Question about Simplicity 7850 Premier Bagged Canister Vacuum
Simplicity 7 Series Vacuum. Suddenly stopped.
I have a Simplicity 7 Series. Was vacuuming today and it quit. I found the bag was overfull. Vac may have overheated? Is there a reset button?
other suggestions?
There is a thermal reset button on your vaccum. It is on the rear of the unit, just below the attachments and next to the sticker with the serial numer etc on it. The vacuum is designed to turn itself of if too much heat gets built up to prevent it from "burning up."
Posted on Dec 29, 2009
  • 1 more comment
  • BSD4U Oct 28, 2010
    The thermal reset was my problem, too. I found a top to a 16.9oz water bottle and a bunch of lint/fuzz in the line from the base to the back of the unit. It was totally plugged and caused the the thermal breaker to trip. Cleaned out the line, pressed the reset button, plugged it in and switched it on. Good as new. Thanks for the tip.
  • A Miller Oct 29, 2010
    I just got this notice ... it is good news ... I am glad this worked out for you ...
  • swenland Nov 20, 2011
    Thanks- That was my problem too. I vacumed up a bunch of dried leaves and it clogged the hose. I was about to recycle it until I read your solution.
  • 8,404 Answers
Overheated in Vacuum speak is burned up. The motor cools itself with the air you allow to pass through it, in this case, you choked it and it burned up. Your machine is probably not worth repairing. I serioiusly doubt there is a reset button that will overcome this though it would be worth a look-see
If you want to try to replace the motor, visit a fixYa.com advertiser or partner or your local appliance repair place or www.repairclinic.com
thanks for posting at FixYa.com
Posted on Dec 13, 2009
  • Linda Villano
    Linda Villano Nov 11, 2013
    The Simplicity vacuum has a reset button so wow this guy fixya seems to not know what he is talking about.
  • sher bear
    sher bear Feb 14, 2014
    Yes, do not take A Miller's advice. The Simplcity 7 has a reset button as Scotboyles instructs at the top of page
Put new filter on simplicity vacuum, where is the filter clock reset button?
Recline the handle all the way back, there is a little rubber cap on the motor cover that can be removed to push the button on the circuit board o reset the timer on the tandem air series. The vacuum must be running when being reset.
Aug 16, 2018 | Simplicity Vacuums
Simplicity symmetry vacuum stopped working
There is a reset button on the back that trips if the vacuum gets hot.
Jul 27, 2014 | Simplicity Vacuums
I turn it on and nothing happens,
I would double-check the seating of the bag. Some machines have a lockout switch that keeps you from running the vac with a bag incorrectly installed (which would then suck dirt into the motor).
Mar 16, 2014 | Simplicity Type S Sport Vacuum Cleaner...
Bag needed changing there was no burn ing smell or strange noises before i changed bag after bag was changed it wouldnt start. the cord is new no fraying and vac is about 5 years old. didn
I'm not real experienced with this model vac, but I do know that many of the newer vac's are being manufactured with a small button or lever, whatever the particular brand of vac decides would best fit on their unit, that would be located somewhere around the edge of the bag door opening and would need to be depressed by having a bag inside in order for the machine to run. I would check for something of this nature to be sure that during the bag change that you didn't just miss putting it in quite right to depress the go button. Other than that, it's entirely possible that the switch died. If that's the case you'll need to bring it in to a vac repair shop for help.
Nov 11, 2013 | Eureka Smartvac 4870 Bagged Upright Vacuum
Sentry 3 series vacuum smelled hot, and now will not power up, changed bag (not over full)
There is a reset button on the back of the vacuum that shuts the power off if the motor gets too hot. Try pushing the little white button on the back. If it comes back on that means that there is probably a clog somewhere or the bag was too full.
Aug 10, 2013 | Simplicity Vacuums
I have a Windsor Sensor s12 and power shuts off after 5 min. of vacuuming. I'm wondering if it's overheating of if there is some other sensor that causes it to shut off.
Your Sensor most likely has an internal heat sensor that is shutting off the motor. Some vacuums install an external heat sensor with a reset button that you must push to re-start the vacuum. If your model does not have an external reset button it is most likely a sensor inside the motor. If it is defective the motor must be replaced to solve the problem. But first make sure the overheating is not being caused by a blockage somewhere or the bag is too full. Air must pass completely through a vacuum starting at the floor where it picks up the dirt through all the canisters, filters, bags, etc. and then is exhausted from the vacuum. Any restrictions or blockage can cause the motor to over heat.
That Vac Guy
Jan 04, 2013 | Windsor SR12 Sensor Bagged Upright Vacuum
I have a simplicity 6 series vacuum. the bag overfilled and vacuum will not run. No power. is there a fuse of relay inside the unit?
no just on /off switch and direct power to vac motor sounds like its burned up from bag being overfilled , now you have to get to the vac motor test it with switch on to see if its getting power if so then motor is burnt.use an ohms meter for power test.
Feb 07, 2010 | Simplicity 7250 Deluxe Vacuum
Overheated vacuum
It normally won't over heat unless the bag is too full, the filters are clogged, or you have have a clog in the hose or down by the brush roll, the inlet may be clogged. Some will restart after a while, some others have a reset to push. If it won't power on, then you have a problem and it will have to serviced.
Mar 20, 2008 | Simplicity 7850 Premier Bagged Canister...
Overfull bag caused shutdown-will not restart
There can be quite a number of causes for these problems. A lot of the time there is a clog that the consumer has not found. If the motor sounds like it is running at a high pitched noise, and there is low or no suction, then that's your problem.
With the over full bag problem, I might have to know a little more information. There may be a reset button on the machine. You are going to want to check around the base of the machine where the brush roll is. Also, a good thing to do is to just change the bag and give the machine about 15 minutes before you turn it back on. It's high unlikely that you shorted-out the thermal protector with one time of not changing the bag.
Oct 02, 2007 | GE 106766 Bagged Canister Vacuum
Simplicity 7850 Premier Bagged Canister Vacuum Logo
5,090 people viewed this question
Top Simplicity Vacuums Experts
Tally Girl
Tally Girl
Are you a Simplicity Vacuum Expert? Answer questions, earn points and help others
