Question about Kenmore Dryers
I have a Kenmore dryer part#857184 There nis power
I have a Kenmore dryer part#857184 There is power to it but suddenly when I set the timer and pushed the start button it will not start. It worked fine a about 4 hours ago.This is a front load dryer electric.
  • 4 more comments
  • billschess Dec 13, 2009
    The circuit breaker is fine and the part you discribed seems to be ok. When I open the door the light comes on and when I shut the door I push start and nothing.
    I already have that cover off and the wires seem to be tight. I will try what you said but what is a "Jim-Clip"?
    here is a photo of the wires in front behind the door inside. I attached 2 photos hope they help. Please let me know if they came through because I need to know where to put the paper-clip.
    Oh and burnt wire smell
    Are you still online? I just got back from airport picking up my wife. Sorry for the delay. Photos can only be 1.50 mb so I need to see if I can compress it. No I have not found what the problem is and I need a bit more instruction as to which wire I nees to disconnect and use a paper clip on. I will send you phot tomorrow if you will be online.
  • billschess Dec 14, 2009
    I just got rid of the dryer and picked up a refurbashed one at flea market. Problem solved and thanks for your help!
  • 2,418 Answers
Check on the door for a small part that sticks out, this part goes into a door switch to tell the timer the door is closed, and lets the drier start up. Do not forget to check any circuit breakers in the control panel of the house, see if one is off.
Posted on Dec 13, 2009
  • 5 more comments
  • John Fourteen Six Dec 13, 2009
    I would try to open the top and check that switch for loose wires. Most Kenmore's open from the front. Pull up on the top at the front corners, the top is secured by metal taps that flex into an opening in the top frame. It may be a little hard at first to break the tension but it should come up and you can look down inside the front for the switch and the wires. If the wires are in place you can try to bypass it with a jim-clip. Unplug it first from the wall, and then unplug the switch to bypass it with your jim-clip, cover the bare part with tape, just plug it up and push the start button to check it see if that is the problem.
    Paper clip. Do you smell any burnt wiring?
    I do not have the pictures yet, if you can pull the wires off the switch, there should be two, and hook these two wires together with the clip or a another short wire you stick inside the ends that plug onto the switch.
    If this does not start the drier, The next part to check is the start button, do the same to it with the clip but it is a momentary touch. You will have to just touch the wiring together for a moment just like when you start it. Be sure to unplug the drier to access these wires and see if you can practice touching them together without touching any bare metal or any part of the wires. You can put some tape on the clip so you can hold it, sometimes the wire ends stick out of the covers enough to touch them together. These wires are in the top panel and the back should come off to access.
    Still no pictures yet. What have you found? Anything?
    am 12/13/09 I will be online off and on today, busy day for me. The idea here is to by-pass the door switch by hooking the 2 wires together, pulling the wires off the switch and making contact through the paper clip stuck in the wire ends. Then doing the same to the start button but remember it is a momentary connection just a touch to make the start relay contact.
  • John Fourteen Six Dec 14, 2009
    Back on for a bit. Have you had a chance to check it out?
  • Kenmore Master
  • 19,396 Answers
Hi.
As a first thing check the thermal fuse. The thermal fuse is located at the back side of the dryer.
The fuse can be tested using a multimeter set on Ohms. If the multimeter stay on infinite, then the fuse has blown, if there is low impedance or zero, then the fuse is Ok.
To get parts and diagram enter the full model number on website below:
Parts & Accessories
  • Ginko
    Ginko Dec 13, 2009
    I have read the rest of the comments. The staple method to jumpwire the door lock wiring is greatly unsafe.
    If there is a wiring problem , it must be troubleshoot using multimeter and proper procedures.
    A door lock lock switch can be tested reading impedance to find out if the micro switch is opening and closing.
    If you have not done this kind of repair before, better calling the number listed on the owners manual to get a quote on support. A badly repaired appliance can endanger your life.
Kenmore dryer model 110 does not stop during automatic cycle
Make sure the small orange wire is connected to the 250 limit at the base of the heater assy. That is what powers the motor on auto cycle.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 27, 2013 | Kenmore Dryers
Kenmore dryer stopped working, still has power.
When the timer stops during the duration of the time set the timers cogged tooth gearing has stripped out. A new timer will be needed to get your dryer working again
Apr 07, 2010 | Dryers
Have a kenmore series 70 dryer. Won't shut off
Yes it deffinetley sounds like you may have a timer issue, if your timer stops and the dryer is running, or if the timer keeps going around and around this will be the problem, however there are thermostats inside the dryer and if you have it set on a HEAT and not a TIMED setting the thermostats won't advance the timer because they havent been set.Hope this helps
Thanks.
Nov 22, 2009 | Kenmore Dryers
Dryer works but timer won't move; therefore I have to set my own timer and remember to check the clothes.
There is really no fix to the timer. You will have to replace it. I suggest using www.repairclinic.com . You can buy this item at a cheaper rate than a service call. Always remember to disconnect power prior to changing out parts. Good luck.
Apr 18, 2009 | Kenmore 62602 Electric Dryer
Kenmore dryer dial doesn't advance
That looks like a thermal shut off to protect the dryer if it overheats.
I am assuming that the timer never advances - even in timed mode (as opposed to some automatic drying setting).
Most likely you need to buy an inexpensive multimeter and start testing. There should be a schematic on the back of the dryer either on the outside or on the inside of the back panel.
Since timers on dryers are just mechanical devices that use a small motor (and yours is brand new), it looks like your timer is not getting power. The switch itself is mechanical, you should be able to rotate it to the different settings, press the start button and the dryer will work in the correct mode. Without electricity, the timer won't advance.
Check for loose or burned connections. Dryers use a lot of amperage so occasionally the wires can get burnt and corroded.
Sep 19, 2008 | Kenmore 62602 Electric Dryer
Electric dryer wont heat or turn off
there could be a temperature switch that tripps off. look at the diagram and trace also the power to the timer motor. it seems that you lost your power to your timer motor that is why the timer stays @ what ever setting you set it.
Feb 11, 2008 | Kenmore 63942 Dryer
No heat, timer not advancing
If the timer advances in timed cycle but not automatic, you have a bad heater thermostat.
Apr 10, 2007 | Kenmore 62622 Electric Dryer
No heat,,timer not advancing
Check with a multi-meter for power on THE heating element's tags (115/220V). If it does get power, you should replace the heating element. In case of no power- you should replace the thermostat. Good luck!
Dryers Logo
63 people viewed this question
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
