Question about E-Machines eMachines Desktop PC
My cmputer does not come on only the fan is working it is not cming on at all not even the power light
  • 101 Answers
Check the SMPS (power supply) and replace it.
Posted on Dec 13, 2009
SOURCE:
My minka wire light does not work is it the dimmer switch on the fixture
Check for 120Vac cming into the light fixture, if its there, the problem is your fixture, the fixture switch, or the way you wired it into the circuit.at the light fixture
Aug 17, 2014 | Minka -Aire Brushed Nickel Remote Control...
My trailer furnace is a coleman DGAA. everything seems to be running good except cool air is cming through vents. takes a long time to get my olace warm.
1 of 2 things, 1, check calibration to match control amperage, 2, check fan switch, but if you have ever changed the thermostat it more then likely your calibration. GARRANTEED
Dec 30, 2010 | Coleman Heating & Cooling
2005 chevy silverado asb and brake lights are cming on and there is a chime and all gages are moving as if loosing power
Check your brake fluid level to make sure it is high enough. May want to connect an OBD-II ABS Brake Scan Tool such as Actron brand to determine what exactly is wrong with the ABS braking system.
One can be obtained off of Amazon.com for $114 or so delivered ( I did anyway).
Not sure about why it is losing power.
Sep 18, 2010 | 2005 Chevrolet TrailBlazer
When start cmputer after same time autometically resrat computer
You may need a new power supply....also check your internal fans to make sure they are spinning. Make sure memory is seated properly. Motherboard may also be in question. Try unplugging letting it sit for a few then plugging back in.
Aug 04, 2010 | HP Pavilion a1410n (ER890AA) PC Desktop
Advenu 7211 powers on 3 lights ok , fan on , no display on laptop or external display , no boot just sit there
do you often keep ypur laptop on your lap or a padded surface? it sounds to me that you may have a motherboard problem (worst case scenario) there are two things you can try, if you know what RAM is then make sure your cmputer is off then take out the ram and re seat it or switch slots too many times laptops develop faulty ram slots or ram chips if i were you i would try that first or maybe try another monitor but if you still dont get a display and your fans and hard drive activity are not constant when turned on then you really do have a hard drive problem! good luck!
Dec 18, 2009 | Computers & Internet
Power and internet lights flash slowly green & if i press reset button then power light flashes green to red. No other lights illuminate.
Try a hardware reset by holding in the reset button on the back panel (need a pin) for 20 seconds as you turn it on. If it does not work or you will not get connection from your router to cmputer it means the router has gone bad and need a replacement Let me know if this will help
Nov 27, 2009 | NetGear DG834G Router
Power problem to cmputer
Kindly check the connection from the front power button to the motherboard. The front power button wire may not be plugged into the correct jumper.
if that wire is hooked correctly, remove the memory modules from the system and all other wires from the board , except the power supply connectors to the board and then power it on , check the status of the light on the power button.
if you can provide us with the model number of the motherboard , we would be able to help you better
Thnaks
proton
Mar 12, 2009 | Intel Motherboard
No display, Phone boots without video and with limited functions
You can try a software update by downloading the Nokia Software Updater from the Nokia web site. Do this even if it is the same SW version.
*******MAKE SURE YOU BACK UP YOUR DATA 1ST ON PC SUITE*********
If this does'nt work then it is a mechanical problem. Will need to go into a service cnter to get repaired, Should be covered by the warranty, taking it back to the place of purchase
Feb 06, 2009 | Nokia N95 Cellular Phone
Fan and light does not turn on .
FAN AND LIGHT DOES NOT WORK
my zephyr typhoon stopped working. Neither light not the fan come up. I am sure there is power going into the unit. I turned on the light one day , the light cam on and suddenly went away. From then even the fan stopped working. any information on what happened is appreciated. Thanks
Jan 22, 2009 | Zephyr Typhoon AK2100 Kitchen Hood
Ps2 fan
Is your machine a old one or a slimline version??
Slimline version have a micro fan and can be replace it.The old one is even better because are cheap and you have a lot choice.Just make sure you get the right one.I believe is a ball bearing fan so if the balls inside get dirty or sticky ..or just defective from nature....nothing more you can do then get a new part.the noise is cming from micro vibration in rotation and all that micro..in 2000-3000 rpm in a minute make a lot noise
Jun 04, 2008 | Sony PlayStation 2 Slimline Console
E-Machines eMachines Desktop PC Logo
Top E-Machines Computers & Internet Experts
Thomas F. Schneider
Steve Allison
Steve Allison
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
