Question about Samsung RS2630SH Side by Side Refrigerator
What is the loud rattling noise. For the last several months we have had a loud rattle coming from the rear and bottom part of the refrigeratory. Help us understand what we can try to fix this problem.
    President:
  • 1,515 Answers
Hello, I will try and guide you to find a solution to this noise. If you are willing and able,roll out this unit to excess the lower panel. Behind this will be the compressor, condenser, and condenser fan motor. Check to see if this fan and motor are the source of the noise. Maybe bearings, blade hitting the panel, something may have been sucked up in the fan making noise, ect.Clean the front of this coil while you are in there searching, to keep the pressures in the system at normal temperatures. You can use a brush to clean. I am confident you will find the source in this area, and resolve this noise. The unit is operating good? If so that is a good sign it is not a serious problem. Please keep me posted on what you have found and I will be here if you require my help. Sincerely,
Shastalaker7
Posted on Dec 13, 2009
2006 gs300 rear rattles
Bet the "mechanic" didn't check the exhaust system hangers.
Jul 25, 2017 | 2003 Lexus Gs 300
'02 Yamaha XJR1300 Rattle/vibrating noise from bottom of engine
how do you adjust the headlight beam on a xjr1300 naked 2002 bike, is it as simple as undoing the 2 bracket bolts at the sides of the lights and re-setting the lights to a new level ??
currently it seems to be set for riding with a pillion passanger or heavy load at the rear as the lights are set low, no one flashes me even if i ride at night with full beam on !
thanks xjr cambs
Apr 18, 2010 | 2002 Yamaha XJR 1300
Water leaking and loud noise and rattling on final spin cycle
Turn the drum by hand and if you hear any noises it is the rear bearing. If there is no noise then remove the front bottom panel and take out the coin trap on the pump and check those hoses.
Eric
Aug 27, 2009 | Whirlpool GHW9150 Front Load Washer
My new Kenmore window unit 76081 makes loud rattle
If it does not make the noise when the fan is ruunin you may ahve abroken sping in the compressor. Make sure you Window unit is level. If not the compressor will knock on the inside. Rusty
Jun 12, 2009 | Kenmore 76081 Wall/Window Air Conditioner
Loud clunking noise when i turn a corner both sides rear
check the sway bar kinks for play both rear wheels will have to even ramps work good if you have them if the is any play in the links it wil rattle also check for play in the bushings that the bar goes threw tis will also give you the noise you complain of
May 28, 2009 | 1998 Lincoln Town Car
Making a rattling noise when i step on the gas.
several things could be wrong are you using 91 octane fuel or less? also it might be a timing issue you might be too far advanced in timing ... this causes preignition.. causing a rattle also cheaper fuel will do the same effect.. thanks Jerry holler if you need more.. also was the noise loud or just a mild noise ??
Apr 27, 2009 | 2002 Jaguar X-Type
Loud noise from 99 Honda Accord
is your ac compressor located on the left side as well and also try your ac if its not blowing to cold the rattling could be your ac clutch on the compressor if that is you will have to get a new clutch kit from your local auto parts store to fix it
Mar 16, 2009 | 1999 Honda Accord
Raddle when go over bumps
If Jay's tips don't pan out, consider having your shocks checked since these can produce a loud rattle if the seals are blown.
A preliminary check can be made using the 'bounce' test. Pressing down and letting up on a fender several times in succession until the car is bobbing good. When you let go on a downstroke, the car should come up once, settle and move no more. If it kind of fades, with several shorter bounces, the shock is bad.
Dec 16, 2008 | 2000 Lincoln Continental
Samsung RS2630SH Side by Side Refrigerator Logo
408 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
