Question about Linksys Wireless-G Range Expander (WRE54G)
Wireless G ranges expander
I live in a motorhome and I bought a wireless G range expander becauce we are connect to the hotel and the connection is not strong enough . The signal is excellent with the range expander but I cant' connect with my internet and if I do not connect the range expander it is a low signal but I could connect to internet. Is it because of my Norton. Please help me
  • 48 Answers
When using the range extender you have to make sure you set the SSID, channel & wireless key in the range extender the exact same as the router also it has to be in the same IP range so if the router IP address is 192.168.0.1 the range extender IP address has to change from 192.168.1.240 to 192.168.0.240. once that is done restart the range extender and disconnect the ethernet cable & it the 2 lights should light up blue.
Posted on Feb 10, 2008
Expand range extender
You can install a wireless range extender. Try a Netgear Dual Band WiFi Range Extender, this device extends the wireless range of your existing wireless router, it connects to your wireless router using a wireless connection without the need of a LAN cable.
May 19, 2013 | TP-LINK TL-WR1043ND Router
Cant find a strong enough connection
You need to buy a Linksys Wireless-G Range Expander to boost the signal
  • Move your wireless router to a central location in your network, keeping in mind that the router should be at waist level at the very least, not on the ground.
  • Plug in the Linksys Wireless-G Range Expander in the room where your wireless router is. You'll move the range expander later, but for setup purposes, it should be in the same location as your wireless router.
  • Press the Linksys Wireless-G Range Expander's "Auto Configuration" button for five seconds, which will allow the range expander to detect your wireless network and configure itself with the appropriate settings.
  • Unplug the Linksys Wireless-G Range Expander and relocate it to a location closer to the Xbox 360.
  • Ensure that the antenna for the Linksys Wireless-G Range Expander is pointing upward, and keep in mind that the higher the range expander is placed, the better performance you will get out of it.
  • Plug the Linksys Wireless-G Range Expander back in, and your wireless network should have a much greater range, ensuring that your Xbox 360 is able to maintain a good connection to the network.
  • Dec 29, 2010 | Microsoft Wireless Network Adapter Xbox...
    I got a wireless network connection home but the modem and router are both upstairs while my ps3 is downstairs. i bought wireless-g range expander model no. wre54g in order to expand my wireless network...
    Hello
    This not a big deal for a wireless network to work on downstairs, you need to check your connection and settings of the routers/computers. or just put a repeater for improvement of signal strength.
    If the matter is signal strength, for the purpose see the TIP link below
    http://www.fixya.com/support/r7245572-improve_signal_strength_wireless_network
    Good Luck
    Dec 13, 2010 | Linksys Wireless-G Range Expander (WRE54G)
    Hi, I just got Linksys WRE54G V.3 and was trying to install the CD. But I keep getting "Site Survey fail" message. My house is using a router made by Apple, and does not have extra space to...
    The range expander helps to extend the range of wireless network...
    Anyhow the range expander has to be placed withing the range of your Apple "wireless" router (Make sure your apple router is wireless router, if it is a wired router, then there is no use of range expander...! U need to buy an Access Point instead)...
    your range expander must be connected to the computer(using an ethernet cable) from which you are trying to configure...
    Site survey searches for the available wireless networks in range...
    It should show your existing wireless network...
    You need to select your appropriate network and you need to configure the Range expander wireless settings according to the Apple router's wireless settings...
    exactly the same SSID(Network name), Security type and encryption technique, password PSK (security key) has to be selected on your range expander as in the APPLE wireless router...
    Thats it...
    You are done...
    Your wireless network range would have extended now....
    Dec 09, 2010 | Linksys Wireless-G Range Expander (WRE54G)
    Dear I did everything mentioned above but still light is red
    Hi Friend, In this case I would recommend you to please reset the range expander once again and connect the range expander with the ethernet cable once again. Match the settings of the router to the range expander I mean while configuring the range expander, the wireless network name and the wireless key should be same and the channel should be same and the security type should be same.
    If it still doesn't work then I would recommend you to please try to change the channel to 1 or 9 or 11
    Dec 08, 2010 | Linksys Wireless-G Range Expander (WRE54G)
    I have a netgear wireless router with WPA security. and i bought a WRE54G . I cannot configure the expander as you know netgear IP is 192.168.0.1 and lynksys expander is 192.168.1.240. when i open...
    Try to reset WRE54G
    Resetting the Range Expander to Factory Default
    The range expander can be set to factory default by pressing the Reset button of the range expander for 20 seconds.
    NOTE: The default IP address of a range expander is 192.168.1.240.
    After resetting the range expander to factory default and you're still unable to access the web-based setup page, make sure that your computer's proxy settings are disabled. For instructions, click here. To disable the proxy settings using a Mac computer, click here.
    NOTE: If all the steps above failed, try to disable any security software on your computer before accessing the range expander's web-based setup page. Click here to learn how to disable your computer's firewall.
    If you are using a Wireless-G Range Expander (WRE54G v2 or v3) and you can't access the web-based setup page, perform the following steps:
    Checking Physical Connections
    Make sure that the computer is connected to the range expander's LAN or Ethernet Port. If the range expander is properly connected, check the LEDs on the network adapter. For instructions, follow the steps below:
    Checking LEDs on the Network Adapter
    Make sure that the LED light of the computer's network adapter is lit or blinking. After checking the LEDs on the network adapter, assign the computer a static IP address.
    NOTE: If the network adapter's LED is not lit, try using a different cable to further isolate the problem..
    Assigning the Computer a Static IP Address
    For instructions on how to assign a static IP address on your computer, click here. After assigning a static IP address, check the computer's connectivity to the range expander.
    Checking the Computer's Connectivity to the Range Expander
    For instructions on how to check the connectivity of your computer to the range expander, click here. If you're still experiencing difficulty accessing the web-based setup page, reset the range expander.
    For instructions on how to restore the range expander to factory default, click here.
    If you're still having difficulty accessing the web-based setup page, make sure that your browser's proxy settings are disabled.
    If you're using a Wireless-G Range Expander (WRE54G v1), you need to do the following:
    For instructions on how to assign a static IP address on the computers' wireless network connection, click here.
    Connecting Wirelessly to your Range Expander
    NOTE: In this example we used WUSB54GS V1.0 (Wireless-G USB Network Adapter).
    If you're using a Mac computer, click here for instructions on how to connect to a wireless network using the AirPort card.
    Step 1:
    Run the Linksys Wireless Network Monitor by double-clicking this icon 3719-001.jpg at the bottom-right corner of your screen.
    4146-005.pngStep 2:
    Click Site Survey then select the SSID of your wireless range expander and click Connect.
    NOTE: The default SSID of the range expander is in this format linksysRxxxxxx.
    4146-007.pngChecking the Computer's Connectivity to the Range Expander
    NOTE: If you're using Windows 98 or Windows ME, click here.
    If you're using a Mac computer, click here.
    Windows 2000/XP
    Step 1:
    Click Start, then click Run.
    Step 2:
    When the Run window appears, in the Open field type "cmd", then click OK.
    3984-003.pngStep 3:
    When the MS DOS Prompt appears, type "ping 192.168.1.240" then press [Enter].
    Step 4:
    See if you're getting 4 replies, Packets: Sent = 4, Received = 4, Lost = 0 (0% loss)
    Nov 08, 2010 | Linksys Wireless-G Range Expander (WRE54G)
    Forgot password for my netgear range expander
    Reset it and reconfigure it. You need to know the configuration of your wireless router to make your range expander work again. Can you still connect to the Internet without the range expander?
    Sep 12, 2009 | NetGear RangeMax WPN824 Wireless Router...
    Can't connect to the internet after range expander set up
    Ok, what you need to do is reset your Linksy wireless connector box, hold button for 30sec. After, you need to try to connent it to your phone and or computer. Try to see if you have a connection.
    Jan 11, 2009 | Linksys Wireless-G Range Expander (WRE54G)
    I just bought a Wireless G Range Expander and when I try to set it up, I continually get the "Site Survey Failed". What am I doing wrong?
    I believe your using a WRE54G, but which version? The latest version has ethernet port so you can connect it directly to a pc to set it up.
    Try to access the expander's set up page by typing its address of 192.168.1.240 and you will be able to configure it from there.
    Jun 25, 2008 | Linksys Wireless-G Range Expander (WRE54G)
    Having Problem Acquiring IP Address
    when using the range extender you have to make sure you set the SSID, channel & wireless key in the range extender the exact same as the router also it has to be in the same IP range so if the router IP address is 192.168.0.1 the range extender IP address has to change from 192.168.1.240 to 19.168.0.240. Hope that helps.
    Dec 25, 2007 | Linksys Wireless-G Range Expander (WRE54G)
    Linksys Wireless-G Range Expander (WRE54G) Logo
    487 people viewed this question
    Top Linksys Computers & Internet Experts
    Prashant M
    Prashant M
    Michael Galve
    Michael Galve
    Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
