Question about KitchenAid KEBC208 Electric Double Oven
Bottom oven does not get hot. elements get warm but not hot. i't a kitchenaid mdl no.KEBI200YWH
  • 1314 Answers
SOURCE: Frigidaire GM deluxe electri dean (electric oven wall unit)
if you feel through the insulation you can find the two wires that attach to the element pull them through to plug the element back on but there is no plug per say but first are you sure the element is good were there no wires on the element when you removed it should have been two spade connectors with wires on them attached to the element hold my rating till you reply
Posted on Jan 11, 2008
  • 190 Answers
SOURCE: Bosch oven not heating to temp
Dear customer,
i recommend u to try the following routine to sort out this problem
  • Check timer and clock settings
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • hope u find this useful. thank you.
    Posted on Jul 09, 2008
    • 291 Answers
    SOURCE: Oven doesn't reach temperature setting
    It could be the plug/receptacle that the element plugs into. It could also be that the elements have separate thermostats and that the one for the lower element is bad. If you can post the model number I can look at the electrical schematic and know for sure if it has one or two thermostats.
    Posted on Aug 31, 2009
    barkencoa
    • 3463 Answers
    SOURCE: Our double oven gets warm but not hot, could this
    If the fan is working o/k, and the thermostat indicator lamp is on, then it is going to be the oven element that needs replacing.
    This is located at the rear of the oven behind a removeable cover.
    Please rate my solution.
    Thankyou.
    Posted on Jan 16, 2010
    barkencoa
    • 3463 Answers
    SOURCE: Zanussi ZDQ 595 fan oven not heating
    You need to replace the round fan oven element located at the rear of the oven compartment behind a removeable cover where the fan is located.
    Posted on May 14, 2010
    Testimonial: "Thankyou - i did not know there was another element in there!! I cannot believe how expensive these ovens are considering the simplicity of their construction and low cost of the components inside.. Thanks again..!"
    I own a Kitchenaid KEBS208SSS double convection oven. The upper oven does not heat up. The bottom oven works perfectly. Thanks, Chaz
    You need to pull the oven out and see if you are getting 240 volts to the bake element (take the back panel off, press bake and start and put your meter lids on each prone of the bake element).
    If you do get 240 volts to the bake element then the element is defective. If you don't get 240 volts then you may be looking at a faulty relay board.
    Appliance Repair Brooklyn
    http://appliancerepairbrooklynnyc.com/
    Jul 03, 2018 | KitchenAid Ovens
    My Electrolux double oven goes from "bake" to "warm oven " after about 1 hour. I try to use the other oven and it will go start to "warm oven"
    is the bake element getting hot?when you put the oven on bake both the broil and bake elements come on,if just the broil element is getting hot it might take it an hour to heat up.you might just have a bad bake element,if the bake element isn't hidden does is turn red? if not it's not getting hot.
    Nov 14, 2017 | Electrolux Ovens
    The bake element (in over) will no longer get hot, should the element itself be replace or could it be something else? Range model RS675PXEQ0
    It does sound like the bake element is probably the problem. Many ovens turn on the broil element with 120 volts to even out the heat in the oven or pulse the broil element. This may be why the oven is warm but not baking.
    Nov 12, 2013 | Whirlpool 30" Self-Cleaning Freestanding...
    Turbochef tornado toaster wont get to menu, just warming up
    The most common issue with this is a bad IR element. When the oven is cold remove the metal rack. you will see the IR element on the bottom. turn the oven on. wait 1 min. open the door and see if the bottom element is warm at all. If the bottom element is still cold then you have a bad element.
    Feb 13, 2013 | TurboChef TORNADO Electric Oven
    Oven not getting hot
    I would recommend checking the circuit breakers, assuming that there is a 230 volt supply for the heater elements. If that is OK you might have a bad heater element.
    Jan 13, 2012 | Frigidaire Ovens
    Thermador over/microwave/heating drawer model SMW272YP Bake bottom element will not heat up. I have replaced the element. The display pannel has been replaced in the past, but still keep having the same...
    I just found out my baking oven doesn't work and I hear the fan for the convection roast, but no heat. I had the appliance man out and he said that I need a relay board! Big bucks and they don't make this model anymore. Moreover, the microwave and warming drawer work fine. This is ridiculous!
    Mar 07, 2009 | Thermador C302U Electric Double Oven
    Simpson 2001 series upright electric stove oven does not get hot only gets warm
    It could be the oven element (behind the cover plate in the back of the oven), or the fan not blowing the heat into the oven.
    Aug 19, 2008 | Ovens
    Re: oven
    the temp probe ( rod sticking out of rear wall inside oven ) should ohm out at 12-1300 ohms at room temp. the other possible cause is the heat relay on the control board is bad .this does not display a fault code.
    Jan 17, 2008 | KitchenAid Architect Series KEBC107KSS...
    General Electric Double oven wall unit
    id say something different like a thermal fuze or relay
    Nov 21, 2007 | KitchenAid Architect Series KEBC107KSS...
    KitchenAid KEBC208 Electric Double Oven Logo
    254 people viewed this question
    Top KitchenAid Ovens Experts
    Marvin
    Marvin
    Craig Butler
    Craig Butler
    Whirlpool
    Whirlpool
    Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
