Question about McCulloch Garden
How long should fuel line from from primer too fuel tank be on a mcculluoch 3200 chainsaw
dontbother10
  • 2220 Answers
SOURCE: I have a McCulloch 3200 chainsaw on which I
From the fuel tank to the carb, from the carb to the primer, from the primer back to the fuel tank. The bulb sucks fuel through the carb excess fuel is returned to the tank. HTH
Lou
Posted on Oct 08, 2009
  • 48 Answers
SOURCE: changed fuel lines
No the primer bulb is connected via the carb generally by a clear plastic line without a filter if it isn't mounted directly to the side of the carb that is.
Posted on Apr 14, 2010
SOURCE: McCulloch,Mac 3200 Chainsaw fuel lines...........
retgmdI need the same, did you ever find one?
Posted on May 27, 2010
aquaman987
  • 927 Answers
SOURCE: how to replace the fuel primer bulb and fuel lines
I just did a primer bulb not too long ago, but I don't remember what equipment it was on. They are generally easy to replace. First, remove anything that is retaining the bulb assembly, such as cover plate. On my Homelite chainsaw, I simply pried it out with a small screwdriver.
The replacement part itself has two barbed stubs that the two fuel line hoses push onto.
Make sure that you keep the fuel line tubes above the fuel level at all times to prevent leakage.
Posted on Dec 05, 2010
  • 6468 Answers
SOURCE: poulan pro 16 inch chainsaw no fuel in primer
did you forget to install the filter on the hose?
Posted on Aug 30, 2012
ALL FUEL LINES
The bulbs on chainsaws are not primers, they are purges so they pull fuel from the carb into the bulb and back to tank, the short connector is the suction side so goes to the carn, the longer connector is the pressure side so goes back to the tank.
Oct 08, 2017 | McCulloch Garden
Changed fuel lines
Apr 12, 2010 | Garden
I have a poulan 2150 chainsaw. I replaced the
Fuel Line Replacement by SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
  • The hose in the tank with the filter on the free end connects directly to the carburetor input connection.
  • If the saw is equipped with a primer, the output line from the carburetor connects to the suction side of the primer bulb (once bulb is collapsed it draws fuel from the tank through the carburetor to refill the bulb as the bulb refills).
  • The pressure side of the primer returns any excess fuel to the tank as it is depressed.
HTH
Lou
Oct 25, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
My McCulloch chainsaw 3200 internal fuel line in
Try your friendly neighborhood chainsaw seller/mechanic. Take a piece of the old hose with you.
SmallEng.com
Routing runs from fuel tank to carburetor, (if equipped) through carburetor to primer bulb, bulb returns excess to fuel tank.
Oct 13, 2009 | Garden
I have a McCulloch 3200 chainsaw on which I installed a new primer bulb and fuel lines. The old fuel lines were broken. I figured out which line runs to the carb from the primer bulb but where does the...
Lou
Oct 08, 2009 | McCulloch Garden
Config of gas lined Mc Callogh chiansaw 3200
What little fuel system detail there is can be found here:
IPL (Chinese Mac, exploded parts list)
https://www.dixiesales.com/ipl/327/Chainsaws_32cc-35cc.pdf
SmallEng.com
Routing runs from fuel tank to carburetor, (if equipped) through carburetor to primer bulb, bulb returns excess to fuel tank. HTH
Lou
Oct 07, 2009 | Garden
Aug 23, 2009 | McCulloch Garden
Poulan 2150 type3 / a show me diagran of fuel line hook up from primer bulb to carburator
I have a McCulloch 3200 chainsaw with a cracked primer bulb and all the fuel lines were gone. I cannot locate any information on routing these lines to the carb. I have a new primer bulb and 3/32x3/16" fuel line. Please help me solve this problem.
Aug 16, 2009 | Poulan Garden
McCulloch Chainsaw carb not getting fuel
This is the same problem I have with a Mac 3200. I have: (1) A line from the primer bulb to the front port on the carburator. (2) line from fuel tank, with attached fuel filter, to the other primer bulb port. (3) Line from port on back of carb. to ????. I thought it must be a pulse line, but not certain, and don't know where to run it to. Please let me know when you find out.
Aug 13, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Fuel hose routing problem on a Mac 3200 Chainsaw
This post helped me with my McCulloch Mac 3216 chainsaw. There are two holes in the gas tank - one above the other. One is for the gas line (with the filter on the end) and the other is for the overflow - a simply line that runs from the "out" nipple on the primer bulb into the gas tank. The filtered fuel line goes to the nipple on the back of the carb. Another short line goes from the "in" nipple on the primer bulb to the nipple on the front of the carb.
There are two notches just out from the two holes in the gas tank for holding the lines that go in -- this may help you locate the holes.
I found it helpful to pull the lines that go into the gas tank out through the gas cap hole and leave them hanging out until the housing was reassembled. I also left the lines that plug into the primer bulb hanging out through the hole where the bulb goes until the housing was put back on. Leave plenty of extra line for the lines going out to the primer bulb. Once the housing is in place, cut the lines to the primer bulb and attach them, and slip the lines into the tank, making sure the ends are as far down in the tank as possible. You will need this extra "slack" to work with the housing to get it back on.
May 30, 2009 | McCulloch Garden
Garden Logo
46 people viewed this question
Top McCulloch Garden Experts
Jim Parker
Jim Parker
roeb
Matt Olenzek
Matt Olenzek
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
