Question about Dryers
Installed new motor. Now runs counter clockwise...wrong direction. How to correct? Thanks
  • 115 Answers
Did you replace the motor? if so reverse the leads you have them switched around
Posted on Dec 13, 2009
What direction should ice auger run mine runs counter clock wise
Most ICE augers rotate counter clockwise. There are a few that don't but they tend to based on EARTH drilling augers which generally rotate Clockwise.
Jan 16, 2018 | Refrigerators
New Beko DRVS73W tumble dryer drum only moves in one direction and makes terrible noise
check the belt that goes around the drum to be correctly mounted at the motor area also inspect the rollers that hold and turn the drum
Aug 27, 2014 | Beko DRVS73W Vented Tumble Dryer - White
What direction does a waterway hot tub motor turn
The only way a motor will run backwards is if the motor gets wired wrong.
all motors turn clockwise.
Rod
US Parts Center
888-521-6183
Jan 03, 2013 | Pool & Spa
Faucet handle turns wrong way
You bought two cold water faucets. The threads are reverse on the hot water faucet. Exchange the wrong one at the store you bought it from.
Dec 31, 2012 | Moen Plumbing
Goodman heatpump model cpke30-18 installed new in 1997. just replaced the condenser motor. new fan runs cloclwise but the fan blade is for counter clockwise. it is blowing down not up. part house said...
Does your new motor have two sets of short wires with connectors in the middle of them? If so then it is reversible and the instructions for doing so are printed on the motor data plate on the side of the motor.If it does not have these wires then reverse the polarity of the two power leads as they come off the top of the contactor, that should fix your problem.
Jun 23, 2011 | Heating & Cooling
I purchased a Wilton 6 in grinder, model 17203. It spins in a counter clockwise direction. Is this normal? In other words the wheel is turning down on the material being worked. Thanks Jim Price
Counter-clockwise as viewed from which end? The correct direction as viewed from the right end would be counter-clockwise. As viewed from the left end it would be clockwise. In other words, when using the grinder from the front, the surface of both wheels should be going down. If this is not the direction it turns, take it back. Good luck, Al K
Feb 02, 2011 | Wilton 17202 8" Bench Grinder
3 phase air compressor wrong rotation
yes it will you need to make sure you have the proper wires connected to get either clockwise or counter-clockwise rotation.
try changing the hot wires around to correct your problem
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Mar 31, 2010 | Air Tools & Compressors
Correct rotation of copressor
Checked all the IR compressors in stock and all turn counter-clockwise facing pulley, however you could check the pump for fan angle on pulley. The fan on the compressor pulley blows air towards the pump. Generally, pumps turn CC because that would allow for the use of gasoline engines which all turn CC. Please email you questions, and Good Luck.
Jan 27, 2009 | Ingersoll Rand 2340/2475 Electric Air...
Open Questions:
Dryers Logo
29 people viewed this question
Top Dryers Experts
Marvin
Marvin
