Question about Nakamichi MB-8 5-Disc CD Player
CD loading mechanism is jammed
Nakamichi MB-2s CD player mechanism is jammed and can't load or unload discs. I have removed the 7 trays for the loading mechanism. The mechanism seems to be stuck where the gears interlock with some sort of notched lever at the bottom of the mechanism.
4 Suggested Answers
SOURCE: Nakamichi MB-2 CD Player tray sticks
It sounds like the belt that opens the try is getting bad and beginning to slip, a common problem on CD players like this. You should be able to find a replacement belt online.
Posted on Jun 21, 2009
  • 11800 Answers
SOURCE: I have a Nakamichi MB-10
That machine resets when you unplug it from the wall for more than 15 minutes. If the Er message still appears it's because the unit detects a damaged part when powered. Since the first sign of error has been a noise relating with the disk trays then most likely the problem is there, with the tray mechanism.
You will have to open it again and access the mechanism to identify the broken part and if it's repairable.
Posted on Sep 26, 2010
  • 169 Answers
SOURCE: nakamichi cd cassette player 1 not spinning discs
There's a Music Bank 7-disc player in use in my bedroom these days. Nice unit, but they used to come in for service once in a while- from what I could tell, these units don't 'park' the CD drawers on a soft power off- they simply shut down. When powered up again, they sometimes let the disc last in play slide off the tray & jam the machine. I've had no issues, as long as I always hit stop, wait for it to park, and then shut off. The analog output's sound has been very good (has a coax out as well).
Posted on Jul 28, 2012
How to open Nakamichi CD Player MB-4s 7 disc musicbank. It has 7 our discs inside and we cannot reject them and we are unable to open the Nakamichi box.
Not really familiar with this one but most will have a very small hole somewhere on the front of the machine near the opening. A straightened paper clip pushed into the hold should open the tray.
Dec 06, 2016 | Nakamichi Car Audio & Video
Dvd tray error?
It is a mechanical problem with its disc loading tray. Either a broken loading belt, or a broken gear wheel at the disc loading section can poise this kind of problem. It can be repaired; by take out the disc loading mechanism from the set. Contact any service technician. http://electronicshelponline.blogspot.com/
Jul 06, 2016 | Curtis LEDVD1975A 19 LED HDTV DVD Player...
Nakamichi cd cassette player 1 not spinning discs
Jul 28, 2012 | Nakamichi Audio Players & Recorders
It's a 6 cd player I went to load the next cd in and all of a sudden the first disc is not worken
The CD loading mechanism has broken, a common failure in all CD players, remove it and send it out for repair.
Feb 13, 2012 | Mitsubishi Grandis Cars & Trucks
Jammed tray
Hi there, had a similar problem.
This unit is easy to open. the four screws on the sides and two i think on the back. When it is open you will have access to the discs in the machine. the last disc will probably be jammed between the facia and the caddy and will be impeding the carousel mechanism, once removed you should check the functions starting with eject, and again to cycle, load disc position 1 insert disc and check. this player i think rotated the disc on loading to a set position, would have to open one to check. hopefully the carousel is not out of sync and all is well.
May 01, 2009 | Sony CDP-C265 CD Player
Nakamichi MB-70 CD player - cannot get cd to eject
Having just removed three discs from an identical unit which also jammed, I will say how easy that was. I do not know if the unit will now function when reinstalled in the vehicle.
Remove the unit from its mounts, remove the outer "frame" (if fitted), remove the two #2 phillips pan head screws from the sides holding the face to the chassis, remove the four #0 phillips screws (black, flat head) from the top and bottom of the face plate.
Slide the face plate off and carefully handle it while tethered by its ribbon wire.
Turing the unit upside down, peer into the opening and observe the disc, gently press the carriage away from the top of the unit (now the bottom, as it is inverted) and allow the disc to be freed, simply pull the disc out.
If there are multiple discs stuck inside, oberve the large metal gear just inside, carefully rotate the gear to actuate the loading mechanism as needed to release addtional discs.
Feb 23, 2009 | Nakamichi MB-70 6-disc In-dash Musicbank...
Sony DVP-CX995V
Its problem of incomplete unloading of CD tray so system control in player sense it and generate command to close it.
CD Loading mechanism needs service and cleaning to loading belt.
If you have electronics experience, you can make it easily. let me know if you need further info.
Nov 20, 2008 | Sony DVP-CX995V Multi-disc DVD Player
Nakamichi MB-100 Disk error
VERY COMMON PROBLEM
THE BEST THING TO DO IS THROW IT AWAY
Jan 11, 2008 | Nakamichi MB-100 6-Disc CD Changer
Nakamichi MB-8 5-Disc CD Player Logo
264 people viewed this question
Top Nakamichi Audio Players & Recorders Experts
Jerry Greenberg
Jerry Greenberg
Rommel Balcita
Colin Stickland
Colin Stickland
Are you a Nakamichi Audio Player and Recorder Expert? Answer questions, earn points and help others
