Question about Baby Lock Ellure
Winding the Bobbin
The bobbin will not turn when trying to wind the bobbin. The screen displays "Bobbin Winding" but the bobbin does not turn. The machine has not been used for a few months and then when winding the bobbin it would turn slow at first then speed up. How can I fix this problem?
  • 2 more comments
  • Anonymous Mar 16, 2014
    it wont turn
  • Anonymous Mar 26, 2014
    bobbin wont wind.
  • Anonymous Mar 29, 2014
    The machine was started, but the bobbin did not starter to wind. Everything was done in accordance with the instructions. What it could be wrong there?
  • Anonymous Mar 30, 2014
    All lights come on and flash when trying to wind bobbin
    New Friend:
  • 3 Answers
I have the same problem and was skeptical of the drop of oil solution but it worked. I had taken my baby lock ellure apart while investigating previously and found nothing else wrong. Tried a few drops of oil and after a moment it started winding noisily and then settled right in!! Working perfectly now!
Posted on May 30, 2014
If you have a top winding bobbin on the right hand side it may be that the winder is seizing up, you must put a drop of oil now and again down the spindle otherwise it goes dry very quickly at high speed.
Posted on Jan 21, 2008
HOW DO YOU WIND A BOBBIN ON A PFAFF 2022 SEWING MACHINE
Bobbin winding
1. Place the thread spool on the spool pin in
against the spool.
back to front. Pull the thread clockwise around
the inside to the outside.
4. Place an empty bobbin on the bobbin spindle.
5. Push the bobbin lever to the right to wind.
A pop-up appears on the screen to inform
you that bobbin winding is on. Press the
foot control or the start/stop button to start
winding the bobbin.
When the bobbin is full, the bobbin winding
will slow down and stop automatically. The
pop-up closes. Remove the bobbin and cut the thread
Sep 14, 2016 | PfaFF Sewing Machines
Bobbin winder is engaged and shows up on screen correctly, but sewing mode is still engaged and bobbin winding keeps stopping.
check the drive knob on the end of the machine
it should be loose when winding a bobbin
if it is tight or seized then that will drive the needle
Sep 20, 2015 | Janome Sewing Machines
Why does display read "WINDING BOBBIN" and won't clear?
This video may help:
Winding an Elna bobbin
Perhaps the bobbin winding mechanism has not been released. (She unsnaps the bobbin when finished winding.)
Aug 31, 2015 | Elna Quilter's Dream 6003Q
Tangled thread after winding new bobbin
Try winding it the opposite way you are doing it now in regards speed. If you are winding it on full speed, try winding the bobbin slower. If you are winding it slow, try faster. Also check that the thread is threading properly and is not catching somewhere, and also that the tension is correct. Finally, test with a thread that you have not experienced problems before.
Jun 30, 2015 | Sewing Machines
I only want to know if the wheel must be loosened to wind the bobbin and if so with direction, to the front or backwards and press and turn or pull and turn.thanks
Which make and model sewing machine do you have?
None of my sewing machines need the wheel to be loosened for bobbin winding. The Singer Touch & Sew bobbins are filled in place. Use the handwheel to get the needle into the highest position (just turn the wheel). Wrap the top thread around the screw that holds the presser foot; open the slide plate part way and press the bobbin wind button. Hold the top thread and then begin winding by stepping on the foot pedal.. The thread should break after a few winds.
The Kenmore and the Husqvarna Vikings both get wound at the top. Place bobbin on winding pin. With the needle up and metal presser foot in place thread the top thread up to the bobbin (through the guides) and up through the hole in the bobbin. Slide the bobbin winding switch over towards the bobbin. Hold the thread tightly and begin winding (step on the foot control). After a few winds are on the bobbin, cut the thread that you were holding flush with the top of the bobbin. Continue winding the bobbin. (The newest Viking in the group has a computer screen; on that one, do not press OK until done winding the bobbin.)
However, if the handwheel is not turning and the needle is down, first find out why it isn't turning properly. This could indicate a tangle of thread somewhere in the system. (The older Husqvarna sewing machine in my home has a non-functional handwheel. The machine will still sew but you have to use the needle up/down switch that forces the needle to stop in the up position before you run out of bobbin.)
Please add a comment with the specifics of your sewing machine and I'll be glad to add additional information.
I hope this helps.
Feb 28, 2012 | Sewing Machines
Bobbin winder will not wind
The bobbin winder will not activate to turn the bobbin or the thread will not wind onto the bobbin spool?
Sewing machines vary in the method used for bobbin winding.
You can find threading and bobbin winding guides at sewusa.com.
If the winder is broken, you can get it repaired or check into getting a Sidewinder Bobbin Winder as an auxiliary for winding the bobbins, which would be less expensive than the repair.
Mar 13, 2010 | Kenmore Sewing Machines
Display will only show "Bobbin Winding"
Presumably you have turned the machine off, and then back on again to, in effect, reboot the machine's computer?
The only other suggestion I can think of, is to ensure that the bobbin winding post is FULLY to the left when you want to sew.
It may be worth looking around the bottom of the winding post to see if there is any build-up of thread (or other stuff) that is preventing the post going to the fully-left position.
Apr 09, 2009 | Janome Memory Craft 9000 Computerized...
Bobbin Winding message appears when machine is turned on
Is the bobbin winder holder clicked over to the right like you are trying to wind a bobbin? If so, and you are not trying to wind a new bobbin, click it over to the left.
Mar 09, 2009 | Kenmore 19233 Computerized Sewing Machine
Sewing Machines Logo
1,038 people viewed this question
Top Baby Lock Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Jon Piercy
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
