Question about Sony Playstation 3 (PS3) Console
PS3 Blu Ray Drive won't eject
My drive will play games and discs just fine but it won't eject.  Any way to fix this.  It's no longer in warranty.
  • 53 Answers
Try a blu ray reset all you do is power the system off by button on front not the switch on back the hold the eject button for 15 to 30 seconds if this does not work then ether you gears are out of line of they are too worn
Posted on Apr 27, 2010
Open that **** up,have similar problem,mine was caused because of a sticker on a dvd, couldnt find my warranty,and force eject wouldnt work,i was afraid to open the bluray drive completely,just to the point where i could manually eject the disc and found a round sticky mark on the disc,the sticker is probably still in there,but keeping the ps3 horizontally seems to help,your problem however could involve with the thingies in the driver not being propperly alligned
Posted on Dec 13, 2009
  • 182 Answers
You could try holding down the eject button for 10 seconds, it resets the drive. hope this helps
Posted on Jan 20, 2008
2 Suggested Answers
SOURCE: PS3 WON'T PLAY BLU-RAY DISCS
The problem is all in the settings. You probably have a 1080i television that cannot display in 1080p. To fix this go to the main menu and go to:
Settings:
Video Settings
Then Blu Ray Disc and make it turn the Display BD in 1080p 24hz or whatever. Once you do that, start the Blu Ray Disc again, and you should be able to watch it. This all happened because your tv doesn't display 1080p.
Hope this helps!
Posted on Apr 24, 2009
Blu ray player won't play or eject disc
If you want to eject the CD you need to look on the front of the Blu-Ray drive for a small hole, about the size of a pencil-lead. If you open a paper clip and insert it, it should pop the drive open for you.
Mar 06, 2013 | Televison & Video
Tip
PS3 Won't accept discs - Here is the fix!
This tip is for people who have already disassembled their Play Station 3 console and tried to replace the laser in the Blu ray optical drive.
If you replace the laser and then reassemble the Blu ray optical drive and the drive will no longer accept discs (like there is something blocking the disc) follow these steps to resolve.
(NOTE: if your PS3 is not accepting discs because the disc just won't push in, not like there is something solid blocking the drive, or your drive is making "grinding noises" refer to this tip: http://www.fixya.com/support/r4321102-bluray_drive_ps3_makes_grinding_noise )
Remove the metal casing of the Blu ray optical if you have not already done so. This requires removing the three black screws and the two silver screws on the bottom of the Blu ray optical drive.
With the metal casing removed, locate the 5 black screws on the top of the Blu ray optical drive to remove. There are two on either side and one at the back in the middle.
Keep the drive together for now (do not take the top off) and reattach to your Play Sation 3 console.
Turn on your PS3 and wait for it to power up.
Now, take the top of the Blu ray optical drive by “unfolding it” so the top of the drive rests on the PS3 power supply.
With the top off, hit the Eject button on the front of your PS3.
The drive gears should “pop” back into place.
Turn off your PS3 and reassemble the Blu ray drive. You should test your Blu ray drive first before reassembling the whole PS3.
on May 13, 2010 | Video Game Consoles & Games
Tip
Bluray drive on PS3 does not accept discs after disassembling
on Feb 16, 2010 | Video Game Consoles & Games
My ps3 wont play blu ray disc
The most common reason for the Wii not reading discs is a bad drive. The following website sells the drives and does installs:
store.richspsxparts.com/wiiredvddr
This drive should fix any reading issues you are having with your games, or issues inserting your games or ejecting them (or lack thereof). This is the entire DVD drive assembly mechanism replacement for your game including a new laser. If your discs are not ejecting, or you cannot insert a disc -- or you can insert a disc but it will not load, this is what you need to get your game going again!!!!!!!
Take care.
Oct 11, 2010 | Sony Playstation 3 (PS3) Console
Disk drive is making a loud noise, and is no longer reading the disc. just makes a loud clicking noise when injecting or ejecting the disc.
PS3 blu-ray drives are pretty problematic. The best solution is to send your ps3 back (without opening it and trying to fix it yourself (voids the warranty)) to sony. Your drive sounds broken, happened to me once before, sent it back, and now its like brand new (took a bit for them to get it back to me though)
Oct 03, 2010 | Sony Playstation 3 (PS3) Console
Tip
PS3 stop reading disks? heres how to fix it.
So your shiney black pearl stopped reading discs huh? Now you are wondering if you can fix it because A)You are out of warranty and don't wanna pay almost 200 bucks to have it fixed or B) You are under warranty but don't wanna be without your PS3 for almost a month or longer .... Maybe you casn fix it on your own, if the problem is simple enough.
Sometimes the PS3 won't read discs simply because the lens is dirty, to find out if thats the case insert a game or blu-ray disc ... take careful note of the disc's 'label' as you put it in ... once it doesn't read after 10-15 seconds eject it ... if the disc's label hasn't moved your blu-ray drive's 'motor' is broken. Best bet is to send back to Sony and pay em. Or take the PS3 apart and try to replace the whole blu-ray drive.
If you remove the disc and notice it has moved your lens is probably dirty. This you 'can' fix yourself. First give the PS3 a GOOD cleaning. Vacuum it, blast it with a can of compressed air, vacuum again. Try disc.
Didn't work? Try a lens cleaner kit.
Didn't work? Time to get your hands dirty ... open the PS3 up (at your own risk) and clean the laser manually with pure alcohol and a q-tip. (video tutorials are on youtube.com)
Disc read errors are our main problem. It isn't some full blown epidemic but IS becoming worse by the day. My reasoning for this problem is simple: The PS3 is a dust MAGNET. I'm betting 90% of the disc read errors are cause by dust and dirt and pet hair getting in the machine and making the lens dirty or causing actual failure of the drive motor itself.
I love the PS3 and wish it didn't fail for anyone, especially this month with great titles almost here, but it happens. Happened to me on April 1st and I found out my blu-ray drive motor failed. A dirty lens I woulda fixed on my own. We really need a good blu-ray cleaner kit to come on the market in all major retail stores.
Peace PS3 fans.
on Jan 30, 2010 | Video Game Consoles & Games
Ps3 wont play movies
Sounds Like your blu-ray drive is going bad. if you still have warranty play movies until it breaks and get a new one
Oct 18, 2009 | Sony Playstation 3 (PS3) Console
My ps3 wont play blu ray movies or games but cds and dvds work fine
The Blu Ray Diode fried when you shut the power switch on in the back. The PS3 uses 2 different lasers to read disks. One for standard dvd's and cd's and one for Blu Ray. The only way to fix your PS3 is to replace the Blue Ray Diode or laser lens. I would recommend paying the $150 bucks to have sony replace unless you know something about Diodes and lasers.
If you hold down the eject button for 10 seconds it will reset your laser and then you should be able to shut the power down in back safetly.
Formatting and or resetting the hard drive won't do a thing if your diode is fried.
I found a work-around to get it to read discs though. You have to have a bluray disc in the drive (game or movie) and start a downloaded game or Playstation Home. Once the game or Home loads, hit the PS button on the controller. The crossbar menu will pull up and you will notice the disc icon will (magically) pop up. Click the quit game icon. Once you are out of the downloaded game or Home the disc icon will still be there. You can then load the game or disc. The icon will remain there until you eject the disc, so you will have to repeat this every time you want to load a game.
Check What Resolution You Have Saved On the PS3 Maybe When It goes Blu-Ray Its To High Res For The Standard TV..
if you felt i have spent my time to help you... a very helpful rating is appreciated for answering ur query...
regards iversh
Aug 18, 2009 | Sony Video Game Consoles & Games
Settings:
Video Settings
Hope this helps!
Jan 19, 2009 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
1,495 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
