Question about Jenn-Air Kitchen Ranges
RH 800 pull-out range hood. I have a new motor to
I have a new motor to install. i need direction on how to put fan motor and wire housing back together.
  • 1314 Answers
SOURCE: missing wire
to the body of the range
Posted on Jan 19, 2008
  • 203 Answers
SOURCE: Range hood light switch not working.
you have checked the bulb? if so the the switch of disconnect from supply first and have a look at the condition of the switch it might be full of goo. joe
Posted on Nov 22, 2008
SOURCE: fan switch not work - Viking 3048SS brand new range hood
I did some more troubleshooting and figured out how to get the plate off that houses the switches. I disconnected the fan switch and created a safe electrical by-pass. I re-connected the main power supply and sure enough, the fan worked. Issue = defective switch. Currently looking to order replacement. Problem solved.
Posted on Apr 11, 2009
SOURCE: Ventline Range Hood Fan broken
In my RV, which should be similar, I removed the filter from the hood. With power off, I removed the fan, which was held on with a clip. Removed two screws holding the motor in and took it to a camper supply store. Mobile home supply would have had it, too. You might find the motor on line if you go to the website of the manufacturer or search for parts for that brand.
Posted on Sep 02, 2009
  • 16 Answers
SOURCE: newly purchased. self-installed MGR7662 keeps
you can not have it on a gfi outlet
Posted on Sep 05, 2009
How to replace the condensor fan on GE Mod.gdl20kcsabs --bottom freezer
How To Replace the Condenser Fan The condenser fan is located behind the refrigerator. It may be necessary to remove an access panel to reach it.
If the fan blade is damaged, it can be removed from the fan motor and replaced separately.
Caution:Please read our safety information before attempting any testing or repairs.
cautiontri.gif Before replacing the condenser fan, unplug the refrigerator to avoid an electrical shock hazard.
The fan motor is held in place with screws and possibly a mounting bracket. Remove the bracket and the screws and pull the motor back away from the housing.
The fan motor is connected by two or three wires. Label the wire placement on the motor before disconnecting the wires. The wires are connected to the terminals with slip-on connectors or a plug. Firmly pull the connectors off of the terminals (do not pull on the wire). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If the connectors are corroded they should be replaced.
Remove the fan blade from the old motor and install it onto the new motor. Connect the wires to the new motor and install the motor into the bracket or housing. Make certain that all of the screws are tightened securely.
Replace the access cover (if any) and plug in the refrigerator.
Jul 15, 2011 | Refrigerators
I have a" Nautilus Microtek
The motor is getting worn to the point it will stop soon. Remove the screen and you find the fan/motor directly behind it. You can try to put some machine oil on the motor shaft next to the motor housing. It may quieten it some. Recommend you replace it. Be sure you disconnect power before you do anything else. The motors and fan assembly is small in size and can be bought in Home Depot or an appliance store. If you need assistance in removing the motor/fan and installing new one, please let me know. Those brands are found at Home Depot.
Jun 18, 2011 | Kitchen Ranges
Hi. Last Friday we had a new Kenmore stainless steel range hood installed along with a new range. Yesterday the range hood fan and lights would not work. The fan does not come on at any speed. The lights...
Some installers plug the fan/light into an outlet in the cupboard above. Check to see if that has power. Some of the outlets are behind a panel in the cabinet above and you have to remove the screws. I have seen the plugs laying in the cabinet just like they had never been plugged in. Yours obviously was plugged in but maybe fell out. If the fan/light is hard wired than you should make sure the power is turned off at the breaker box and then check the wiring inside the box to make sure it is wire nutted together and is holding. I would also check that the breaker for the fan/light is still putting out power. These last two might be a little tricky if you have never tried them. The breakers sometimes go bad but look like they are set. If the whole hood fan is not getting power it is probably time for an electrician or the people who installed to come back.
Aug 25, 2010 | Kenmore 52153 Stainless Steel Kitchen Hood
My Range Hood (Best by Broan K260A) is just two years old in a new house. WHen I use it, fat & grease drip down from the left and right edges against the wall. Can someone tell the problem?
grease accumulation, remove the fours screws on the lower plate, to remove excess grease. further you can unscrew the bolt that are holding the assembly and unplug the unit. after remove fans with allen key and remove motor , clean and reassemble , make shure to put motor the right back the same way. reassemble the same way , problem should be solve for at least 7 years depending on cooking.
Mar 15, 2010 | Broan-NuTone Broan Range Hood Accessory
I just had a Broan Elite E662 hood installed and it is blowing out instead of pulling air in. I held a tissue up to the filter and it does not pull it up...rather it blows it down. Was something done...
It sounds like the fan blade may be installed upside down, or the entire motor/fan assembly is upside down. Typically, these small motors aren't reversible, so you should check the blade first.
Dec 13, 2009 | Broan-NuTone Broan Elite RM605404 Kitchen...
Fan switch not work - Viking 3048SS brand new range hood
There is the on off switch and the blower control that controls the speed of the fan. It is more than likley the blower control that would need replaced.
There could also be a wire disconnected in the hood.
Aug 19, 2008 | Viking VWH3048 Kitchen Hood
Brand new Viking 3048SS hood - fan switch not working
think i would call viking back and ask for refund of inspection fee and go by the bad switch scenerio the electrician said new fan that would be considered flaws in workmanship in most states dont know where you are located but pretty much same anywhere most inspectors for these companies always try to blame problems off on installers hold your ground and make them fix it and refund that" inspection " fee I've been doing electrical work for several (20+) years it takes longer than 5 minutes to troubleshoot something like that good luck
BABT83.2AL Canopy Rangehood The fan/suction is not working. A slight straining noise is heard. The light is working as is the display panel.
These units have a history of fan failure due to inferior 220 volt Italian fan.
I have just had fan fail and retrofitted a ebmpapst blower fan model D2E146HT6702 which is readily available in Aus for around $120.
The fan speed control is by inverter variable output so you don't use all the speed select wires that this fan has. Connect the Red wire on the range hood to the Black on the motor (High speed winding) and the Black on the range hood to the Blue on the motor (Neutral) and the earth to the earth (Green).
Disconnect and toss the cap in the white enclosure under the PC board enclosure (the new fan has the cap on board). Don't know how easy to fit in the range hood as mine is in an acoustic fan housing in the roof (makes it wisper quiet when running)
Apr 07, 2008 | Baumatic F60 Stainless Steel Kitchen Hood
Broan fan cat h 500 housing 115v 60 c 1.5a lr 31619
Customer Service: 800-558-1711
Technical Support: 800-637-1453
Oct 13, 2007 | Broan-NuTone Best By Broan BER02IS 48"...
Kitchen Ranges Logo
70 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Sal De
Craig Butler
Craig Butler
Paul Carew
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
