Question about Indesit W 123 Front Load Washer
MY WASHER MAKES A HUMMING NOISE 3/4 OF THE WAY THROUGH EVERY CYCLE
CAN ANY 1 HELP PLZ....my washer is making a really loud humming noise. and it does this every wash 3/4 of the way through the cycle it doesnt matter what cycle either... this washer is still under warranty had washer guy out ..but he could only stop 15 mins..it didnt make the noise..as he wasnt here long enough grrr...but the more washers it does the louder the humming noise..apart from this my machine is working spot on... or yeah had to do the reset twice now since its started the noise...all i want is peace some 1 plz..fed up of getting fobbed of with repair guys now..
  • sofunny Jan 25, 2008
    hi. ive had it since october 2007 and its still under warranty from the 12 months guarantee...its was okay the first month..then its started and got worse.. an average i use the machine 3 times a day...any help or advise i will appreciate thanks....
  • sofunny Jan 30, 2008
    Hi thanks for your replys so quick..its i might have posted my question in the wrong part i think..i have a indesit WIL 163 washing maching and couldnt find no off dot postion to try and reset it like you said...
    Problem Solver:
  • 9 Answers
Sounds like motor brushes worn
how old and how much use has it had?
Posted on Jan 22, 2008
  • rjrules71 Jan 26, 2008
    could be a relay problem
    when you have to do a reset does it give an error message if so write it down and tell the repair man he should be able to track the fault from that
    al indesit washer have a reset pattern
    switch of with on/off button
    turn selector to a large 'off dot' position
    wait a couple of mins then switch back on
    wait 2 mins
    then switch off again and turn selector to a cycle start position
    wait 2 mins turn back on and let it run the FULL cycle do not mess it about.
    Sometimes it takes 2 or3 attempts so be patient
    If there is a fault it will appear again within the cycle and give you an error code eg E7/E1 etc note this and call a repair man he will track it from this code.
Frigidaire washer makes a very loud humming noise on spin cycle.
Good Morning Larry Looney, thank you for your post!
I understand that your Frigidaire frontload washer is making a humming noise while in spin cycle. This could be a potential problem with your motor or drum bearing. In order to find the proper cause of the humming noise I would highly recommend having a professional technician come out to your home for diagnosis and repair. This will help to avoid any unnecessary part purchases as well as any future issues. -Matt
Nov 14, 2014 | Frigidaire ATF6000ES Front Load Washer
Frigidaire affinity front load washer
If the unit will not spin at all and makes a humming noise, sounds like something has seized up in the back of the unit. This could be a belt broken, motor seized up, or the transmission, if your unit has one, is gone.
Jul 17, 2012 | Frigidaire ATF6000ES Front Load Washer
My Frigidaire Affinity washer stopped working. When i start the cycle it makes a loud humming noise, but no water goes in, and it starts spinning for a few minutes, then the time goes from 1hr, to 3 m
Possible that the inlet valve is faulty. please measure the voltage on the inlet when the washer is switched on , if there is no voltage then the controller is faulty. If voltage is present then the inlet valve has failed.
Jun 05, 2012 | Frigidaire Affinity ATF7000E Front Load...
Make a humming noise and spins very slowly
MINE DOES THE SAME. HOUSING IS CRACKED THAT ATTATCHES TO DRUM. WHITE METAL CANNOT BE REPAIRED.
Jul 25, 2010 | GE WPXH214A Front Load Washer
Kenmore Washer makes loud noise when draining
check and clean the pump. possible coins in it
Feb 07, 2010 | Washing Machines
On spin cycle makes hum and will not spin. I even emptyed it and it will spin but still makes a loud humming noise.
You have a loose or VERY warn drive belt.
If you can have someone place the washer on its front/face and inspect the drive belt, I am sure that you will see what I am saying.
The solution will be one of 2 things...
1. Find the tension control and repair/replace it
2. Replace the belt.
-Jim
Nov 05, 2009 | Frigidaire ATF6000ES Front Load Washer
Loud humming noise when dishwasher is filling up with water
your model is pretty new. just so you know your warrenty is 1 year parts and labor. 2 years on parts. it should not cost that much money.
there are two components that start before the circulation pump.(wash noise you hear)
first sounds you hear will be the drain pump. usually rattling noises if something is in it but it can make a hum noise if something is jamming the drain propeller up. which is accessible with a T20 torx driver. take the filters out and the mesh filter. and unscrew the screw in the base towards the left. pull out whatever is lodged.
the other humming sound can come from the next component that activates is the watervalve. make sure you dont have a kinked water intake line. otherwise its a bad valve. i have had to change a few of those water valves out already but not for a hum noise on your model. you have a new style water valve. when brands make new parts we get problems fast sometimes..
Feb 14, 2009 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Maytag Netune Mah4000AWW
Makes a loud humming noise. Does the machine go thru its cycles ? Is the humm ther all the time ?
Jan 06, 2008 | Maytag MAH6500 Neptune Front Loading...
Indesit W 123 Front Load Washer Logo
369 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
