .
  10. At the top of the Notepad window, click File , Exit to close the window.
  11. At the top of the CD Configuration window, click File , Close to close the window
  12. Restart the computer.
You should now be able to burn an audio CD without displaying this error message. ---------------------------------------------------------------------------------------------If this answers your question please rate this as fixed.
Thanks for using fixya support..You have a wonderful day
Jun 03, 2008 | Samsung SH-S182 DVD±RW Dual Layer Burner
Microsoft Windows XP Home Edition Logo
1,252 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
