Question about Midway Home Entertainment Rise & Fall: Civilizations At War for Windows
Compatibility problem with rise and fall civilizations at war
The game will install but when I try and run it to the game will install but when I try and run it to play the game it says there is a compatibility problem and terminates that game how do I get it so I can play the game?
Get a vista patch off the internet and install to your directory, it will afterwards work, i had the same problem :)
Posted on Feb 27, 2010
This is only the data I am discovering all around. Happy Wheels
Posted on Jul 28, 2018
Unable to locate file, the data path appears to be incorrect, pleas check your data path After i open the game
The game's installation seems to corrupt. Try re-running the game's setup file and - whenever possible - choose the 'Repair' option ...
Jun 27, 2014 | Midway Home Entertainment Rise & Fall:...
Robert E. Lee: Civil War Install Help
if that is an old version , it probably will never install or work in windows 7. they do not upgrade old games
Dec 10, 2017 | Sierra Robert E. Lee: Civil War General
Problem with Rise & Fall: Civilizations At War for Windows 7. how to open ebooklibrary.exe
To install and run "R&F Civilizations at War" in Windows 7:
1) Run the Setup file and install the game
2) Google and download "http://www.ausgamers.com/files/process/24085/rise-and-fall-civilizations-at-war-patch-v115-beta" and "http://www.star-force.com/support/sfdrvup.zip".
3) Install "Rise and Fall: Civilizations at War Patch v1.15 beta".
4) Run the game, let it install required libraries and then reboot.
5)Run sfdrvup.exe and update the protection driver. Reboot.
Now the game should run in Windows 7.
Jan 08, 2012 | Computers & Internet
I'm trying to play rise and fall civilizations at war but i tried to play it after installing it and an alert came up saying there was compatibilty problem. please help
Depending on what operating system you have, it might legitimately be a compatibility problem with the OS. For example, if it's a 64 bit game and you're running it on a 32 bit platform (unlikely), or if the game was made for XP and you're playing it on Vista or 7.
One of the possible solutions (for the XP and Vista/7 problem, or basically any problem similar) is to right click on the .exe for the game and change it to compatibility mode. Go to My Computer>C:>Program Files (or Program Files (x86) in Vista/7)>Midway>Rise & Fall etc etc...It might not exactly be that directory, so in order to find it you can find its entry in the Start menu and right click on it, and go to properties. In the resulting menu you should see "Shortcut Target" or something to that effect that tells you the directory in which the game is located.
Open that directory and find the executable for the game. It should have a little mini picture of the game and should be named the same as the title of the game. Right click on it and go to Properties, then go to Compatibility. Check the box "Run this program in compatibility mode" and select the operating system in the drop down box for which the game was designed (You can find it on the back of the box). Now try running the game, and it should work in theory.
Unfortunately, I've had no luck with compatibility mode. Another option that might or might not work (depending on the requirements of the game) is to run it on a virtual machine. You can download VirtualBox as a virtual machine emulator, then create a virtual machine with the desired operating system. You have to have access to a licensed copy of the target OS, however, so if you don't have one this probably won't be the best solution for you. Also, virtual machines have a bad habit of not being compatible with certain graphics engines, etc, so it might not work anyway...Just a thought.
Though I've never used it, Windows 7 (if that is your operating system) users can download something called "Windows XP Mode" which lets you run programs which were designed with XP on your windows 7 platform. I believe it's some form of virtualization that's done, but as I've never used it, unfortunately I can't give you any helpful advice as to how to install, set up, and run it. You can most likely find anything/everything you need online. If you have any specific questions let me know and I can do some research and see what I can find out. Best of luck!
Tj
Aug 09, 2011 | Midway Home Entertainment Rise & Fall:...
My robert e lee civil war general game is not working on my windows vista it says it is incapitible with 64 bit version of windows how can i get it to work
If the game is not compatible, I am afraid, it will not work. Your computer may not have the right settings for the game or you have to much space used up. If you have any more questions, please contact me. I am here to help. Thanks for using FixYa. Good Day.
Feb 12, 2011 | Sierra Robert E. Lee: Civil War General
My mouse will not move on rise and fall civilizations at war but it will pick up signals like clicking
Looks like, the main problem is the mouse driver.. I've got Razor Abyssus with 1000hz and 3500dpi and it stands still.. but I do remember, when I've played Rise and Fall a little time ago, with my different mouse
Feb 14, 2010 | Midway Home Entertainment Rise & Fall:...
Rise and Fall, Civilizations at war
i thiink your gfx card does not support required version of pixel shader....google for ne hack of pixel shader for the game..
Aug 24, 2009 | Midway Home Entertainment Rise & Fall:...
Midway Home Entertainment Rise & Fall: Civilizations At War for Windows Logo
2,493 people viewed this question
Top Midway Home Entertainment Video Game Consoles & Games Experts
Han Jenny
Han Jenny
Level 1 Expert
Olivia
Olivia
Level 1 Expert
Are you a Midway Home Entertainment Video Game Console and Game Expert? Answer questions, earn points and help others
