Question about D-Link AirPlus DI-524 Wireless Router
Weak signal my signal always says the signal is strong but it only produces 5.5 mbs which makes all the other wireless devices super slow. I constantly restart the device but that doesnt work. What do you suggest?
    Brigadier General:
  • 10,406 Answers
Where are you measuring the speed:
* transferring files from one computer on your network
to another computer on your network?
* using a "speed-test" web-site (http://speedtest.shaw.ca) that reports the speed?
What level of service are you paying your ISP for? "Lite"? "High-Speed"? "Extreme" ? "Nitro" ?
The "bottleneck" could be between your ISP and your router,
not between your router and your computer.
Posted on Dec 13, 2009
Why does my tablet keep saying authentication problem when trying to connect to wifi
Had same problem - said signal weak although strong on other devices, and hung on authenticating.
Cordless phone on base unit was beside wireless router. Moved unit and turned off phone. Problem disappeared, and signal showed strong.
Dec 30, 2012 | Archos Arnova 10 4GB 4)
The signal from my router to my Samsung blu ray is not strong enough
There are several things you need to consider with wireless connection:
Distance - How far is the Netgear router from the Samsung Blu ray? Try changing the wireless channel on the Netgear router that can help boost the signal. Wireless Security- Have you enabled wireless security on the router? Is it WEP or WPA? Make sure that you input the wireless security key on the Blu Ray player and that you have setup wireless settings correctly.Number of wireless devices - Check the number of wireless devices(laptops, desktops, pda's, etc) connecting to the router as it also weakens the signal. And if wireless security is not enabled on your Netgear router, there's a chance that your neighbor might be connecting to your router via wireless.
You can also test how strong the signal is by placing a wireless laptop on the same location where the blu ray player is. If the laptop gets a weak signal as well, you can try placing the router closer to the blu ray player.
Oct 24, 2011 | NetGear WNR2000 Wireless Router
I have charter internet speed of 25 mbs going through my router...and I can wirelessly get that speed or greater on my pc....However my Netgear powerline adapter XET1001 85mbs (which is connected to the...
Powerline data transition speed can be effected by many things. Distance, equipment producing electrical noise on the power lines, being on separate circuits, or even running though power filters or surge protectors can cause slow or failed connection.
Make sure the adapters are connected directly into the wall, remove any electrically noisy equipment on the circuit between the adapters, and try to make sure the adapters are on the same electrical circuit. These things should help.
Jan 11, 2018 | NetGear XE102 Powerline Ethernet Adapter...
My wireless network doesn't have a strong signal
mcdevito75 here, Your wireless as all wireless depnds on Satalight position, depending on where you live, the signal could be weak at times. Just as your signing on to connect your wireless to the internet, click on up-dates. You can also contact your wireless provider (maker of your wireless) for additional info. Hope this helps.
Jul 17, 2010 | D-Link DI 514 Wireless Router (DI-514)
WHEN ON PLAYSTATION LIVE AND MY DAD IS ON HIS LAP TOP WIRELESS THE SIGNAL IS VERY WEAK THE PLAYSTATION WIRELESS
When more than one thing is using a wireless router, it has to do twice the work, slows down, or even overheats or shuts down. I strongly suggest you only use one at a time, for the sake of your router.
Nov 24, 2009 | Sony Playstation 3 (PS3) Console
My d-link router isn't producing a strong enough internet signal
I've had two d-link routers 'go off' this way. Ended up replacing them.
Oct 02, 2009 | D-Link (DI-784) Wireless Router
Weak signal 60 feet away at neigbhoor's
Some routers just don't put out strong signals. The problems could be wiring in/around/at your house or neighbors....causing weak signal. Are the signal strengths strong in your house?
We have super signal strength on ours upstairs (we have a bi-level house) but downstairs the signal is very low. All the wiring in the house and anything electronic or otherwise can block it.
Hope this helps at least some. Good luck!
Jul 30, 2009 | D-Link DIR-625 (790069292637) Wireless...
My Linksys network adapter is very slow to connect
Ask them to review you connection speed to make sure your getting the speed you ordered. Linksys is usually pretty good. See if it's faster WITHOUT using the wireless (plug directly into the modem). If it is I can only think of two things... Ether you need to relocate your wireless modem to acheive a stronger signal OR if your signal is strong on your adapters end, you could always upgrade to a different wireless adapter that can handle faster conections.
Jun 27, 2009 | 2wire (1000-400108-001) Router
Slow speed tests
Your HP G60 has an 802.11 b/g card. 802.11g has a maximum rated speed of 54 mbps, like the router. You never get the actual "rated" speed with wireless cards, this would occur only with maximum signal strength, no network protocol overhead, no security, etc. if you were to replace your current card in the Satellite with an 802.11 b/g card, you would get comparable results.
Jan 15, 2009 | Intel PRO/Wireless 2100 MiniPCI 802.11b
Wireless signal is very weak
Signal strength is varies depend on your position,
Hardware type, wireless provider line-of-sight (how
many obstacles that blocking the signal), and other
factors.
Make sure you connect to the same wireless spot.
Or at least go to places with wireless spots and compare
signal strength.
If you never have a strong signal from at least 5 different spots
(make sure you check it's the top 5 best spots you find,
ask others who connect to the spot also to make sure)
then you go to your repair shop and ask them why.
But, if you at least have 1 strong signal then
your spot just having a weak transmission.
Dec 26, 2008 | Dell Inspiron 2200 Notebook
D-Link AirPlus DI-524 Wireless Router Logo
211 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
