Car is in Park and everything is locked up
Car ignition wont turn, everything is locked.
  • huneydew Jan 20, 2008
    I did this and it still wont , it is not on a hill, and the wheels are straight. Can only turn the wheels at a half inch intervals as the steering is locked as well.
  • 2,039 Answers
What kind of car. if our car is park on a hill or something like that stering turn. turn the stering wheel and try to turn ignition the pressusr of on the stering gonna prevent from turning ignition dont forget to rate this cheers
Posted on Jan 20, 2008
  • pierre laplante Jan 20, 2008
    if it not that to remove a ignition baril you have to put the kee on but sinse you can not move the kee you gonna have to drill the baril dont drill to fare the baril slid in a metal housing you should see a little hole drill to that hole when our there push in the hole the pin gonna go in you should be able to remove the baril that the way i do them cheers if any question im ear
I cant start the car the key wont turn in ignition
Last time i had this problem, my car wasnt all the way in park, so what i would try is:
1: apply the break
2: push up on the gear shift, to make sure its in park.( if you can move the gear out of park, move it all the way to drive 2, then back to park.
3: try the key again
Aug 01, 2016 | 1995-1996 Saab 900s Convertible Top Cover
I have a 2009 Kia Rio. When i put the key into the ignition it will not turn therefore the car will not start.
wiggle steering wheel up and down sometimes the steering lock tab jams and wont permit key to turn ====if key worn down will not let ignition cylinder turn other is bad ignition cylinder
Jul 30, 2016 | 2009 Kia Rio 1.6
Ignition switch will not engage/turn to start car
Hi Beth usually when shifter is stuck there is a locking mechanism and keeps shifter from engaging unless brake is depressed to release the lock. If you hear a clicking sound when pedal is depressed then switch is probably ok and its probably the steering wheel lock. First try with your spare key to start the vehicle(old key may be worn ). If that doesn't do it then try with WD 40 a very little in ignition key hole or on the key work it slowly and see what happens. If none of these suggestions work its probably the steering wheel lock and that requires surgery. Keep me post best of luck
Mar 27, 2014 | 1999 Toyota Avalon
The key is in the ignition and it is locked and will not turn. we have tried everything but the key wont turn on the car. the key does come out of the ignition but wont turn to start the car.
Your steering locks could be in a bind. Is your steering wheel turned to the side? Try moving the steering wheel while trying to turn the key. If this is not the case, then you most likely have either a worn-out key or a worn-out ignition lock cylinder assembly.
I would first try a different key if you have one. If there is not another key, I would take the Vehicle Identification Number (VIN) to the dealer along with proof of registration and picture ID, and have them cut a NEW key using the key codes for your vehicle. If this does not work, then you will probably have to replace the ignition lock cylinder assembly.
Jun 04, 2011 | 2002 Toyota Sequoia
The ignitioe will not turn out of the off position, the steering column will not lock and transmission shifter depresser button presses but will not move out of park.
SOUND LIKE IGNITION SWITCH KEYLOCK CYLINDER BROKEN. IN WHICH YOU CANT GET CAR OUT OF PARK.THE KEY LOCK CYLINDER BY TURNING THE KEY.IT MOVES A GEAR AND RACK ASSEMBLY THAT IN TURN MOVES THE IGNITION SWITCH ACTUATOR ROD AND PLUNGER TO VARIOUS POSITIONS REQUIRED FOR PERFORMING IGNITION SWITCH FUNCTIONS. IF KEYLOCK BROKEN YOU WONT BEABLE TO TURN IGNITION KEY OR GET CAR OUT OF PARK.
Mar 26, 2011 | 1999 Oldsmobile Alero
Can't turn the key , steering wheel turns so its not locking, i tryed just about everything and i don't want to break the key off. it acts like the car isn't seeing its in park. anyone help plz.
MAKE SURE YOUR CAR TRANSMISSION SHIFER IS ALL THE WAY IN PARK.ALSO TRY ANOTHER KEY.THE ONE KEY NOT WORKING COULD BE WORN OR SOMEWAY DAMAGED.IF ALL CHECK OUT GOOD YOUR IGNITION SWITCH LOCK CYLINER IS BROKEN.THIS IS A DEALERSHIP.BECAUSE THEY WILL HAVE TO REPLACE IGNITION SWITCH LOCK CYLINDER AND KEYS THEN THEY HAVE TO REPROGRAM CAR SO IT WILL CRANK.
Feb 23, 2010 | 1999 Oldsmobile Alero
Car ignition wont start or turn
Could be a bad lock cylinder or broken ignition switch (under the dash on top of the steering column). If you disconnect the switch from the control rod that comes from the cylinder and the cylinder turns you need a new switch.
Jun 17, 2009 | 2002 Cadillac Deville
Key lock cylinder won't come out....
cars have a lock position to protect the car from being stolen by theives. When we park the car with the wheels turned to the sides it gets locked in that position and the key can sometimes nbe hard to take out. Try moving the steering wheel in both directions as much as possible while pushing in the key and trying to jiggle it to turn. If you can get it out, the next time , park your car with the wheels facing forward. I hope this works.
Feb 06, 2009 | 1996 Toyota Corolla
Ignition wont turn key
thats something else, might be the ignition lock cylinder is bad, but if the switch turn and won't release park position, then it might be a fuse
Jun 29, 2008 | 1998 Chevrolet Malibu
Computers & Internet Logo
381 people viewed this question
Alun Cox
David Payne
David Payne
