Question about Brother MFC 6490CW InkJet Printer
I have a Brother MFC-6490CW and I want to scan paper that is 11x17 and the manual says that i have to set my glass size. However, they say to push the Scan button and then the Scan to Media button...that button isn't there. What do I do, my scans are coming in in Letter format and I've tried everything possible as far as settings on the computer side of things.
    President:
  • 405 Answers
You will need to open the control center program which is installed when you install the printer on your computer.
Start, all programs, Brother, control center. Click on configuration then scan then file. There are two tabs at the top, change the paper size at bottom of each to ledger and press ok.
Posted on Mar 28, 2010
Scan to media is (I found) scanning to a USB drive. Try inserting a USB drive in the USB port, and "Scan to Media" should appear.
Posted on May 21, 2010
SOURCE:
I have a MFC-6490CW and when i scan A3 it cuts off the sides of the page when i scan to file
Hi
Please select the auto select paper size option, if this don't fix your problem then go the paper option and manually select the A3 paper size and scan.
Jun 02, 2011 | Brother MFC 6490CW InkJet Printer
I am still trying to scan 11x17 and I sent it up in control center but still not working right it scans 8.5x11
CHANGE CONTROLCENTER CONFIGURATION
1. Open ControlCenter. START -> (ALL) PROGRAMS -> BROTHER -> XXX-XXXX (Model of machine) -> CONTROLCENTER. An icon will appear in the system tray by the clock. You may have to click this icon to launch the program.
2. Click CONFIGURATION -> SCAN -> FILE (or any other scanning option youare using)
3. Under Software Button, change Document Size to LEDGER 11 x 17 in.
4. Under Device Button, change Document Size to LEDGER 11 x 17 in.
5. Click OK
6. Place document on the Brother machine.
7. To initiate the scan, left click on FILE (or any other scanning option you selected in step 1). This issue should now be resolved.
May 18, 2011 | Brother MFC 6490CW InkJet Printer
Mfc 6490cw everyone paper jam errror ! please help me.. Thanks.
Hi enesuysal
I have done some research into your problem firstly you can obtain a copy of the manual for your model printer here from this link i have provided...
http://www.retrevo.com/support/Brother-MFC-6490CW-Multifunction-Printers-manual/id/20693ag613/t/2/
You will find the information you need on page 160 Pull the paper trays out of the machine.nikkiallisto.jpg
Cheers nikki
Please rate my answer.Thanks for using FixYa.
Jan 16, 2011 | Brother MFC 6490CW InkJet Printer
How do I select paper tray 2
You can set the Brother machine to automatically select the appropriate paper tray based on the paper size or you can manually select paper tray1 or 2. If you use the Auto Select feature, the application will automatically pull from the appropriate tray based on the document#s paper size. For this feature to work, the tray settings must be definedfrom the machine#s control panel. For instructions on how to configure this setting, continue to the section labeled: ADJUSTING YOUR BROTHER MACHINE#S PAPER SIZE SETTING)
PART 1: ADJUSTING YOUR BROTHER MACHINE#S PAPER SIZE SETTING
1. On the Brother machine, press MENU.
2. Scroll to and press GENERAL SETUP.
3. Scroll to and press TRAY SETTING.
Oct 29, 2010 | Brother MFC 6490CW InkJet Printer
HOW TO SET UP MFC-6490 TO SCAN 11 X 17 DOCUMENT
Jun 17, 2010 | Brother MFC 6490CW InkJet Printer
Trouble printing
It'll be better for you to use the built-in A3 paper size, otherwise you'll not be able to print it perfectly. I you would like to do it, You can try this, after setting the documents and the documents size, give the print command, and under the printer properties, select the paper size, you'll see an option (custom) from the drop down list, select it an set the size, but you must leave a space for the printer to hold the paper. Good luck. Thanks for using FixYa.
Jun 02, 2010 | Brother MFC 6490CW InkJet Printer
Where does the paper go on a Brother MFC 6490CW?
theres a menu button on the wireless printer..go to network and set the configuration from there if your using wireless just set the configuration to the existing wireless device you have and thats it...instant wireless printer connection...also check the manual..hope this helps...
Aug 28, 2009 | Brother MFC 6490CW InkJet Printer
MFC-6490CW, photocopy of 11x17 document prints 8 1/2 x 11 full scale image on 11x17 sheet. The image is centered on the 8 1/2 dimension, and located at one end of the 17 dimension. The rest of the 11x17...
First make sure you are not using "fit to page" as this feature does not work for legal size documents. To fix this problem we need to check several things. First, Press Copy, Load your document, press 1 for number of copies, press the up/down arrow until you get to "paper size" then choose legal (for 11x17). Press OK
It is also possible that your machine is set to reduce/enlarge size to less/more than 100%. If the first solution did not work start over, press copy, load document, enter 1 for number of copies, press up/down arrow to choose "enlarge/reduce" then use right/left arrows to choose 100% (again, do not choose 'fit to page') press OK. Once you have done this, you can set these as default if you like. Press Copy, press up/down arrow to choose new setting, press OK, press 1 to choose YES, press stop/exit.
Apr 18, 2009 | Brother Office Equipment & Supplies
Brother MFC 6490CW InkJet Printer Logo
3,044 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
