Question about Dell Inspiron XPS M140 Notebook
The dell logo flashes then the screen goes blank. The hard drive keep flashing like the laptop is booting up okay it is a xps m140 and has vista home as a o/s
    Brigadier General:
  • 10,406 Answers
After the logo flashes, press F8, repeatedly, until a white-over-black "boot menu" is displayed. Choose "Safe Mode", to see if this "minimal" version of Windows will startup successfully.
Posted on Dec 13, 2009
Dell laptop w/ Vista - will post but then freeze up
Do you see the hard drive listed in the BIOS?
If not, probably a hard drive issue - but strange you can't boot from a CD.
Did you reset the BIOS to defaults? If it is a BIOS issue, you could try and flash it to a newer one (if it exists) but if it goes wrong you could brick your computer.
I had a failing hard drive in a laptop which would not boot up. I bought one of those converter things (laptop IDE to full IDE) so I could hook it up to my desktop pc as a slave. I was able to access all the data and transfer it to the new hard drive in the laptop. If you have a SATA connection on the laptop hard drive and your other computer then I don't think an adapter would be needed.
Mar 01, 2010 | Dell Studio 17 Laptop
Dead screen on an xps m140. How can I figure out why it won't work? The computer boots up and can be attached to an external monitor. But when I boot up without the monitor the laptop screen is a blank...
Take a flask light and hold it at an angle toward the screen. See if you can see the desktop in the background. If you can your inverter needs to be replaced. The inverter is a small circuit board that lights the screen, much like the balast in a flourescent light.
Dec 05, 2009 | Dell Inspiron XPS M140 Notebook
Dell xps m140 screen goes blank
More like the back light has burned out on the LCD. Not an expensive fix, but time consuming. Almost easier to put in a new LCD (about $60us on Ebay), and is something you can do yourself.
Mar 20, 2009 | Dell Inspiron XPS M140 Notebook
2007 DELL XPS M140 LAPTOP WILL LOCK DUE TO 256M MEMORY STICK
Normally you boot up the laptop without a memory stick in the USB port.
Check your BIOS settings for the boot up device order.
You should have the hard drive as the first boot device, you can have the CD as the first boot device and the hard drive as the second boot device.
You should not have the USB port as the first boot device.
Feb 02, 2009 | Dell Inspiron XPS M140 Notebook
Dell XPS M140 laptop shuts off after powering on
Most laptops that I have worked on that power off that quickly turned out to be an overheating problem. Is the cooling fan running for the brief period that you can hear the hard drive before it powers off ? If the fan is running another potential resolution might be to remove the processor and apply new thermal paste.
Nov 10, 2008 | Dell Inspiron XPS M140 Notebook
XPS 600 BIOS setup problem
light 1&2 is a memory configuration error.make sure you have the memory in correctly
Sep 06, 2008 | Dell XPS™ 600 PC Desktop
Hi dell inspiron m140
What was the reason for the fix?
Have you replaced anything?
How are you trying to do the fix exactly?
What is it doinfg exactly during the operation, any noise, lights flashing, error codes, anything?
Aug 20, 2008 | Dell Inspiron XPS M140 Notebook
Dell XPS M140 Very Slow In Booting Up and General Use
Run a check disc, or hard drive test in the bios, if any part of the test fails, then the hard drive is failing and will need replaced. Delete anything from the start up section of the start menu/programs, and download and run CCleaner form filehippo.com, it will help keep your computer clean and running fast/smoother. Also, are you using Norton? If so, remove it and use the AVG. You can find it at File Hippo as well.
Aug 16, 2008 | Dell Inspiron XPS M140 Notebook
Dell Inspiron XPS M140 Notebook Logo
172 people viewed this question
Alun Cox
