Hi I have a marshall AVt150 combo which worked
Hi I have a marshall AVt150 combo which worked fine until ...the sound cut out.
I have tried the following
1 Tried amp in another speaker unit.. no sound
2 Tried another amp into speakers of failed AVt150.. works fine.
3 used headphones output.. works fine
Have also noticed effects not working
Any advice ?
SOURCE:
techman
  • 3130 Answers
SOURCE: hooking up 2 speakers to 1 speakon output
Power Output (1 kHz*) Stereo Bridge-Mono 8 Ohm 4 Ohm 8 Ohm XLS 802 500W 800W 1600W XLS 602 380W 600W 1200W XLS 402 300W 450W 900W XLS 202 200W 300W 600W *1 kHz Power: refers to maximum average power in watts at 1 kHz with 0.5% THD. It depends on the impedence of the speakers. Carfull as you could burn up this amp if you exceed the resistance rating on it. Go here on all of the specs of this model of crown amps. http://www.crownaudio.com/amp_htm/xlsspec.htm Good Luck
Posted on Mar 27, 2007
  • 905 Answers
SOURCE: Carver Sound Problems
your going to need this place to download the remedy's for your system http://www.euras.com/repair_tips_1/CARVER/AV505/AV505_CARVER.htm
if it is not working then there is another serious problem , and it could be the amp IC or the volume IC but tests will need to be done to determine what is causing the failure , but it does sound like amp IC as a suspect since the rear were not even working , did the volume seem different when turning it up or down before the center quit or after the center quit?
Posted on Nov 03, 2008
petraman7
  • 1175 Answers
SOURCE: my azur 540a/640a v2.0 amplifier is not working.
I agree with hallsteve.
One or both of the output sections is blown.
What part of the country do you live?
I may be able to suggest someone.
Posted on Jan 22, 2009
SOURCE: Speakers pop and rear speakers cut out of surround sound
your problem is a bad solder connection of the relay linked to the lautspeaker sockets. I had the same problem and googled for the solution. Since I resoldered the pins everything is fine. That problem is well known and happens to a lot of Sony receivers.
I can send you a link with a detailed how-to-do solution with pictures, however it's written in german language. But you can use some online translators.
Here is the link: http://www.bmw-syndikat.de/bmwsyndikatforum/topic.asp?TOPIC_ID=28280&FORUM_ID=20&CAT_ID=9&Forum_Title=Geplaudere&Topic_Title=Problem+Sony+STR-DE445
Ralf (from Germany)
Posted on Feb 15, 2009
petraman7
  • 1175 Answers
SOURCE: Sony preamp has no speaker output but headphone jack work fine
Hi...
If this thing is a pre-amp , it will not drive any speakers.
You'll need a power amp to connect the output of the pre-amp to...then speakers.
PLease rate my help ...Thanks
Scott
Posted on Mar 25, 2009
Marshall HCFX footswitch jack quit. No voltage at jack, no schematic.
I know the HDFX but try downloading this maybe can be useful, sometimes the patterns are similar.
MARSHALL AVT150 AVT275 Service Manual free download schematics eeprom...
Jun 24, 2015 | Marshall Music
Marshall mg15fx. no sound coming. the only sound i get is buzz when switching the master knob.
I would test by first trying a different guitar cord. If the fault is still there, try jumpering the effects in and out jacks with a patch cord. If there is sound now, clean the two jacks with contact spray and working a 1/4 inch plug in and out of the two jacks.
Jul 04, 2014 | Marshall Amplification Marshall MG15 15...
Marshall troubleshoot
First check the preamp valve in that curcuit
Feb 26, 2014 | Marshall Amplification Music
My Marshall 250dfx has stopped working, there is power but nothing is coming out. No crackiling before, one min it was fine, the next it stopped.. Help!!
try another speaker or test the speakers on another amp. if the speakers are working then it's your amp . check out the output ic's. they maybe blown.
Dec 03, 2013 | Marshall Amplification Marshall MG30FX...
Marshall mg102fx cuts out
I've seen a bunch of Marshall Combos and a very common failure comes from broken resistor legs at pre-amp and power amp modules insides, they are the low-value/2-3W rated and the soldered legs broke so easy because of enclosure vibrations, let me know a bit more to improve help...
Nov 04, 2013 | Marshall Amplification Marshall JMD1...
Unresponsive Acoustic channel 2 Marshall as100d ....
I have same problem. i have this map. please help me to find the problem. if you can point the area in this map that problem is from that.
Mar 04, 2013 | Marshall Amplification Marshall AS100D 2x8...
Hi. I have a Marshal MG10CD amp. It was working fine, till a few days ago, when it suddenly stopped functioning. The amp gets power supply, as you can hear static when switched on, however, when the...
Check for a dry/cracked solder joint where the 1/4 inch phono input jack connects to the printed circuit board. Solid state Marshalls are renowned for this.
Feb 23, 2011 | Marshall MG10CD 10 Watt Combo Amplifier
Marshall MG50 DFX, the volume knob OD channel crackles
Either the control is damaged (happens if they get hit) or it is possible the circuit board it is mounted on has broken solder OR worse, a crack near the control. The unit will require servicing. Parts are readily available.
Jan 28, 2010 | Marshall Mg50dfx 50-Watt Combo Guitar...
Marshall Amp Sound Problem
try cleaning the send and return sockets with switch cleaner or WD40
Jan 31, 2009 | Marshall Mg100dfx 100-Watt Combo Guitar...
Marshall 50w dsl
Put a patch cable from send to return on the effects loop in the back of the amp and see if it goes away. I would check your speaker, connections and speaker cable also. Is this a head or a combo?
Sep 04, 2008 | Marshall 82 WTS LITHIUM BATTERY, 3 LED...
125 people viewed this question
 Grubhead
Grubhead
Steve Allison
Steve Allison
