Question about D-Link 802.11g Wireless Router WBR-1310 (WBR1310)
I want to connect wdr1310 to my desktop lan card
  • 1 more comment
  • David LeGrand Dec 13, 2009
    yes it is
    yes it is, the computer does not see it
  • Jaye Ellen Burke
    Jaye Ellen Burke May 11, 2010
    Is your modem's output going to the WAN connector on your router? Is your computer connected to one of the router's LAN ports to your desktop LAN?
  • 591 Answers
Did you complete the Wireless and Security sections of the router setup? This MUST be done in order to use the router wirelessly. First step is to set the SSID (Network Name) that appears on connected computers. The Security section helps insure access to only those with an access code, set in this same section. The Passcode has to be remembered, as it is the only way to access the router wirelessly.. If the Passcode is ever forgotten, is only reset by replacing with these very same steps. Please let me know what happens after these steps are completed.
Posted on Dec 14, 2009
HOW TO INSTALL DYNEX DESKTOP 10/100 MBPS PCI NETWORK CARD
Remove the case cover from your desktop computer.
Remove a cover strip from a PCI expansion slot.
Insert the Dynex network card into this PCI slot and secure it with a screw.
Replace the cover on the desktop computer.
Boot up the computer and when Windows has booted up then insert the Dynex installation CD into the CD drive then install the LAN driver.
Connect a LAN cable from the Dynex LAN card to your modem or router etc.
Mar 11, 2012 | Computers & Internet
Used to run wired desktop and wireless laptop off a Netgear DGN2000. No problems. Just changed the desktop for a new one. The laptop continues to work fine but can't get internet on new wired-in...
Check to see if the LAN card is enabled and working. If not install the LAN card driver.
If the LAN driver is working then go to Control Panel - Network Connections - right click on the LAN card then click on Properties, then check the TCP/IP settings of the LAN card, Tick Obtain an IP address automatically and tick Obtain an DNS server address automatically.
Then you will be able to connect to the Internet.
Jun 11, 2011 | NetGear DGN2000-100NAS Router
One of Intel DP55kg Motherboard desktop shows 100 mbps Lan connection when the other desktop shows 1gbps. why?
It depends upon the make and model of the LAN card. The one in the Intel may be a 10/100Mbps LAN card and the other one a 1Gbps LAN card.
You cannot make a 10/100Mbps LAN card run any faster than it was designed for.
May 11, 2011 | Intel DP55WG Motherboard
How do you connect to the internet on a sony pcv-120 since i dont see a ethernet plug in anywhere
It is possible that your desktop does not have a LAN card installed.
Go into the Control Panel - System - Hardware - Device Manager and click on Network Adapters and if there isn't a LAN adapter then there isn't one installed.
Then you need to purchase a LAN card and install it in your desktop computer.
Dec 21, 2010 | Sony VAIO PCV-J120 PC Desktop
Hi there, I am using Window xp on my desktop and window 7 on my laptop. Lan card on desktop is quantum lan card QHM8100R3D. Problem: I have Belkin F5D7234-4 Router and when i tried to connect...
Verify that you haven't manually set the IP address of the desktop machine to an IP address that conflicts with another device on your network.
If this is the case, change the network settings to use Automatic or DHCP IP address assignment.
If this doesn't fix the issue, I suggest trying a different network card than the QHM8100R3D to see if that addresses the issue.
Dec 20, 2010 | Belkin F5D7234-4 Router
My system not detecting the the LAN card after OS installation which is connected in pci slot of desktop board D845GVSR. But before OS installation LAN was working properly.
Since you have reinstalled the OS, while formatting the drivers for teh desktop card is also uninstalled.So please install the drivers for the LAN card again.
THANKS....
With Regards......
Vaishu
Sep 26, 2010 | Intel D845GVSR Motherboard
How to apply external lan card?
connect usb to rj45 external nic card in to the system install software from cd(one cd may be you received with external nic card)
Nov 14, 2009 | Dell OptiPlex GX280 PC Desktop
My internet provider says i need a lan card what is this? and how do i get it
You can buy Lan card at any computer store, just give them the spacification of your computer and model, they will give you the Lan card compatible to your computer.
Lan card is a board that you will attach to *********** board, it have an connector for you lan cable so that you can connect to a modem to connect to the internet.
Nov 04, 2009 | Dell Computers & Internet
When modem is conected through router computer not recognizing internet connection. with or without modem bridged
Go to Control Panel -> Network connections make sure the Local Area connection is enable. if this working fine then replace you LAN card. LAN card is connected to the PCI slot of the motherboard. And install drivers for your LAN card. Thank you
Sep 06, 2008 | Computers & Internet
Belkin mimo G network card
I think in your Pc Wireless lancard is disable,Pls enable the wireless lancard,
1. just check the lan card is enbled
example:my network place --right click---properties---wireless lan card,
2. check the R u getting ip address,
example: start---run---cmd----ipconfig
May 20, 2008 | Belkin Dual-Band Wireless A+G Desktop...
D-Link 802.11g Wireless Router WBR-1310 (WBR1310) Logo
76 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
