Hello...
I know it may sound simple, but did you check all the applicable fuses.
Good Luck
Not sure if you have it, but there is a fuse O (letter) that is part of the circuit. If that does not apply, its time time to start checking grounds and connectors. Also, make sure there are no blow blinker bulbs.
Good Luck
Sorry, from my information I cannot tell where it is located. It just states that it is in the Power Dist. Center (PDC).
Good Luck
Yes i did check & replace fuse 9 marked turn signals. is there more that i dont know about.
Do you know where this fuse is located?
the power distribution centre is that the bank of fuses and relays under the hood?
It was under the hood. Fuse marked O, 20 amp for hazard lights, thanx for all your help.
Ok now ive got problems with my blower motor resistor. Is there any way to bypass it n run the fan motor direct on high or something. i have to wait until next week for the part.
