Question about Microsoft Xbox 360 Controller
My right joystick on my controller has something wrong with it. this problem is not always appearing but it happens about half the time I play with it. Say im playing a FPS and I wish to use that right joystick to turn to the right. Well, the responsiveness at times is close to none. Say I keep holding the joystick in that direction then. The speed of which I am turning is fluctuating as if its having a hard time getting the signal from the joystick. Sometimes it will jolt back to full speed and suddenly move barely at all. I have no clue how to fix this problem or explain it any better.
    Problem Solver:
  • 12 Answers
Simple pull the right joystick up and then click it inwards and move it one full circle
Posted on Dec 23, 2009
SOURCE:
My Xbox one controller left joystick is always moving to the right.
sounds like the microswitch is stuck. The return spring won't help resolving this. more than likely replacing the controller will be your most efficient means to resolve the issue.
Oct 31, 2014 | Microsoft Xbox Video Game Consoles & Games
Changed batteries, now won't control power
It is possible you are using the wrong type of battery. A lot of electronics require you to use either Lithium-Ion or less powerful ones. I had this happen once by putting in batteries that were the right size, but were meant for more powerful devices. If you have a cheap set of the right size batteries laying around that are a different type, try those.
Dec 10, 2012 | Hitachi Clu-577tsi Remote Control
Dynamic Joystick Controller, all lights flashing 5 times then pause a little then again. Was working fine the day before. If I disconnect a wheel, then all lights flash 3 times then pause. Then again....
follow that joystick cable make sure it hasn't been pinched also i would make sure everything is connected ,you could have dis connected something on accident.
Jan 17, 2011 | Electric Health & Beauty
Joystick L keeps scrolling up and down..any idea why this is happening?
Yeah that always happens to me whilst playing cod. It's just thatthe joystick keeps getting stuck, when it happens just press it in a wobble it.
Sep 17, 2010 | Video Game Consoles & Games
Calibration Problem
I don't know what computer you are using and what operating system you have. But if it a PC, and you have Windows XP you can go into control panel and look under Game Controllers, it should list your joystick. Click Properties and then select the Settings Tab to calibrate your joystick.
Hope this helps.
Jul 01, 2010 | Logitech WingMan Extreme Digital 3D...
My psp joystick is broken. it is stuck down. when i play games, the person is always crouching or going down. and the highlighted section in the menu is always going down. I've looked for solutions on how...
The PSP of my son just so happen to have same problem as yours. Aside from the joystick, the 4 directional button (Up, Down, Left and Right) also controls the directions (hmmm... as the name implies). I was able to correct this by replacing the worn out FLEX PCB at the back of the directional button found just underneath the PSP casing. The trace of the Down Button on the PCB is already shorted to the ground which causes the signal to be always active even it is not pressed.
Oct 26, 2009 | Sony PlayStation Portable (PSP) Console
PS2 Controller Joystick Problem During Gameplay
If you've had the controller a long time weird things can start happenning. Usually the pads on the joysticks go first.
Try a different joystick(borrow a friends) and if it still happens you'll know its not the controller.Could be a glitch in the software of the game.
Eliminate each area. If a friend has the same game use their disc to try your controller with.
Take your controller to the video game store ask them to try it out on their game display models.If it's "busticated" you can buy a new one right away LOL.
Aug 03, 2009 | Sony PS2 Dual Shock 2 Controller...
When I bank right or left with joystick the screen Freezes
To check the joystick isn't the problem, go into control panel game controls, then check that the joystick appears and you can move the cross-hair around on screen, most modern joysticks are
auto-calibrating, but you could try running the calibration.
To check the game isn't a problem, unplug the joystick, then use the arrow keys to fly the plane, if it doesn't crash when you bank then it isn't the game.
I assume the game is Combat Flight Simulator 3, as very old games that were written for Windows 95,98,ME series often won't run on Windows NT,2000,XP,Vista as they are completely different versions of Windows. If this is actually Flight Simulator 3, you may need to consider buying a later version of Flight Simulator (FSX is the latest version, but may not run on your laptop).
Other things to try are updating the graphics card driver.
Norton shouldn't need deactivating, although it could cause problems if you're playing online.
Also remember that laptop graphics cards are never as powerful as desktop graphics, and games very rarely specifically support laptop graphics.
Hope this helps.
Jan 21, 2009 | Logitech Extreme 3D Pro Joystick
Left Joystick off
remove batteries. just one hold down buttons 6 & 8 reinstall battery this resets the analog sticks
Dec 19, 2007 | Logitech Rumblepad 2 Game Pad
Controllers freak out
Sounds like its time to buy a new controller, You could spend hours trouble shooting this one and for the price of a replacement its really not worth the time playing around with it and trying to repair it.
Sep 17, 2007 | Sony PlayStation 2 (PS2) Console
Microsoft Xbox 360 Controller Logo
218 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Nathan Hamilton
Nathan Hamilton
Paul Castley
Paul Castley
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
