My element 19 inch flx-1910 tv will not power up
All of a sudden my lcd tv will not power up there is power at the plug
  • 8 more comments
  • Anonymous Aug 16, 2008
    same prpoblem
  • Anonymous Nov 16, 2008
    just started happening here
  • v_dub_89 Nov 16, 2008
    same
  • Anonymous Dec 18, 2008
    I can´t find fix the problem, somebody could help me????
    I had the same problem, sent it back for warranty work, they fixed it, and one month later (and outside of the warranty period), it is now doing the same thing again.
  • Anonymous Dec 22, 2008
    Mi LCD flx 1910 de 19" dejo de encender ,la fuente funciona bien pero no prende ni el stand by .Cual es la solucion?
  • lhancockjr Jan 16, 2009
    Same problem. 19 Inch FLX-1910 will not power up.
  • aerochip Jan 24, 2009
    I get sound, but I can't see any image!
  • paintx Jan 27, 2009
    Normal
    0
    false
    false
    false
    MicrosoftInternetExplorer4
    /* Style Definitions */
    table.MsoNormalTable
    {mso-style-name:"Table Normal";
    mso-tstyle-rowband-size:0;
    mso-tstyle-colband-size:0;
    mso-style-noshow:yes;
    mso-style-parent:"";
    mso-padding-alt:0in 5.4pt 0in 5.4pt;
    mso-para-margin:0in;
    mso-para-margin-bottom:.0001pt;
    mso-pagination:widow-orphan;
    font-size:10.0pt;
    font-family:"Times New Roman";
    mso-ansi-language:#0400;
    mso-fareast-language:#0400;
    mso-bidi-language:#0400;}
    Element Electronics
    FLX-1910
    Problem: When the power button is pressed the screen turns
    on momentarily and a buzzing sound is heard, then the screen goes blank and the
    buzzing sound stops. Audio can be heard
    fine but no image is displayed on the screen.
  • Anonymous Mar 29, 2014
    Just bought a 19" elements flat panel tv....the sound is hollow...?
Element FLX-1910
Problem: When the TV is turned on a picture appears for a few seconds and then the picture turns off. Audio is still heard.
Solution: Not a simple fix! This TV has 4 small florescent looking bulbs that act like a back light to light the image on the liquid crystal display (LCD). At least one of these bulbs is burned out or broken. The wires powering the broken bulb need to be cut and spiced together. Basically you’re bypassing the bulb and completing the circuit when cutting the wires going to the bulb on each end and splicing them together.
WARNING: This worked for me but no guarantee for anyone who tries it. This is a very involved procedure and involves completely dismantling your television. To be honest I don’t recommend anyone trying to fix it unless you are very technically minded and have a couple of hours to waste carefully tearing apart your TV. If anyone is willing to attempt this repair I am willing answer questions.
Cause of problem: It is my guess that this problem occurs when the TV is left on for extended periods of time. Like leaving the TV on when you fall asleep at night. My TV was left on a lot. I noticed that the plastic was melted and discolored where the bulb had burned out. (This can only be seen internally and is no way visible from the exterior)
Posted on Feb 14, 2009
    Problem Solver:
  • 12 Answers
As PAINTX said, one possibility is to check the wires/bulbs in the LCD Panel....mine can be easy found because the wire that connect one of the bulbs looks burned....after removed plastic,on LCD Panel corner, wire has no contact with the bulb....just need a solder iron and technical skills to repair it. After that, Picture looks normal.
If in your LCD TV, picture looks very, very dark, but you can see it seen, maybe you have to change Power Supply/Inverter Board (both circuit in same board, aprox. 50 dlls). Of course, also look for a defective capacitors, before buy the board.
If no picture at all, maybe the wires of the bulb lost contact.
Thanks PAINTX.
Posted on Jul 30, 2010
2 Suggested Answers
  • 408 Answers
SOURCE: my element 19 inch flx-1910 tv will not power up
did you make sure the voltage, amperage, and polarity were matched tv to plug?  The information is found on the back of your tv and the plug must match that.  If they do not match, you might have fried your tv.
Posted on Mar 11, 2009
Element lcd wont turn on
element electronics Flx-1910 19in'' not on
Nov 19, 2012 | Element Electronics FLX-1910 19 in. LCD...
Element stuck in standby and wont turn back on.
you can unplug the power cord and drench the power and after go ahead and plug in back the TV and try to start it
Jul 30, 2010 | Element Electronics FLX-1910 19 in. LCD...
Digital channels don't work anymore for my tv with
Switch position of televisions trial and error situation and let me know the result
Nov 16, 2017 | Element Electronics FLX-1910 19 in. LCD...
Can't remove stand from Element flx 1910 TV.
On the bottom of the Element FLX-1910 there are 4 tabs located on the bottom side of the base. With the help of another person, please slide all 4 tabs in an inward direction. This will release the tension between the base and the stand. Slide the base over the tabs and remove the base from the stand.
Apr 12, 2009 | Element Electronics FLX-1910 19 in. LCD...
Mar 11, 2009 | Proscan 19LA25Q 19 in. LCD Television
Televison & Video Logo
1,262 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
