Question about GE JVM1653 Microwave Oven
What does F5 when displayed mean? - GE JVM1653 Microwave Oven
  • 581 Answers
Replace humidity sensor
Posted on Dec 13, 2009
Getting a F-5 code on my microwave 721.80829500
The F5 error code indicates a humidity sensor failure. I recommend having the humidity sensor checked & replaced if needed.
Jul 13, 2014 | L-G Microwave Sensor Assembly -...
F4 or f5 on board if i unplug it and reset clock turnit on it runs for 2 or 3 sconds the display starts to blink it shuts off and you need to unplug and start over sometimes it will work
see this and fix it. read your section troubleshooting manual .God bless
you
  • F4--Open humidity sensor, will occur if humidity sensor is detected as being open continuously over 5 seconds.
  • F5--Shorted humidity sensor, will occur if humidity sensor is detected as being shorted continuously over 5 seconds.
Oct 15, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
F5 keeps blinking and stove is beeping
hello,
This f 5 code indicate or means that the oven has detected a condition it needsto check.what u need to do to solve this problem is to apply the below step as a guild.
Press "Cancel" to clear the display and to stop the beeping sound,then try turning the oven off and on again. If you still see the "F," turn offthe power to your oven and wait five minutes before turning it on again. If youhear the beep or see the "F" when you try to bake or broil again,
If your oven still has the warranty this will be covered under this ok
Hope this is very helpful for .
Thanks for using fixya.
Jul 27, 2011 | Microwave Ovens
What does error message F5 mean?
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing..
I'm not finding the one for for this model online.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If it's a convection model, F5 would be a damper door sensing error, which is usually a bad switch.
More info on switches is here.
One of the damper-related components, either the switch or motor or the damper door may be binding.
The damper is a door inside that opens or closes depending on cooking mode. If the controller senses that the door is not in the right position, it will shut down the cook cycle.
If it's not a convection model, F5 is probably a sensor error.
On some models, "SENSOR ERROR" appears on the display when:
  • Using the sensor feature, the door was opened before steam could be detected. Do not open the door until stream is sensed and time is shown counting down on the display.
  • Steam was not detected in the maximum amount of time. Use Time Cook to heat for more time.
Here's some info from Samsung, which is the actual manufacturer of these ovens:
"Some models are equipped with a sensor that can automatically adjust the oven's heating time based on the amount of steam in the oven. If your microwave is displaying E1, E4, or E5, there may be an issue with the gas sensor. For an E1 error, press the Cancel button and check on the food.
"Other microwaves do not give specific error messages and just display "8888" on the LED. If you get this error message, your microwave needs service.
"If the message is either ERROR or E-6, it indicates a mechanical fault.
"For all error indications, including the SE or 5E error, try unplugging the microwave from the outlet for at least ten minutes and then plug it back in. If the error persists, the microwave may require service. Please use our ASC Locator to find your nearest Authorized Service Center."
Feel free to contact me directly if you need more help.
Aug 22, 2010 | Frigidaire GLMV168K Microwave Oven
The control panel displays code F5 and I'm not sure how to fix this problem
If google and manufacturer website are of no help then ask a search agency like http://manualfox.com - They do a great job.
The service is not for free, but often worthy (you only pay if they find what you are asking for).
Jun 18, 2010 | GE Spacemaker JVM1540 Microwave Oven
Kenmore Gas Range model # 362.75491990 F3 error Oven will not hold temp - error message displays and beeps I Replaced the oven temp sensor same issue Is the control panel bad?
Many models of the GE microwave have sensors that can detect humidity from the foods you are cooking. This allows the microwave to make adjustments to the power levels used to cook your food. If "Sensor Error" appears, you should either press "Clear" to cancel the mode or leave the food in the appliance longer to give the microwave more time to detect the food.
Press "Time Cook" to manually enter the time if you receive an error message when trying to use the "Sensor Reheat" mode of your GE microwave. The error message may be caused by the food item being too large or too small to detect.
these are some other code error that will help you in case of next time.
  1. Step 1 Press "Off/Cancel" (or "Cancel/Off" depending on your model) to clear the error code. Note the code if it reappears.
  2. Step 2 Replace the touchpad if the code displayed is "F0," "F7" or "F10." A function key is stuck or shorted.
  3. Step 3 Replace the touchpad or the clock (ERC) if the code "F1" is displayed. Disconnect the ribbon connector to the touchpad. If no code is displayed after an hour, replace the touchpad. If the code displays again, replace the clock.
  4. Step 4 Replace the oven temperature sensor if "F2," "F3" or "F4" is displayed. "F2" indicates the oven temperature is too hot and the oven temperature sensor is suspect. "F3" or "F4" indicates the oven temperature sensor or shorted or open.
  5. Step 5 Replace the ERC if "F5," F6" or "F8" is displayed. The ERC is the main control unit. "F5," F6" and "F8 are codes that indicate problems in the ERC functions.
  6. Step 6 Inspect the door-lock assembly and circuit if "F9" is displayed. The door must lock when the oven is in use. If the lock mechanism is not functioning or if the detection circuit is malfunctioning, the stove will display "F9."
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); NOTE:
"F3" codes mean your oven temperature sensor has failed or shorted out. The only thing you can do is to replace the sensor.
Take care.
May 11, 2010 | Microwave Ovens
What does the F5 code mean?
F5 error message most often indicates a failed electronic control (although it can sometimes be caused by a failed oven temperature sensor. The sensor should be checked before replacing the control. It should read about 1100 ohms when at room temperature.
May 06, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
F5 Sensor Error?
The failure code list says to replace your Electronic Oven Controll. Contact a Frigidaire parts dealer and check the price and availability.
You will need to give them your make and model number.
Buckle up! It may get expensive!
Good Luck!
Feb 27, 2009 | Frigidaire PLMV168 Microwave Oven
I AM VERY DISAPPOINTED IN GE 'S HELP WHERE THEY WANT TO CHARGE 9.99 DOLLARS FOR HELP ON MY MICROWAVE WHICH IS OUT OF WARRANTY. IT IS ALMOST 2 YEARS OLD
Hi AGAIN DIBARTRK
Now that you have indicated the make of your oven....... the fault codes for GE microwaves are as follows. I have given you all of them for you future reference. :)
F1 - ( open thermal sensor ), will occur below 190�F of cavity temperature within 15 minutes of starting convection, combination or roast cook.
F2 - ( shorted thermal sensor ), will occur if a shorted thermal sensor is detected continuously over 5 seconds on convection, combination or roast cooking.
Note: it will take a minimum of 5 minutes of convection run time before F1 or F2 code will be displayed if the thermal sensor is shorted/open.
F3 - ( shorted key panel ), will occur if a shorted key panel is detected continuously over 60 seconds.
Note: It will take a minimum of 1 minute of run time before the F code will be displayed.
F4 ( open humidity sensor ), will occur if humidity sensor is detected as being open continuously over 5 seconds.
F5 - ( shorted humidity sensor ), will occur if humidity sensor is detected as being shorted continuously over 5 seconds.
Note: It will will take a minimum of 15 seconds after the magnetron is energized before the F4 or F5 code will be displayed if the humidity sensor is shorted/open. Also the unit must be plugged into a 120 volt outlet for at least 5 minutes before sensor is checked, this also applies after the humidity sensor has been changed. Before checking operation of new sensor allow init to be plugged in for at least 5 minutes.
F6 - ( shorted temperature probe ), will occur if temperature probe is detected as being open or not plugged into the receptacle. If probe is plugged in and "ProbE" is on display, check probe for continuity with ohm meter.
they are all different for different brands... It is much easier to get a solution from FixYa you actually tell us what sort of equipment you are having trouble with. :) Do I get a FixYa rating now... :)
regards
robotek
May 06, 2008 | Microwave Ovens
GE JVM1653 Microwave Oven Logo
107 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
