Question about Saeco Aroma Espresso Machine
Trobleshooting saeco coffee machine
My saeco light for heating water is on after i tried to make a coffee with low water in tank,now the light is on and is not heating the water what can be the problem fuse? where is located
  • 55 Answers
With the water tank fill open the steam wand with hot water setting to re-prime the system or ventilate it
Posted on Dec 17, 2009
Saeco coffee machine with a red blinking exclamation point light won't make coffee, how do I fix it?
When the red exclamation point is flashing slow, something is not where it is supposed to be, bean hopper lid, door, brew mech, water tank empty, dregs box or water tray on dregs container is full. If the red exclamation point is flashing quickly, open the steam valve for pump priming. If pump turns on, and water passes correctly, the light should go off and return to heating stage. If not, we have a blockage or a pump that is not working correctly.
Nov 16, 2015 | Saeco Odea Giro Plus Coffee Maker
Saeco vienna plus red solid light cannot prime water line
Make certain the line from the water resource is cleaned and not obstructed. If the pump fails to move the water from the reservoir to the heating tank, then the pump needs to be replaced.
Mar 25, 2014 | Saeco Vienna Espresso Machine
Water in tank but water light on
First, I'm not a Saeco technician. Though I've worked on similar Saeco models.
*** The following is for information only. You should always call your vendor for service, as opening this machine will void warranty.***
- Water not getting to machine or not sensing that the water tank is already filled.
* There usually some type of float near to middle of the water tank. It's usually white or colored plastic. This 'float' needs to move freely up-down to 'sense' the filled tank. clean the tank and shake it -note the movement of this float. It will need further cleaning if it's stuck (or you will have to replace tank if it's crudded up).
* Re-install tank and fill with filtered water. Turn machine off, count to 15 then turn on again. This usually turns on pump to add water to inner tank. If this does not happen then there is a CPU problem. If it does hums for 5-10 seconds then goes off but no heating then the pump may have an air bubble in line. Try the turn off and on method several times (up to 5) to get the water flowing. If it's still not working then there is a clog in the pump and will need service and/or replacement.
* Did you change water source? Since this is a table top machine in which you fill the water tank. Try to use filtered (bottled ok) water. Do Not use Distilled or 100% pure water as this type of water will eat out the metals from your machine! Some places use a water softener as it tends to be better for the machine long term (years).
* Still got problems? Check with vendor or MFR for service or replacement. Most machines of this type do not have serviceable parts or adjustments.
Aloha, ukeboy57
Feb 03, 2018 | Saeco Incanto Classic Espresso Machine
Water light not going out, even when full. Not able to make coffee
the water tank has a float inside, the float has a magnet. the machine senses the position of the magnet and indicates water ok/not. sometimes the magnet rusts inside the plastic casing, renders it less magnetic so it wont work. or the float is missing- fell out while you were cleaning the tank. you will need a new magnetic float to fix the problem.
Feb 11, 2014 | Saeco Incanto Classic Espresso Machine
Saeco vienna leaking water from bottom of machine
The o-rings of the water tube coming out of the boiler need to be changed. Rubber O-ring tend to expand after extended exposure to heat.
Jan 03, 2011 | Saeco Vienna SuperAutomatica Coffee...
Water light stays on....no water dispensed, even
My Machine will grind-tamp but will not add water to push through.It will send water out tap on the side.
Apr 14, 2010 | Starbucks Saeco Italia Digital Barista...
Water is full, but red water light is on and coffee wont come out
Try lifting the water tank and make sure it is pressed along the back of the machine when you put it back in.
Sep 28, 2009 | Saeco Incanto Classic Espresso Machine
Low water light stays on
If water light and heating lights go on and off, Try this: Fill water, turn water nozzle on, let water flow out. Water light should go off. Shut off water.
If coffee lights are solid, turn off the machine, let it cool off and try the above again.
Jul 07, 2009 | Gaggia Syncrony Compact Coffee...
Saeco vienna "machine ready" light (second light) blinking--not allowing to dispense coffee.
Try to open the steam knob and make a cup of water(Tea).
Best regards
/Mirran
Oct 21, 2008 | Saeco Vienna SuperAutomatica Coffee...
No steam
There is descaling and then there is descaling.
We have written a good article on how to descale saeco coffee machines which you may find useful.
Try a really heavy descale - use the recommended dosage of descale powder or solution in 3/4 the recommended quantity of water.
Run some coffee through the coffee side of your machine, then the water/steam side of your machine and then allow to sit for a good five monutes before repeating.
Do this until the solution no longer comes out with a greenish tinge and then flush both sides with fresh water.
Make you use on filtered water or an in tank filter in your machine.
If this doesnt work it's off to your saeco service center.
Paul from Coffee Shrine for Saeco Coffee Machines
Aug 20, 2008 | Saeco Classico Espresso Machine
Coffee Makers & Espresso Machines Logo
514 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
eyecam
Marvin
Marvin
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
