Question about Moen & Posi-Temp Single Handle Shower Or Tub Valve
My Mo's shower is about 6 years old. I think the
My Mom's shower is about 6 years old. I think the handle is a Moen T 2111 and when I turn it to hot there is NO water. Plenty of cold water. She's 84 & handicap so not into cold showers, any help out there?
  • 744 Answers
Sure - there is always help at FixYa!
This sounds like a bad cartridge. They can be replaced. To replace the cartridge:
Turn off the water to the tub/shower.
Remove the handle cover (it should pop off)
Remove the center screw (usually phillips head)
Remove the retaining clip holding cartridge in - you can use a pair of long nose piers or a small screwdriver
Grab the cartridge with a pair of pliers and pull straight out. It may require a little force - there are O-rings around the cartridge to keep it from leaking.
Check the cartridge bore (the hole where the cartridge was removed)
Clean any debris or scale - lime away or CLR will work
Apply a little bit of soap around the new cartridge to help it slide in easier. Push it all the way in and make sure it is seated. Re-install the clip (you should have received a new clip with the replacement cartridge)
Turn the water back on a check for leaks
If OK, reinstall the knob screw, and cap.
Let Mom take her warm shower...:)
Posted on Dec 13, 2009
Testimonial: "Thank you very much. I will try my Nursing expertise at fixing this plumbing problem, darn economy I wish I could afford to hire a plumber. Thanks. "
    Problem Solver:
  • 7 Answers
The best tip to use in pulling out a calcified cartridge on a Moen Shower center Hot/Cold adjust, is to put the crew back in all the way and use that to put your teeth end of your Lineman, needle nose or any tool you can use to bit down on the inside of the screw head to give you the leverage to pull it straight out.
*2nd tip is instead of replacing cartridges over & over because of hard water deposits or paying a Plumber an ungodly fee, purchase silicon liquid lubricant and run it through the very hard to turn cartridge. Continue turning and adding silicon liquid drops until the cartridge is loosened up.
Reinstall after lubing the outer rubber seals, which you should clean & push the cartridge into the Shower head.
Replace Handle and check how easy it turns, saving you $100's.
**Perform this procedure every time you notice the turn becoming harder & the cartridge will last a good long time.
Posted on Feb 27, 2016
    Scholar:
  • 52 Answers
Turn off the water and remove the cartridge from the valve. You will have to remove the cap, knob, screw and cartridge clip. Pull the cartridge out (carefully) and inspect it for loose parts, plugging, or if the spool valve is blocking the hot water port. If it is, it's defective and will need to be replaced. You should be able to get a replacement at most home improvement stores
SOURCE:
Moen water flow restricted and only warm
Not sure about your particular valve, but most newer shower valves have an anti-scald limiter that stops the handle from turning too far to the hot water side. Check for a ring or a pin under the handle that can be set in different positions. It will need to be moved clockwise to allow the handle to rotate farther to hot.
Hope that helps. If you have trouble finding it, try looking up a diagram for the valve model.
Jul 03, 2017 | Moen & Replacement Cartridge
Moen Kingsley Moentrol single handle bath/shower fixture. Had guests use this recently and they only could get hot water. When you turned the handle to cold nothing comes out. Only hot when turned the...
Sounds like the cause of your problem is the pressure balancing spool. Call Moen at
1-800-289-6636
and explain the problem. They will send a repair part to you free of charge. the link below is a "blow up" of your valve.
http://www.moen.com/shared/pdf/t3113pt.pdf
Mar 10, 2011 | Moen & One Handle Tub & Shower Faucet
Is the moen posi temp shower handle a warranty part? if not whats the price?
It may be but it would depend on how and why it broke. If the unit is less then a year old Moen is always pretty good about replacing parts.
I can't give you a ferm amount on replacement not knowing witch handle you have but they range from $6 to $150 depending on the handle and the finish. The link below will give you good idea.
http://www.moen.com/replacement-parts
Mar 03, 2011 | Moen Posi-Temp Single HandleTub And Shower...
I've been given an old (10+ yrs) Moen shower control valve that I want to use (it does apparently have pressure balancing built-in), but don't know which side is hot and which is cold. Does Moen always...
Moen and all shower valve manufacturers follow american federal guidelines. Hold the unit in your hand with the handle facing you - the left side is the hot water inlet and the right side is the cold water inlet.
Nov 25, 2010 | Moen & Posi-Temp Single Handle Shower Or...
Moen L3175 faucet with low water pressure
IS THIS A SHOWER ONLY? IF SO ,I WOULD REMOVE THE SHOWER HEAD FIRST THEN TURN YOUR WATER ON.THE HEAD JUST MIGHT NEED TO BE CLEANED AFTER 11 YEARS.
May 10, 2010 | Moen L3175 Chrome Legend Single Handle...
Moen Single Handle Shower Faucet-turn on get cold, little hot
You can try to rotate the first plastic ring to the left of center a few teeth, this will let the handle advance alittle more to the hot side.
Oct 09, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Moen shower/tub faucet
hi... yes that's a very common issue with moen "cartridges" -- it's very simple to fix..... grasp the handle and give it a gentle tug upwards when the water is on... if it retracts again, pull the handle out again and tug again but this time a bit harder. Not sure what causes this on new cartridges but it will fix your issue.
Apr 27, 2009 | Moen & One Handle Tub & Shower Faucet
Replaced a moen cartidge and now the water is not hot in shower
make sure when you turn on the hot and cold shut off valves all the way and turn the moen on after that. Some times I would get that problem if I turned one(either hot or cold) off then tried the shower.
Feb 23, 2009 | Moen & Posi-Temp Single Handle Shower Or...
Single handle moen shower not turning far enough
it is your shower cartrige. ace hardware $45. hot always goes first. just check if it is a posi-temp or moan trol
Dec 17, 2008 | Moen 3175 Legend One Handle Shower Faucet...
Moen & Posi-Temp Single Handle Shower Or Tub Valve  Logo
710 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
