Question about Bissell 6594 PowerForce Bagless Upright Vacuum
No dirt is collecting in chamber and doesnt seem to be picking up
  • 8,404 Answers
The hose is clogged. try sucking the dirt out with another vacuum (backward) If this doesnt work, you will have to disconnedt one or the other or both ends of the hose to remove the clog. this is a simple process.
thanks for your interest in FixYa.com
Posted on Dec 13, 2009
My dc07i has power to hose but isn't picking up when hovering carpets or hard floors the roller is going round but there is no suction
I would guess that the line is plugged between the pick-up where it goes to the dirt tank. Lots of time when something big gets sucked in, it still lets the dirt in the tank. However over time dirt collects around the wedged object and gradually over time plugs the passage way. It may take a little time to pick out the blockage. You may have to somewhat take it apart. to get at it. This happens to my shop vac a lot.
Dec 31, 2014 | Dyson DC07i Bagless Upright Vacuum
Not picking up, belt and filter have both been changed
on the feather lite remove the bottom, and look into the bend in the flow chamber that goes up to the canister,, debris lodges in that bend causing the machine to not pick up
Jul 05, 2011 | Dirt Devil Featherlite Bagless Upright...
VACCUUM SEEMS TOOST SOME OF ITS SUCTION POWER
How often have you changed the filters in the vacuum?-- and when was the last time you did it now?
Obviously emptying the dirt collecting chamber OFTEN helps the vacuum--
but then in addition, there are several filters-- are they clean?
Pull them out, tap and otherwise shake the dirt loose from them, until they are clean--
(Compressed air is great for this-- but you might not have that nearby, right?)
Do yo have another vacuum that might help you clean up the filters?
Or-- maybe it is time to replace all the filters?
Let us know how successful your efforts on the above turn out.
Mack B
Dec 28, 2010 | Bissell Vacuum - Momentum Cyclonic 1 ea...
It doesnt seem to be picking anything up
Check the hose...they plug up and then everything stops...
Here is a tip that I wrote after having the same issues with my Bissell...
Bissell Bagless Upright Vacuum2_bing.gif not working
http://www.fixya.com/support/r4387950-bissell_bagless_upright_vacuum_not
heatman101
May 20, 2010 | Dirt Devil Featherlite Deluxe Bagged...
Gets hot picks up dirt then it falls out again
Check the throat of the vac itself where air and dirt passes through to the back and into the intake. The heat would indicate you have a loss of air flow though to the chamber.. try dropping a coin backward through from above down to the bottom of the vac. his will help indicate whee a blockage is.
Sep 26, 2009 | Eureka Capture Upright Vacuum Vacuum
Dirt not going in to the right "chamber"
hello. i can help you. here is your link to a free replacement manual
http://www.eureka.com/owners_guide.jsp
also, check the hose to make sure that a foreign object isn't blocking airflow. Next, make sure the airflow switch is set correctly. Many models have a switch that changes the suction from the main vacuum to the hose attachment.
Jun 22, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
Bissell powerforce bagless vacuum,when turned on dust flies out sweeper
Dust flying out of the sweeper indicates that their is a blockage in the pathway that the dirt normally travels to get into the dirt collection chamber. Turn the sweeper upside down and look for a blockage of some kind. Also, empty out the canister and look to see that the pathway into the canister is clear.
May 18, 2009 | Vacuums
Dirt smell
If this thing has a fast-spinning belt in the "head" of the unit, you are smelling the dust that is being collected in the back of the little drive "chamber" and is being heated up by the motor and the friction of the belt. This is a pretty common thing on vacuum cleaners designed like the Oreck. If it is huge bunnies of dust, well then that means there is a leak somewhere...
Mar 11, 2009 | Oreck XL Ultra Bagged Upright Vacuum
Dyson won't pick up heavier particles -
check the hose line from the base to inlet of the canister, there may be a blockage, like hair or plastic (i had a lego block and hair)
clear obstruction, and check the belt.
hope this works !
Jan 30, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Kenmore vacuum- no suction, brush wont turn
Sounds to me like you have a plugged vacuum. Check all the way through.
Jan 29, 2009 | Kenmore 22812 Bagged Canister Vacuum
Bissell 6594 PowerForce Bagless Upright Vacuum Logo
186 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
