Question about Linksys Wireless-G Broadband Router
My laptop will work if it is right next to the main computer but does not get connection in other rooms. It used to.
  • Linksys Master
  • 8,404 Answers
Have you tried a ethernet cable connection laptop to router?
You may want to reinstall/update your NIC driver.
Is there any aluminim foil backed wall paper in your house? Is your router hiding behind it? (big problem at my house)
Try these couple ideas - see what happens
Posted on Dec 13, 2009
I can't connect the printer with my laptop. The printer is connected to my main computer and I'm trying to get my laptop to recognize the printer.
You will need to add this printer as a network printer using the main computer as the server. This is easily done, but is different for each operating system.
winXP= start>settings>printers and Faxes>add a printer> add network printer (next will search for printer)
- sometimes you must share the main computer by opening windows explorer and right clicking on the c: and select sharing and follow the screen
- Hope this helps, send more info if you need more help
Aug 28, 2011 | HP PSC 2210 All-In-One InkJet Printer
A friends iof my gave me this router, but I don't know how to install it so that i can use it with my laptop in my living room. my internet is connect to my computer in my room. My main internet is in...
You have a few options. If you already have a router, set this one up as an Wireless Access point. It pulls signals from the main router and you can connect to this one. BUT your signal could be weak depending on the distance, walls etc. If you can make a cable run, use it as a switch. (Extend your ports, and as a wireless point. Go to Cisco Linksys and download the manual.It is not difficult. Use the main router as a your DHCP and this one as a wireless point. You will need to set up the SSID and security (Securty is optional, but I would do it). Give it a SSID different then your main one and you can setup your device to connect to the one with the strongest signal (Most do this by default.
Dec 18, 2010 | Linksys Wireless-G Broadband Router
I am having connection problems with this product, the NetGear Router WGR614. My computer that the router is connected to is in my family room and it works great in here, but when i am sitting in a chair...
HI, This is one of the problems associated with wireless connections in the home.
I have many clients in a similar sitauationa and where possible, I run an ethernet cable from the router to whereever the computer is to be used. Alternatively I use what's known as 'Powerline networking'. This is a system whereby the mains wireing in your house is used instead of ethernet.
There are several brands available and you can buy units that have a wireless transamitter on one mains plug so that you can be flexible with your wireless layout.
I have found this to be much more reliable than trying to use 'range-boosters'.
Aug 09, 2010 | NetGear Computers & Internet
Not connecting to laptop
Hello!
Please consider the steps given below to troubleshoot the issue while connecting the Camera to the HP Computer using a USB cable.
(i) Before connecting the Camera to the Computer, first initialize the Camera to the original factory settings by following the steps given below:
(a) Turn ON the Camera then press the Home button to display the home screen.
(b) Select Settings with left/right arrow on the control button.
(c) Select Main Settings 1 by using up/down arrow on the control button.
(d) Next, select Initialize and OK.
Performing the above steps will reset the Camera to the original factory settings. After resetting the Camera to the original factory settings, turn off the Camera and remove the battery pack then press and hold the power button for 30 seconds.
(ii) Then, reinsert the Battery pack and turn ON the Camera and press the Home button. Select Settings using the left/right arrow on the Control button.
(iii) Next, select the Main Settings 2 option then select "USB Connect".
(iii) In the USB connect, please select the "PTP/MTP" option.
(iv) Next, connect the Camera to the Computer using the supplied USB cable to get it recognized. Please make sure that the Computer is recognizing other USB devices when connected to it.
If the Computer still doesn't recognize the Camera then check in the Device Manager window for any exclamation mark.
Please press the Windows logo on the Keyboard and then press the "R" key while holding down the Windows logo key to open the Run dialog box. Then, please type "devmgmt.msc" in the Run dialog box and click OK to open the Device Manager window. In the Device manager, click on the plus sign next to each category and check for any exclamation mark, if there is any then right click on the device and click uninstall. After uninstalling all the devices with the exclamation mark in the Device Manager, please restart the Computer with the Camera remain connected.
After restarting the Computer, the Camera should be listed in the Computer window (windows logo+E key) as a removable drive.
If the issue persists even after performing all the above steps then the issue may be related to the Operating System. In that case, you may try reinstalling the Windows.
Aug 22, 2009 | Sony Cyber-shot DSC-H50 Digital Camera
When connected to mains adapter the 2 left side LEDs on the front of the computer {standby+mains connected]start to flash and doesnt charg
This happens when the battery will not hold a charge. You will need a replacement battery if you want that light to go away.
If the battery has not been like that too long
put in a plastic bag and freeze overnight
let thaw until room temp
insert battery
plug in jack
do not power on laptop
let charge for1 hour
then try
Apr 15, 2009 | HP Pavilion dv8000z Notebook
Can't get it to work
I had the wireless working with dynex card before the virus hit the computer. The virus is fixed, but the internet does not work.
Feb 28, 2009 | Dynex Enhanced Wireless-G USB 2.0 Network...
Setting up a laptop to our home computer
As you already have a broadband at your house, its going to be very easy for you to connect the notebook in the same network.
I would assume that right now your computer would be connected directly to a DSL/Cable modem.
What you should do at this stage is that you can buy a Wireless Router.
The computer that you are using at the moment might be a desktop and may not be wireless capable.
So your Wireless router would be placed right next to your desktop and the desktop would be connected using a wire to the same router.
Your router which is wireless capale will let your notebook also connect to the internet. I am stressing on the wireless as you mentioned that the notebook will be on a different floor.
Note :- I have given this suggestion assuming that the notebook you have bought is wireless capable.
If it is not than you will have to pull a wire up to the other room and you can buy a normal router as well.
Hope that you find this as a good suggestion.
Thanks
Sammy
Nov 29, 2007 | Packard Bell Easy One Silver 2101 Notebook
Itunes cannot find my apple tv
how can i have apple tv in my bedroom tv without my computer in the room
Sep 27, 2007 | Televison & Video
WiFi not recognized on Compaq laptop
this can happen sometimes, just go to network connections in control panel, right click on the wireless icon and click dissable (or press the rellevant button on your notebook) Restart pc and then right click on the icon again and select enable. There should be an icon in your taskbar, right click and select view network connections, and then see if your router is listed and click connect.
Sep 25, 2007 | NetGear WGU624 Router
Linksys Wireless-G Broadband Router Logo
27 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
