Question about Whirlpool LER5636P Electric Dryer
Replaced timer however time does not count down and dryer won't heat up
We replaced the timer, however it does not count the time down and the dryer does not heat up. Please help.
Thanks
  • 770 Answers
One thing to check it the voltage coming into the unit make sure you have 220-230 volts at the plug if so you want to open the back little panel where the cord goes in and check your terminal block and cord connection PLEASE unplug b4 you open the panel A dryer will still tmble but wont heat or advance if that leg(110volts) is not there and the other one is
Posted on Jan 21, 2008
Does the timer count down on sensor heating
On a sensor drying, timer shows ONLY estimated time to finish. It might add some time, or finish sooner depending on the size of load, fabric, and saturation.
Dec 23, 2014 | Samsung DV5451AEW Dryer
Whirlpool dryer doesnt heat, time and shut off when you open the door
if you have it on time dry and it doesn't count down the timer is bad but it should stop when you open the door unless you have a broken door switch too,just open the door and push in on the switch with your finger,it should make a clicking sound,if not the door switch is also broke,if you have the timer on auto or more or less then it won't move without heat.on auto the heat comes on when the dryer reaches temp. the heat shuts off and the timer will advance a little,then the heat starts again and the timer stops,it will do this until the clothes are dry by using a sensor instead of time.
Feb 16, 2014 | Whirlpool GEQ9800P Electric Dryer
Kenmore 110.60812990 will not stop
if it's not advacing in time dry you have a bad timer,that timer should count down no matter what the dryer is doing,if you have it in auto then it could be no heat,when it's in auto or more or less cycle the heat comes on and the timer won't move until the heat shuts down,when the heat is off timer advances,when the heat starts the timer stops,it will do this until the clothes are dry and then timer will shut off but in timed cycle,timer isn't counting down get a new timer.
Apr 05, 2013 | Washing Machines
Duet sport electric dryer won't heat or spin, minute counter counts down
You will need to replace the "thermal fuse" located on the back of the dryer. Here is the part to order.
Nov 22, 2012 | Dryers
My clothes dryer timer won't work and it won't heat up
Dear Sir:
See this possibles causes:
1) Do not work
Power house: test for blown fuse or c. breaker tripped, replace or reset
door switch: test for open or defective see the video
thermal fuse. test for open or defective see the video
wiring: see for burn or breake test for continuity see the diagram
heating element: test for burn or open see the video.
God bless you.
May 23, 2012 | Dryers
The dryer works fine in TimeDry mode, but in Intellidry mode it dries very slowly. The "Moisture Moniture" indicator lights start and stay at "Less Dry". I have replaced the moisture...
you could have bad gas coils.if the timer doesn't advance in auto dry most likely you're having heat problems,when the dryer heats and then the heat shuts off then the timer will advance,when the heat comes back on the timer stops,it does this until the clothes are dry.gas coils when starting to fail will work normally until they get hot and then no heat until the coils cool down then they will work again,on time dry the timer just keeps counting down until the time runs out no matter what's happening to the dryer.i've seen the coils fail after the first 10 minutes and other times for 20 to 30 minutes but usually if the load is big and in time dry the clothes will feel warm and you'll need to dry them a second time to get them fully dry,also while you're in ther you should clean out the dryer at least once a year,clean out the duct that the lint filter slides into,vacuum out the cabinet where the motor is and blow out the vent line,if it's a long run i use a leaf blower to blow out the line,remove it from the back of the dryer,stick the leaf blower into the vent line and blow it out,i've blown out birds nest out of some lines, your clothes will dry on time,you won't go through so many parts and you won't have to worry about a dryer fire,the gas coils are on top of the gas valve,remove the two phillips screws,lift off the cover and change out the coils.next time you use the dryer keep an eye on it,after it runs for 20 minutws start checking it,you'll hear a click,then another click and the flame will lite,look into the gas tube and if the flame isn't liting then you have bad gas coils.
Sep 10, 2011 | Maytag MDG7600AW Gas Dryer
Kenmore Elec Dryer timer & Heat Element Failed
if you set timer on time dry it will count down but if you have it set on more or less it will not advance without heat,change out the heater and you will be fine
Nov 04, 2009 | Kenmore Elite HE4 Electric Dryer
Dryer does not stop - timer knob does not turn so dryer continues
do you have it on more or less?,if so the timer will not move unless there is heat, do you have heat?are the clothes drying ?if you have it on time dry the timer is bad try moving it past the spot were it's sticking and see if it counts down
Nov 03, 2009 | Whirlpool GGQ8831L Gas Dryer
Maytag Dryer has lost heat...
I would think the timer is not used but a humidifier when on auto dry mode. Check the humidistat, should be either make or break contacts, open or closed.
Nov 11, 2017 | Maytag Dryers
Whirlpool LER5636P Electric Dryer Logo
135 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
