Question about Samsung S760 Digital Camera
Lens not opening
I washed the camera holder using detergent powder then let it dry. When the camera case was already dry I put in the camera back to the case. Then after a day I get the camera and tried using it. Its no longer working. The battery is brand new and fully charged but all I can hear was like 4 clicking sound and I noticed that the lens wont come out anymore and I noticed that loks like the powder caused it.
    Problem Solver:
  • 16 Answers
The cam hold. was not fully dry even though you thought so...
Posted on May 15, 2010
How do you use the tub clean?
Read these instructions carefully before
beginning the TUB CLEAN cycle.
Open the door and remove any clothing in
the wash drum.
Open the dispenser drawer.
Add liquid chlorine bleach or tub cleaner.
Some powder or tablet tub cleaners which
are manufactured for this purpose can be
used.
(NOTE : Do not add any laundry detergent
or fabric softener to the drawer when using
TUB CLEAN.)
- If using liquid chlorine bleach
Add liquid chlorine bleach to the bleach
compartment of the drawer.
(NOTE : Do not exceed the maximum
fill line and do not pour undiluted liquid
bleach directly into the wash drum.)
- If using powder cleaner
Remove the liquid detergent cup and
add powder cleaner to the main wash
- If using tablet cleaner
Add tablet cleaner to the wash drum
directly.
(NOTE : Do not add tablet cleaner to the
drawer.)
Close the drawer and washer door.
5
Select TUB CLEAN and press START.
NOTE : It is recommended that TUB CLEAN
should be repeated monthly.
If mildew or musty smell already exists, run TUB
CLEAN for 3 consecutive weeks.
After TUB CLEAN is complete or when the washer
is not used, leave the washer door open for better
ventilation and drying inside of the washer
Jul 05, 2014 | LG WM2701HV Washer
CAN I USE DRY DETERGENT(SUCH AS TIDE,OR DO I HAVE TO USE A LIQUID DETERGENT FOR MY FRONT LOAD MACHINE?
Hi ,
You can use both. If u r using dry detergent it will stick on the area where u r pouring that detergent powder, in case liquid i will not stick and easily disolvable. according to ur budget u can choose tat.
Aug 09, 2011 | Frigidaire Washing Machines
I do most of my shopping online and liquid bleach sometimes doesn't ship without breaking. Is it OK to use dry or powder bleach? I have the whirlpool cabrio top load large capacity model.
It should be okay to use dry bleach, if you follow the instructions on the bleach. Some bleaches require dissolving in water first, others can be used dry.
May 13, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
We clean the filter after every wash but we still get black & white bits on the washing wa have cleaned the waste pipe, pump filter at the back is always clean .model no sw75usp can you help under...
Hi bob, have you tried cleaning the dispencer drawer that supplys the detergent to the tub? in some cases over time the detergent holder can collects small amounts of powder that can dry out and stick to the walls of the holder and when the machine is in its spinning stage can sometimes vibrate the dry powder in turn cause the powder to enter the tub also there can be a huge build up of liquid detergent like softners that can form a hard black residue in the holder in turn causing the clothes to collect black paticles. If all is ok then you could try applying a hot wash cycle without any clothes in the tub to flush the bowl from any contaminents, thumbs up if this helps thanks.
May 06, 2011 | Samsung Washing Machines
The dispenser door is stuck in the closed position. No matter how much I try to jiggle it open the door will not slide out. How do I get the door to open without breaking something?
Hi stuwstark, you could try running a quick wash cyle without any clothes in the tub once cycle is activated you will hear water flowing through the dispencer holder from there you can try riggling the dispencer to see if it will loosen up, in some cases the dispencer holder can become stuck due to dry soap powder clogging up the sliding rails also the dispencer holder can become stuck due to the liquid detergent box "insert" becoming loose and jamming it self up against the top casing of the dispencer holder so by applying the cycle when the water flushes thru the holder could ease the hard powder or could float the insert making it easier to open,try it and see how you go, thumbs up if it helps thanks.
May 06, 2011 | LG WM-2277HW Front Load Washer
How can i use the liquid soap inside the dishwasher
just fill the same holder that you would use for powder.
Dec 17, 2010 | Dishwashers
Why does a lot of detergent remain in the soap dispenser after a washing cycle is complete
Was the dispenser cup wet when you added detergent?
Make sure the dispenser cup is dry before adding powdered detergent. If dispenser cup is wet, the detergent can clump.
Is the cycle incomplete?
If the previous cycle did not complete, the detergent can become caked in the dispenser cup if it is left sitting in the dishwasher.
Is the detergent old?
Older detergent exposed to air will clump and not dissolve well, which will cause the dispenser door to stick to the detergent. Replace detergent if necessary and store the detergent in a tightly closed container in a cool dry place.
Is the water temperature too low?
For best washing and drying results, water should be 120oF (49o C) as it enters the dishwasher.
Were items blocking the dispenser that kept it from opening?
Items blocking the detergent dispenser will keep it from opening. Make sure water action can reach the dispenser.
Detergent guidelines
  • Use automatic dishwashing detergent only.
  • Other detergents can produce excessive suds that can overflow out of the dishwasher and reduce washing performance.
  • Store tightly closed detergent in a cool, dry place.
  • Fresh automatic dishwasher detergent results in better cleaning.
  • Add detergents just before starting the cycle.
  • The amount of detergent to use depends on the hardness of your water and the type of detergent.
  • If you use too little, dishes won't be clean.
  • If you use too much in soft water, glassware will etch.
  • Suggested fill amounts are for standard powdered detergent. Amounts may vary if you use liquid or concentrated powdered detergent. Follow instructions on the package when using these detergents.
  • Water hardness can change over a period of time. Find out your water's hardness by asking your local water department, water softener company, or county extension agent.
Nov 25, 2010 | LG Washing Machines
Do I put powder detergent in the same place I put Liquid detergent?
Detergent compartment
Add liquid or powdered detergent to this compartment for your
wash cycle. The detergent separator must always be in place,
either in the front or back position.
 Do not fill beyond the “MAX” level.
 Liquid or powdered color-safe bleach may be added to the
Main Wash compartment along with the same type of
detergent, liquid or powdered.
 Liquid detergent: Put the SEPARATOR in the front position,
between the guides, as shown as shown by Position 1 below.
There will be no gap between the bottom of the wash cycle detergent
compartment and the bottom of the separator.
Powdered detergent:
Put the SEPARATOR in the back
position, behind the guides as shown by Position 1 below. There will be
a gap between the bottom of the wash cycle detergent
NOTE: The separator will be in the POWDER (back) position
when shipped from the factory.
Nov 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Repeated failure of the aluminum hub which carries the spin tub. It appears to be eaten away by water or detergent. Casting pockets are filled with what appaers to be dried detergent residue in spite of...
The major cause of drum support failure is the use of todays modern powders and detergents, also .
another major factor is washing at too low a temperature.
At low temp washes , some of the active ingredients do not function at low temps..You need to change your washing habits.
Always follow the instructions on the wash powder manufacturers products, and at least once amonth do what is called a maintenance wash,this is putting the washer on at a high temp, with powder in, but no clothes.
This helps to keep the inside components clean
Another factor is using biological and non biological powders,
Dec 08, 2008 | Washing Machines
Detergent holder
Possible your detergent dispenser is clogged, use an old toothbrush to clear out. Because of dried-up detergent clogging it................
Jan 30, 2008 | Washing Machines
Samsung S760 Digital Camera Logo
46 people viewed this question
Top Samsung Cameras Experts
Computer Links
Jerry Z
Are you a Samsung Camera Expert? Answer questions, earn points and help others
