Question about Tsurumi Pump Plumbing
I have a Tsurumi Honda powered THP- 4070-HA. Need a new impeller. Can you point me in the right direction
2 Suggested Answers
YIRMASTER
  • 32 Answers
SOURCE: Need Service Manual for 1987 Honda Accord
Here is a direct link where you can buy a Service Manual for 1984 thru 1989 Honda Accord.
Posted on Jan 12, 2010
Tsurumi pump 40pu2.15s my pump only humming and stop pumping water. what is the cause?
Most likely cause is a blocked impeller. Disconnect from power supply, remove pump from sump, take off pump base to expose impeller and check for freedom of rotation. If all appears OK and pump still just hums it could be a blown capacitor - unless you really know what you are doing I suggest you employ an experienced expert to proceed further. Where are you located?
Mike Goody
Jul 19, 2011 | Tsurumi Pump Plumbing
How much hydralic does 2"
What do you mean by Hydralic?
there is no hydraulic oil in it,
and its a Honda gas engine,
Jan 03, 2011 | Tsurumi Pump Tsurumi Diaphragm Pump 120cc...
My pump won't run it just makes a humming noise and gets hot. the impeller spins freely by hand.
If the pump is fairly new it could be the starting capacitor,
But if the pump get really hot quick its the motor who is damage and need to be rebuild or replace,
how old is your pump and wich model do you have?
Aug 13, 2010 | Tsurumi Pump s Submersible Trash Pump -...
My Tsurumi 50pn2.4s has a bad bearing. Where can i buy bearings and seals?
Probably any bearing store will have the right one,but you will need a mechanical seal from a Tsurumi pump Distributor,
www.tsurumipump.com
Jul 21, 2010 | Tsurumi Pump s Submersible Trash Pump -...
No problem just looking for a parts book on a tsurumi lb3-750 sub
Here is a breakdown of the pump. The contact number is at the bottom right of the page.
http://www.uco.no/Global/Bruksanvisninger/Pumper/synkepump_642422-232_br.anv.pdf
Website http://www.Tsurumi-Europe.com
Hopefully this will help you locate your parts.
Thanks for using FixYa,
Kelly
May 04, 2010 | Tsurumi Pump s Submersible Water Pump ...
My pump is humming but not pumping the water, what is the problem?
You are right, it is not running since there is no water
that goes out. It is just humming - which be due to
stucked impeller or busted starting capacitor. Let's start with checking up the impeller. Unscrew the strainer, and take it off. At the suction port, try turning the impeller by your finger. This is to check if it is stucked. If it is stucked, open the bolt holding the impeller case, so that you can free the impeller from
being stucked. Once the impeller is free, you can assemble the pump and switch it on and make it run.
If it doesn't run, then the final touch is to replace the
starting capacitor at the topcase of trash pump. In
doing this, make sure that in the reassembly of the top case, you must maintain the right force to close
the top case bolts water tight. Just send you e-mail
for further assistance. God Bless you.
Oct 26, 2009 | Tsurumi Pump s Submersible Trash Pump -...
Tsurumi submersible vancs series pond pump has
To get a new owner manual send them an email and they will email or send you one,
info@tsurumiamerica.com
Is the pump was working fine for a long time before that happen?
if yes
There is a motor problem,
You can check your pump power cable try to find any damage or hole in it.
If the cable fine
And if the impeller and wheel still turn before triping the breaker It would be a good thing to check the amperage with a special electronic tool to see how much amperage the pump take,
or
if you are good in manipulating tool we can send you the breakdown or i can support you to open it and to check the motor trying to find any burn part in it. That way we will know right away if its worth to fix it.
let me know
Jun 09, 2009 | Tsurumi Pump s Submersible Trash Pump -...
Pond problem
If your repair cost is more than 50% of buying a new unit, it is advisable to buy another. God bless you.
Apr 08, 2009 | Tsurumi Pump s Submersible Trash Pump -...
Plumbing Logo
55 people viewed this question
Top Tsurumi Pump Plumbing Experts
Paul Carew
Tom Chichester
Are you a Tsurumi Pump Plumbing Expert? Answer questions, earn points and help others
