Question about Frigidaire FER311FS Electric Dryer
When i press the button it makes noise but the drum does not turn it sounds almost like its jamed
  • Frigidaire Master
  • 2,699 Answers
The drum on your dryer rides on a rear bearing,when it wears down the drum can jam,it pobably was very noisy before this happened 5303281153 rear bearing kit
Posted on Dec 13, 2009
Hotpoint Aquarius 1000 WM62 The drum makes a screeching noise when turning ? Any ideas ?
it could be drum bearings or even some thing that has got past the inner drum and is jamed inside hitting the drum when it turns,,,,could also be the motor bearings,,,,open the door and try lifting the inner drum up,,if there is any lift in it then the drum bearings are going,,this will also cause it to screem on spin speed
Dec 01, 2010 | Washing Machines
Drum will not turn and there is no heat.
This dryer has a circuit board that controls virtually everything. If it makes a buzzing noise when you press the power button to turn on the control panel, it's probably not going to be an easy fix. When you hire a professional, you avoid buying expensive parts that you might not need, such as a control board. If it makes a loud buzzing noise when you press the start button, it's possible that it could be a motor or belt problem. But again, I'd recommend a service call for this one.
May 25, 2010 | Whirlpool GEW9250 Electric Dryer
My Kenmore dryer 78942892 won't tumble when I press the start button. It begins makes a noise but doesn't tumble, then it just turns off.
sounds like the motor . remove drum and try to turn shaft . i think you will fint it won't . replace motor .. m m
Dec 24, 2009 | Kenmore 63942 Dryer
Hp 3210 is leaking magenta
Resetting the printer. After the Ink Service Module has been replaced, trigger level 1, 2a, 2b, or 3 will still be displayed when the printer is turned on. Reset the printer to remove the trigger level messages.
CAUTION: Do not reset the printer if the Ink Service Module is not replaced. The spittoon may overflow. Follow the instructions below to reset the printer.
  • Turn on the printer
  • Press and hold down the Cancel button
  • While holding down the Cancel button, press and hold down the Resume button
  • Hold the Cancel and Resume buttons down for 8 seconds and then release both buttons. The Right Print Cartridge LED and the Resume LED will go off and the printer will return to a Ready state.
  • When the printer returns to the Ready state, it indicates the printer was successfully reset.
    OK I had the hp error code 0xc18a0001 problem and here is the conversation I had with the tech...
    James Cowan: HP error code 0xc18a0001
    Earnest: I will assist you in this regard. I understand that a error code with 0xc18a0001 with "Ink System failure" is displayed on the front panel of the All-In-One printer. Am I correct?
    James Cowan: Correct
    Earnest: May I have the model number of All-In-One you are using?
    James Cowan: c6250
    Earnest: Please let me know the room temperature in which printer is replaced
    James Cowan: 67 degrees F
    Earnest:: OK. Please perform the below steps on the front panel of the printer to resolve the issue
    James Cowan: OK
    Earnest:: Press and hold the "left arrow" key. Press the "Setup" key and release both keys, display should say "Enter Special Key Combo". Press and release the "OK" button
    Earnest: Please ignore the above steps
    James Cowan: OK yes nothing seemed to do anything
    Earnest: Please perform the below steps on the front panel of the printer. Press and Hold the "Print Photos" & "Red Eye Removal" buttons. Release both buttons. Display should say"Enter Special Key Combo". Press and release in sequence"Red Eye Removal", "Print Photos", "Red Eye Removal"
    Earnest: Display should say "Support" and display the FW rev (something like R0616R)
    James Cowan: COxxFN0723BR
    Earnest: OK. Press and release the right arrow button until the display says "System Configuration Menu"
    James Cowan: OK
    Earnest: Press and release the "OK" button
    James Cowan: OK and it says hardware failure status
    Earnest: Display should say "Hardware failure status: Clear. Press OK to clear". Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue". Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. Please do not try to print at this stage
    James Cowan: OK
    Earnest: Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet. Let me know once you are done with the above steps
    James Cowan: OK its unplugged
    Earnest: Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer. Turn the unit on. The printer may display message "Use POWER button to shutdown the printer" followed by "Press OK to continue". Press OK
    James Cowan: OK
    Earnest: Let me know the message displaying on the front panel of the printer
    James Cowan: printer preparation occuring - do not interrupt
    Earnest: OK
    James Cowan: OK its done
    Earnest: Let us print a self test page from the printer now
    James Cowan: OK deal
    Earnest: 1) Load letter, A4, or legal unused plain, white paper into the input tray
    2) Make sure that the printer is on and loaded with unused plain, white paper
    3) Press Setup. The Setup menu appears
    4) Press the down arrow button to select Tools and then press OK
    5) Press the down arrow button to select Self-test Report , and press OK. The self-test report prints
    James Cowan: OK printing
    Earnest: OK, please check whether all the colors pritned perfectly on the test page
    James Cowan: Perfect
    Earnest: Great... Cheers!!!
    James Cowan: Thank you very much
    Earnest: Now you can continue using the printer.
    Sep 25, 2009 | HP Photosmart 3210 All-In-One InkJet...
    The drum doesnt turn
    I would start by checking the belt to see that there is not too much slack in it. Applying a belt dressing spray may help. If not, and there is too much slack in the belt, it might be time to replace it. That is a lot less expensive than actually replacing the motor. Hopefully it won't come to that.
    Hope this helps. Good luck.
    May 18, 2009 | Estate TGDS840JQ Gas Dryer
    Error 79 hp 3300
    OK I had the hp error code 79 for HP 3300 problem and here is the conversation I had with the tech...
    James Cowan: c6250
    James Cowan: OK
    James Cowan: OK
    James Cowan: OK
    James Cowan: OK
    Earnest: OK
    Apr 24, 2009 | HP Office Equipment & Supplies
    60.40 Error Message on HP Laserjet 5025 MFP printer
    OK I had the hp error code some problem and here is the conversation I had with the tech...
    James Cowan: c6250
    James Cowan: OK
    James Cowan: OK
    James Cowan: OK
    James Cowan: OK
    Earnest: OK
    Feb 22, 2009 | HP Office Equipment & Supplies
    Kenmore elite HE3
    You need to check if the Spray Arms are knocking against an item in a basket. If the source of noise cannot be determined, run a program without plates or glassware. If the noises continue, let me know for further investigation.
    Oct 05, 2008 | Kenmore 82822 Electric Dryer
    Grunting noise?
    If your machine is a Brother 4100 you can clear the drum message by pulling the drum out of the machine and then pressing the clear button. The display will ask if a new drum is the be installed. Press the number 1 to say yes. Reinstall drum. This resets the drum counter.
    As far as the grunting sound, that may be caused by a tight or jammed toner cartridge. Try changing that out.
    Hope this helps.
    Aug 27, 2008 | Brother IntelliFAX 4100 Laser Fax
    Whirlpool Thin Twin Model LT7000XUNO stack unit
    ithink I have the lt7000xuno
    something got jamed in it now the drum won't turn mabe spun abelt or is there a cut off switch?
    Aug 05, 2008 | Whirlpool LTE6234D Top Load Stacked...
    Frigidaire FER311FS Electric Dryer Logo
    213 people viewed this question
    Top Frigidaire Dryers Experts
    Marvin
    Marvin
    Sal De
    Craig Butler
    Craig Butler
    Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
