Question about Panasonic PT-47WX53 47" Rear Projection HDTV
The screen is slightly slanted and there are two images
  • Panasonic Master
  • 8,617 Answers
Classis convergence issue. The PT53WX53 convergence repair kit from www.tvrepairworld.com should fix that issue. The kit also contains the CD with instructions.
Posted on Dec 13, 2009
    President:
  • 788 Answers
If you try to adjust convergence with the flash focus, perfect focus, (depending on the make of your set) or by manual convergence and the lines will not line up or even move. What you might be experiencing based on this symptom sounds like a convergence IC problem.
I have repaired hundreds of these sets, so if you have any questions after reading the following, please reply to this post and I will help you in any way that I can.
With any Projection Television that has a damaged convergence problem, you do not want to continue the use of the set. If the IC’s continue to fail they will cause a short in the power supply and cause your television to not power up, and possibly damage the CRT’s in the set.
With that aside I have some support suggestions that I have put together that may help you make an informed decision.
You should be able to get a local service center to repair this at your house for between $350.00 - $450.00, If you want to repair this set yourself, I have some instructions below that will be a help to you.
While it is not a very hard repair, this repair can be a bit tricky
How do I tell if the IC’s are damaged?
When looking at the area around the convergence IC’s you see some resistors that have changed colors, or you test a resistor and it no longer reads the marked value. You will have to replace the IC’s and the supporting components.
When you remove the old IC's, please be sure to remove all of the old heat sink compound, as it can act as an insulation for the new IC's and cause them to overheat. I usually clean the heat sinks with alcohol and a small rag.
Where are the IC’s located and how do I find them?
There are two and large IC’s that control the convergence in a big screen set. Some of the newer sets only have one. If you only have one, it is right in the middle of the set on the center circuit board. They are secured to a very large aluminum heat sink. They will have a part number stamped on them that will start with an STKXXX-XXX, like STK392-110.
Along with the convergence IC’s there will also be some associated components that will need to be replaced as well. There are some resistors that are part of the convergence circuit that will be open and need to be replaced. Most likely these will appear charred in the center. If you have an Ohm Meter or a DVM, check all the resistors that are close to the IC’s and you should be looking for either ones that have opened or have changed values.
If one of the convergence IC’s are found to be bad, I would replace them both, if one has gone bad the other may go soon. I usually order my parts from Andrews Electronics in California, they will have the OEM components that you will need.
Their site is
http://www.andrewselectronics.com/welcome.aspx
And their phone number is a 24-Hour Order Desk: (800) 274-4666
I recommend the phone order so you can talk to the person about the different types of IC’s that are available.
I would also advise that the convergence IC’s be OEM or better, just because they are cheap does not mean that they are a good deal. I have seen the cheap IC’s fail after a short time, even though they look exactly like the OEM IC’s. I think that the bottom line is that you will get what you pay for when it comes to the parts.
You can also try
http://www.tvrepairkits.com/ , I have not tried them yet, but they do carry OEM or better parts.
I hope this information allows you to resolve this issue.
If you need further assistance please comment to this post and I will try to help you further.
Thanks for using FixYa
asnowman
I have attached some photos of really bad convergence problems; your picture may not be exactly as bad as these.
the screen is slightly slanted and there are two - 6cf0bc3.jpg.
Have a JVC AV-48WP30 rear projection tv set and the green seems to be out of place. the green image is lower than the others and is in a wave shape on top of screen and bottom.When I adjust the convergence...
Your convergence IC's are bad. If your not doing the work it will probably cost in the neighbor hood of $250.00 for a service company to do. Not a major repair.
Nov 03, 2009 | JVC AV-48WP30 48" Rear Projection...
Tip
Overhead Projector Tip- best results!!
For best results, slant the screen forward slightly so it meets at a 90 degree angle with the projected image light beam. In not, then a keystone effect results where the projected image is taller on top or on the sides; in other words, the projected image is a parallelogram, not a square.
on Aug 16, 2010 | Office Equipment & Supplies
Top of screen slants on the right and left side horizontally
go in touch with SONY i assume ur set is still under warrenty.....call customer help and support
Mar 12, 2009 | Sony FD Trinitron WEGA KV-36HS420 36" TV
Slanted Border- Projector image is not square
Is the image slanted on the bottom as well?
Make sure the projector's throw is pointed directly at the target ie. screen or wall etc. there's not much else it could be.
Jan 10, 2009 | InFocus ScreenPlay 4805 Multimedia...
Monitor screen problem
Check your cables. Make sure they are secure.
Apr 07, 2008 | Compaq fs740 17" CRT Monitor
MONITOR SCREEN KEEPS BLANKING OUT WITH A ORANGE COLOR OR BLUE COLOR
It is one coulour missing and it can b mostly due to CRT socket loose or some dry solder in CRT {RGB) path..
Chck out...
This is a technical freak from INDIA!
Slanting Picture
The yoke has probably come loose and tilted.. From the rear of the set looking on the back of the crt you'll find a copper wire wound magnet called the yoke. It terminates on the neck of the yoke with a clamp. With the set off slightly loosen the clamp and turn the yoke assembly in the opposite direction - key word here is slightly - and apply power to check the alignment.
Keep doing this until you achieve the alignment you want. And always remember to unplug the set between attempts.
Nov 05, 2007 | Sharp 32SC26B 32" TV
Slightly slanted screen/picture
your main filter capacitor in power supply has gone defective.
just replace it .
every thing will be normal.
good luck.
Oct 17, 2007 | Toshiba 36AF43 36" TV
DC400 Screen only showing slanted multicolorlines
No this is clearly a CCD sensor problem ( CCD generates image in v-cams and still digital cameras ) if the sensor is outputting too much noise then your image will be distorted just like yours is. If the sensor is outputting nothing then camera shows blank screen ( also notice that with this problem you can playback OK ). Replace CCD block.
Sep 06, 2007 | Audiovox DC400 Camcorder
Horizontal lines on image
Either screen or ccd sensor faulty. T establish which see if you can can normal playback : if the immage looks ok in playback mode it is the CCD sensor. Either way camera has to go to your agent or qualified repairer.
Aug 18, 2007 | Sony Cyber-Shot DSC-P200 Digital Camera
Panasonic PT-47WX53 47" Rear Projection HDTV Logo
96 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
