Question about Panasonic DMR-T3040 DVD Recorder
Indicates: No Disc or U11
My Panasonic DMR-T3040 will no longer recognize or read DVD-R discs, both blank and recorded - even those recorded earlier on this machine.
It still reads commercially pressed DVD's, but no longer DVD-R or DVD-Rams. Hard drive is still good... I just can't record on it any longer.
This problem began intermittently and has now become constant.
I love this recorder, it's served me well so any help is appreciated.
Best regards,
Rob Mize
4 Suggested Answers
Palmbeach
  • 185 Answers
SOURCE: DMR E55-P will not read DVD-R
Hi Benyto
Thank you for the information. Sorry that you are having such problems.
Nearly all the problems on ths DMR E55 are due to a faulty power board. The greatest load on the power supply is when the unit first reads discs and also when finalizing. Sometimes the unit cannot read discs and sometimes it continuously self checks.
Try replacing IC001 on the power board. This is a 5 pin regulator #STRG6353. This component gets very hot and the heatsink is poor. When I replace these, I use a larger heatsink and some heatsink paste which helps to prolong the life of the component. If you look at the regulator, you will see by the colour of the circuit board that it gets very hot. It fails after two or three years in all DMR E55s.
Be careful when you take the old regulator out because the print can lift away from the circuit board.
I have posted full instructions on how to replace the STRG6353 >HERE<
Hope this helps
Posted on Mar 03, 2008
  • 3 Answers
SOURCE: DVD recording problems
I have the same unit with the same exact problem. I ended up taking it in for repair and it's now working perfectly. I paid $100 for the repair. I dropped the unit off and picked it up myself. I think $30 additional is charged for shipping and handling in US.
PANASONIC CAMERA & DIGITAL SERVICE CENTER
1590 Touhy Ave
Elk Grove, IL 60007-5319
EMAIL camerarepair@us.panasonic.com
888-439-2676
Part Number
RFKNEH75VP
Description
RAM/DIGITAL PCB MODULE
Posted on Jun 28, 2008
SOURCE: DVD Code Problem No FVU
You need to install or update the Firmware. Go to www.panasonic.ca and search your model. You will then need to download the firmware for your player and burn it/mount it as an ISO file on to cd. Just follow the instructions and you'll be up and running in no time.
It took me about 25min, but it is working fine now.
Posted on Jan 01, 2010
Will not read DVDs
When I place a blank or ore-recorded DVD into mt Panasonic DMR-EZ47VEB it indicates NO READ. Can I solve this problem?
Feb 20, 2010 | Panasonic DMR-EZ47V DVD Recorder/VCR
Won't recognise DVD Ram and non-finalised discs from own recordings.
Usually, the U11 error code in a Panasonic DVD player indicates an optical problem. You could of course try doing a cleaning using a CD cleaner normally readily from computer parts stores. Alternately, you can open the unit up and do a manual cleaning with soft bristle brush and/or cotton buds. Other than that, it could be indicative of a weakening laser eye which of course would require parts replacement.
Hope this be of initial help/idea. Pls post back how things turned up or should you
need additional information.
Good luck and kind regards.
Thank you for using FixYa..
May 24, 2008 | Panasonic DMR-HS2 DVD Recorder
When I place a dvd in my Panasonic DMR-EZ47V DVD Recorder / VCR Combo, it apparently does not ''sense? it and indicates it ?no disc?. Any Suggestions?
hi, make sure you read the manual' to use the right disc.some can only record on few brand disc's name's only.hope that help.
Feb 20, 2010 | Panasonic DMR-EZ47VEBS DVD Recorder / VCR...
"NO READ" on Panasonic DMR-EZ27 DVD Recorder
This is the most common problem, in most cases the burner must be replaced.
May 03, 2017 | Panasonic DMR-E80H DVD Recorder
DMR-EH75V DVD Recorder
ekimt,
Yes, it would not recognize any type of disc. The disc icon was always present on the display even though no disc was inserted. Also, mine went out while recording from HDD to DVD. Panasonic had mine repaired in two business days and it' s working great.
mjs8
Aug 04, 2008 | Panasonic Diga DMR-EH75V DVD...
I have a panasonic dvd recorder modol dmr-e30 when i load the dvd i get the error message u11 how can i resolve this problem.
Has anyone found a solution? I was recording movies everyday and then it stopped and says U11. I am using the same discs as before.
Jul 02, 2008 | Panasonic Televison & Video
I recently bought a Panasonic DVD Recorder DMR-EZ27. And it does not read blank DVD's. I've tried different brands of DVD-R's, DVD R's, and DVD-RW's. However it will play and recognize pre-recorded DVD's....
The problem still is;nt fixed. I bought the dvd recorder from a person that buys customer returns at an auction. I contacted him and he offered to give me a full refund or another recorder. He thought it might be a software problem.Thanks for getting back to us on this problem.
Jun 10, 2008 | Panasonic Televison & Video
Panasonic dmr-es45v
The disc drive motor is burned out, its junk...if you didn't finalize the discs, they're junk too unless you buy another Panasonic DMR.
Jan 15, 2008 | Panasonic (DMR-ES45VS)
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Panasonic DMR-E50 won't recognise blank DVD's only
You can only record to dvd-ram or dvd-r NOT dvd-rw!
Dec 03, 2006 | Panasonic DMR-E50 DVD Recorder
Panasonic DMR-T3040 DVD Recorder Logo
94 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
