Question about Kenmore Dryers
Kenmore dryer 80 series model# 110.60852990. Dryer will not turn on. it has power to it because the light is on inside and the timer motor runs when power button is pushed and held. I know the start button switch is good because i bypassed the switch and timer motor still runs but dryer dont start. what else could be wrong???
  • Kenmore Master
  • 2,699 Answers
Unplug dryer remove the vent line and take off the back panel,on the left side you'll see the duct that your lint filter slides into,to the right of it around 4 inches up from floor you'll see a white thermal fuse part 3392519,check it with meter,now go back to the filter duct,take out the four screws and clean it out,bad air movement will pop the thermal fuse,then vac out the front of dryer,take out the two screws where you pull out the lint filter,get a screw driver and pop up the top lid of dryer,one side at a time,disconnect the door switch connector,take out the two 5/16 screws one on each side and pull up on front panel and vac out the inside of dryer,when you get it running,go outside and make sure the flapper is blowing fully open,if it isn't your vent line is blocked,if it's a long run i use a leaf blower and blow all the **** out of the line and then check the flapper again some of the lint can get stuck on it and it won't close correctly,clean the dryer once a year and you shouldn't have any problems,a little maintenance goes a long way
Posted on Dec 13, 2009
  • Sal De Dec 13, 2009
    i'm sorry i don't think i told you to first remove the 2 fillips screws on top,take out lint filter and then remove the duct from rear of dryer
4 Suggested Answers
  • 91 Answers
SOURCE: Kenmore 80 series dryer
repl/motor
Posted on Jan 03, 2009
gamefixer
  • 6 Answers
SOURCE: Kenmore 80 series electric dryer will not start even though the door switch switch appears functional and power is getting to the timer.
Easy fix. I had the same problem on mine. You need access to the back. Remove back cover. Look at bottom left, you will see two blue wires going to a white plastic item next to one of the thermal sensors. This white plastic piece is a fuse, or fusible link if you like. I'm not sure what the rating is, but you can take the old one to a parts store. They can match it. Now, why did it blow? Well, if the dryer is old, it could be just worn out. But more than likely, one of your 230 volt lines has degraded due to a bad connection, thus drawing more amps, thus blowing the fuse. Look at where the power cord comes in at. Is there any discoloration or oxidation at the terminals? If so, replace the power cord at this time, and try to clean up the terminals as best you can. Also, at this time, you probably better take a look at the lint collector duct running along the left side down the back. It's probably so clogged with lint that your dryer does't dry as fast anymore, and air flow from the exhaust is restricted. Take the duct off and clean it out, or blow it out with compressed air. You should be up and running now. Have fun...
Posted on Jun 16, 2009
  • 351 Answers
SOURCE: Kenmore 80 series dryer makes a constant squeaking
could be rollers, idler, belt or motor, we have to tear it apart and manually move things to find out... simply visit my site and call if you need help whirlpoolpartssurplus.com mark
Posted on Jun 25, 2009
110.64872400 kenmore dryer 80 series. dryer makes humming noise when start button is pushed, can turn drum manually. please help
The humming noise is most likely coming from the timer motor and not from the drive motor. This characterizes a problem with a blown thermal fuse which is wired in series with the drive motor and located on the blower housing. Power to the motor is cut when the thermal fuse blows open and consequently the drive motor cannot run. No dryer function works when the drive motor cannot run.
Unplug the dryer or disconnect power then pry the lower access panel off with a flat-head screwdriver as shown.
Remove the screw from the lint duct bracket and remove the bracket. Remove the two hex-head screws from the lint duct and remove the duct to access the thermal fuse and the cycling thermostat.
Click on the links below for the detailed troubleshooting of this problem and the parts diagram. The cycling thermostat(part number
3387134) must also be replaced once the thermal fuse(part number 3392519) is found open.
Whirlpool and Kenmore Electric Dryers Not Starting
Kenmore Electric Dryer Model Number 110.64872400 Parts Diagram
Aug 14, 2011 | Kenmore 73952 Gas Dryer
My sears kenmore 80 series dryer does not turn on. i can hear the timer.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Oct 19, 2010 | Kenmore Dryers
Manchine is getting power light works on the inside but nothing happening, can't hear anything when pushing the power button it's a kenmore 80 series model 110.67832791 any suggestion on what could be...
heatman101
Oct 16, 2010 | Kenmore 63942 Dryer
My Sears Kenmore 80 dryer will not turn on.
your dryer motor is worn out,replace it,the model number is inside the dryer door-mike
Feb 21, 2010 | Kenmore Dryers
Kenmore series 90 dryer(5 years old). Power ok
have you checked the start button?
Jan 30, 2010 | Dryers
Kenmore 70 Series Dryer not heating and not cutting off
I had an identical problem to yours this weekend with my Kenmore dryer. There were 2 problems.
1. Timer was broken. Does not advance to "OFF" position on timed dry, however it still works for auto-dry.
2. Thermal fuse was blown. Upon replacing, dryer heated up normally.
I believe when the timer broke, the dryer had kept running and blew the thermal fuse. On Sears' website, thermal fuse is $5.30, timer is roughly $80.
Kenmore 70 Series gas dryer, M# 110.76752500
Jan 01, 2010 | Dryers
Kenmore 80 Series No Heat
The heater gets one leg of power through the timer and one leg through the motor terminal.Make sure power is leaving the timer and terminating at the heater. Check the switch on the motor for continuity for the other leg of power.(The motor must be running to check this switch).
Aug 24, 2009 | Kenmore 63942 Dryer
Push the start button and nothing happens - no noise nothing.
check both thermal fueses, door switch, power relay, timer contacts if good, replace motor, do you have 220 volts at plug
Jun 26, 2009 | Kenmore 62602 Electric Dryer
Dryers Logo
492 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
