Question about Fisher and Paykel Washing Machines
Model gw611 where do you find the pump - Fisher and Paykel Washing Machines
  • 86 Answers
The pump is located under the machine,Look for the plastic fan.Also to remove it is easy.Unplug the the earth and power plugs,And there is a plastic lock that has to be held out while turning the pump anti clockwise and it will drop out.Hope this helps.
Posted on Dec 13, 2009
I have fisher paykel GW611 making a terrible squeaking sound when washing. It seems to be coming from under the white plastic fan like thing under the machine. Need help to get it off Thanks
Go to www.repairclinic.com and enter GW611. You will see a list of common replacement parts and may be able to view a video showing disassembly of a generic F & P washing machine.
Aug 01, 2016 | Fisher and Paykel Washing Machines
FP Model GW611 Washing Machine intermittent & slow water flow into bowl then machine times out or errors. Removed inlet flow restrictors, fan on pump turns freely?
valves are wearing out and need to be replaced. they are located behind the top board where the hoses plug in. turn off water when removing valve tops!
Aug 19, 2013 | Fisher and Paykel GWL11 Top Load Washer
Fisher & Paykel GW611 Excellence does not pump water out. All lights are on and when it is suppose to pump, you can hear the noise, but no water coming out of the hose!
It sounds like the drain pump or the diverter valve is restricted. Check to make sure that the drain hose is clear then disconnect power and lay the machine's front on a padded surface to access the drain pump and the diverter valve at the bottom of the tub. Remove the pump's inlet and outlet hoses then check and clear from any debris that may prevent water from draining out. Check the impeller for any damage or restriction.
Check the diverter valve for the same condition as the pump described above. T
he diverter valve is where the drain pump and the recirculation pump inlet hoses are attached from. Make sure the valve is in the drain position while the drain pump is working. Replace the drain pump and/or the diverter valve if deemed necessary.
Jul 18, 2011 | Fisher and Paykel Fisher & Paykel Washer
I have lost my instruction manual. It is Fisher & Paykel model GW611 I want to know how to turn off favorites and reprogram it in again
From what I can tell, GW611 is an Ecosmart:
http://www.fisherpaykel.com//admin/pdfs//pdf_usecares/420653_US_Ecosmart_UC.pdf
There are a few different Ecosmart manuals on the Fisher & Paykel website, so you might be able to find one that matches the button shapes you have. They all seem to have the same Favorite instructions:
To set your Favorite Cycle
1. Press the POWER Button.
2. Press the FAVORITE cycle button. Hold down for 4 seconds until you hear two quick beeps and the Favorite light flashes.
3. Select your favorite cycle (eg Regular or Delicate).
4. Select the wash options (eg soak, time saver). Use Advance if you want part of a cycle (eg spin only).
5. Press FAVORITE again to store your favorite cycle.
Note: Your Ecosmart will remember your favorite cycle, or any other cycle that has been customized, even when unplugged from the wall. It is not possible to program a delayed start into the Favorite cycle.
http://www.fisherpaykel.com/customercare/userguide/index.cfm
Jul 16, 2011 | Fisher and Paykel Washing Machines
Model GW611 the first and second last led flashes. fills up and wont go into wash cycle
If by first led you mean green to the left & amber to the right then that is fault code (130) & i think it is (Rotor Position Sensor) If you meant first to the right that would be red & green, code 65.no that doesn't sound right.its 130 & im sure thats rotor sensor.
May 25, 2010 | Fisher and Paykel Washing Machines
It is a GW611 excellence model.It will not go past rinse cycle on
I spoke to a person yesterday that has a next door neighbour that does washing machine repairs and he is going to look at it so i can let you know what the outcome is if you want to know.Thanks Peter.
Dec 12, 2009 | Fisher and Paykel Washing Machines
Washing Machines Logo
205 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Charles T Nevin
Charles T Nevin
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
