Question about Singer 1507
Jamming brand new machine
I just bought this machine and after about 5 stitches, the bobbin thread bunches under the face plate and jams the machine. I've oiled and cleaned the machine, as well as tried using a different size needle but it keeps happening. Any pointers on how to fix?
  • 96 Answers
The tension on the bobbin case needs to be adjusted to needle size and type of fabric the medium fabrics usually use a size 11, light fabrics need a size 9 and heavy like ( corduroy denim or upholstery fabric needs a 14 or 16 Heavy fabrics need a little less tension on the top side so it will feed properly just play with it until it looks good on a scrap of the same fabric
Posted on Dec 13, 2009
SOURCE:
I have a janome 6600. The stitches started jamming up and breaking.What might be causing the challenge with the stitches?
Difficult to say without really seeing what's happening and which thread is breaking. If the top thread is breaking, check to make sure the thread is not wrapped around the spool pin or a thread guide.
Just some things to try:
Install a brand new needle.
Be sure to clean and remove all the thread pieces, lint, etc from under the needle plate, around the shuttle, etc. Oil as instructed in the owner's manual.
Remove all the thread from the machine. ALWAYS RAISE the presser foot when threading the top and rethread the machine from the beginning. Check that the thread path is correct and the bobbin is loaded and threaded correctly.
Be sure to use good quality thread--no Old or bargain bin threads!
Solve Most Sewing Machine Problems With These Simple Tips
Why Does My Sewing Machine Keep Jamming Sewing Made Simple
Feb 11, 2018 | Janome Sewing Machines
I have a deco 600....it keeps on jamming. The top thread gets entangled with bobbin and the machine jams fast and the needle breaks.
try adjusting the needle thread right up to stop the bunching of thread that is causing the problem
Oct 16, 2016 | Sewing Machines
My machine is new (only used once) but now keeps jamming, appears the needle keeps jamming under the plate,please help.
if it' still under warrenty take it back and get another..if it's not under warrenty, try a new needle, make sure the top thread is not coming off the thread take up lever, make sure the bobbin is turned the right way in the bobbin case, also could be a timing problem
Dec 03, 2014 | Sewing Machines
Thread on the bottom side of stitch is all bunched up
Try these suggestions
1. Change needle
2. Rethread the machine--top --make sure to use every thread guide
3. Take the bobbin out --make sure it is inserted correctly into the bobbin
Case, & make sure the bobbin is turned the correct way
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
Oct 09, 2012 | Sewing Machines
Bobbin jamming
try changing the needle
clean under the needle plate & in the bobbin area for lint
rethread the top part of the machine using every thread guide
if none of theses suggestions work, the machine needs to be
checked to see if there is a problem with timing
Sep 21, 2012 | Bernina Virtuosa 150
Have a brand new Singer 1507 that keeps jamming the bobbin thread. Have followed threading and winding bobbin instructions closely, but am still having problems with the bobbin thread jamming after 1-2...
I would try adjusting the tension on the machine - this sometimes causes the bobbin thread to jam while sewing. Re thread the entire machine including the top thread. Also it is recommended to use new thread as old thread can ball up after time. If no luck I would call the store you purchased the machine from.
Nov 30, 2010 | Sewing Machines
Model 7467. bought in april and it was working. now top and bottom threads will not form "stich". it is threaded correctly! took off face plate - nothing jamming up. machine made a clunking noise...
check the top thread tension
check to make sure the bobbin is inserted in the bobbin case correctly
check to make sure the bobbin case is correctly inserted into machine
Sep 30, 2010 | Singer Confidence 7467 Mechanical Sewing...
Sewing machine is jamming
The UPPER thread is not threaded through the machine correctly.
Feb 11, 2010 | Kenmore 11101 Mechanical Sewing Machine
The thread jams in the bobbin well
Make sure that you are using the correct bobbins and you have put the bobbin the right way around, make sure that you have threaded the machine correctly, and the needle is around the right way, these are a few things you can check.These are just a few simple things that a lot of inexerience sewers could check before going to a technician.
Jan 14, 2009 | Kenmore 15616
Top thread wrapping around hook under needle plate then jamming
Could be the needle is the incorrect size or the thread is not compatible with the embroidery or both. :)
Oct 31, 2017 | Singer CE-100 Futura Computerized Sewing...
Singer 1507 Logo
609 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
