Question about Kenmore Washing Machines
Washing machine model 110.42832201 - cleaned out the pump and I now need to run the self diagnosis - what is the procedure to get that started for this machine?
  • Kenmore Master
  • 2,605 Answers
There are a couple of way`s to enter a diagnostic. I`ll start with what I think is the easiest. Close the door, you don`t have to power up the unit, as long as it is plugged in is sufficient.
On the control panel choose one button with the exception of stop/cancel. Push and hold it for 4-5 sec. release for 4-5 sec. and repeat this sequence 3 times. If entered correctly all the led`s will light and the display will show 2 digit`s, usually ``00`` or ``U0`` something to that effect. It will display all the version`s of the individual control`s i.e. ccu, uib, mcu, etc.
With the same button you used to enter the diagnostic, you can step (or advance if you like) thru the test cycles until it exit`s the diagnostic at the end. If at anytime you wish to stop, press cancel.
Hope that answer`s your question. Good luck and thank`s for visiting fixya.
macmarkus :)
Posted on Dec 13, 2009
Hi there, the drain pump keeps running and nothing else happens on my dishwasher. Any thoughts?
The make and model would be nice to know. Most of the new machines start with the drain pump initialization to begin a diagnostic self test. IF it is sticking in this phase, then the sensor that tells the machine is full has a problem or the control board is bad. To reset the machine, unplug it or shut off the breaker for a minute.
Oct 04, 2015 | Washing Machines
Where is the filter?
My hotpoint is same you have to pull machine out then tip on side carefully then remove black sump pipe right by pump at Back machine clipped on so remove clip holing to drum and pump. Also the pressure sensor might be attached just unclip then clean filter out and put back clipping back on tight. Hotpoint have self cleaning pump on these models but has catch by pump that can get blocked only new models of hotpoint made this easier hope this helped :)
May 06, 2014 | Hotpoint Ultima WF865 Front Load Washer
Siemens SI14-44 washing machine is error coding F:18. something wrong with the emptying of the machine.... is the filter blocked? is so where can you clean out the filter?
check in the manual for the error code most of washing machine if the error code is in users manual its means its only minor problem,but if the error code is not in users manual its means you need to call an service technician to not waste your money or time if you do by your self.
F:18? if this error is for water stuck?
for the automatic washing machine mostly have drain pump, please check the filter of your drain pump, if clog your drain pump of some hair pins,cotton buds or coins or any small item,that the cause of water stuck,and it will long time draining or totally not running the drain pump.and its cause of stop of cycle of washing machine in rinse time or spin time,because after washing the pump must be on to remove water before start the next cycle.
Nov 02, 2013 | Washing Machines
417 44152400 21 code reads e63 and machine not draining properly
Good Day,
Your washing machine is fully automatic?
the washing cycle is normal?
if yes do the same maybe it will help you.
for the fully automatic washing machine mostly have drain pump, please check the filter of your drain pump, how? remove the cup of your drain pump like a ordinary cup, screw it clock wise or counter clock wise.
Remove drain pump filter and clean it, some hair pins, cotton buds or coins or any small item that coz of clog up.
if your washing machine dont have drain pump ,but fully automatic check the drain motor if running or not? how? open the back cover for top loader washing machine only, select spin cycle and press start to see the drain motor running? the drain motor is like a small box with small wire to pull the lever of the drain to remove water inside, if the motor running or pull the lever of the water pipe but water still inside the washing machine, remove the drain cup or cover and clean it or check if have coin or cloth inside that coz of clog or water stuck,
if the drain pump or drain motor is weak this is will cause and long time draining or totally not running the drain pump or drain motor and its cause of totally stop the cycle of washing machine in rinse time or spin time, because all fully automatic washing machine, after washing cycle the drain pump or drain motor must be on, to remove water before start the next cycle. rinse or spin cycle.
Nov 01, 2013 | Kenmore Front Load Washer
Washer will not spin out
There is most likely a clog in the pump filter. Check the hose between the tub and drain pump. If that isn't it check the door switch.
Cleaning the pump procedure is here:
http://www.youtube.com/watch?v=b3kL3daLZ9g
Door switch procedure is here:
http://www.youtube.com/watch?v=FGo3xEABxm0
Jan 23, 2013 | Frigidaire Washing Machines
How to find filter in Intuitive model
check your pump down at the bottom of the machine take the bottom plinth off the plastic that runs along the bottom of the machine once off on the right hand side you will see your pump you will need to undo the black screw and get your self a towel and a small and big bowl there will be a lot of water so when you have took the screw out start turning the pump cap very slowly and when you have filled the small bowl close it and keep repeating it till all water is gone then take it right out if its stuck then pull it clean it out and put back together don't for get to turn your machine off be for doing any thing ok hope i have helped if after you have done the pump and the machine still do the same thing then its programmer ok
Nov 01, 2012 | Fisher and Paykel Washing Machines
Whirlpool washing machine AWM 5100 has stopped going thru the full cycle.
My machine did a similar thing and in my case, it was debris in the filter. It took several clear-outs before the object appeared.
Mar 21, 2012 | Washing Machines
Message
Having read the other reviews here, I was prepared for the cryptic "VENTILATE" message. (The manual refers to this procedure as "Loading the circuit", which doesn't help to clarify things.) Of course this refers to what Americans would call "priming" the machine. As mentioned in another review, there is a plastic hand pump supplied for priming, but that is only needed in the event that the electric pump fails to self-prime. All I had to do (following the quick-start instructions) was to select the Hot Water function; the internal pump quickly primed itself. clean machine with the Saeco scale remover thank you ,Lee Davidian
Jan 17, 2010 | Saeco Magic De Luxe Espresso Machine
Problem diagnosis please
touch pad is stuck on the control panel machine putits self in self test
Mar 03, 2008 | Washing Machines
Duet Washing Machine model ghw9100lw1 FH ERROR CODE
you should here a humming noise, just before water comes in .do you?close eire let me know.
Dec 07, 2007 | Whirlpool Laundry 27'' Duet Ultra Capacity...
Washing Machines Logo
56 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
