I have an old floor furnace which needs two control stocks to turn on gas valve and gas flow. But I could not find this 30 inches long and quater inch square stick in any store. Could you tell me where I may find these sticks ?
  • 614 Answers
You will find what you need at a machine shop. They have square keyway rods in stock. They will cut to any length. Rus
Posted on Dec 13, 2009
Shastalaker7
Check the gas valve some can be really finicky, if the setting for pilot is not right bang on in the proper position the button will not go down, and no gas will flow to the pilot. If the button does go down, do you hear/smell the gas flow? If not the valve is toast.Make sure the gas valve to the unit is turned on AND that the service to the house is actually on! I have had many calls for the same issue only to find the gas company locked out the meter!
Aug 17, 2014 | Cozy Furnace, Floor - 90N50A
Need gas valve for Empire 7088-2 (Nat Gas) heater
Get on computer and type in surplus gas heater valves,or used,or gas valves for --name and # of valve,i can't find the name but there's a Canadian co.that almost has everything gas..years ago they bought up a lot of American companies stock when going out of business of changing product types,there's got to be other companies that have done the same,,ask the wikipedia of out of business gas companies,who bought them out or there parts,someone has them,or a universal valve.
Nov 22, 2012 | Empire Heating & Cooling
Rv heater keeps running
Try cycling your disconnects a few times. Turn off the propane at the tank. Turn on the vent fan. Then turn on the furnace. Yes' I said turn off the gas and turn on the furnace. As the furnace tries to ignite "you will hear the spark" SLOWLY open the gas valve. I say slowly because the tank valve has a safety feature that stops the flow of gas if it is going to fast. By opening the valve slowly the gas will pressurize the line and the valve will stay open.
Here is the reasoning behind this. If your refrigerator, water heater or anything else gas was turned on while the gas valve was off the pressure left the line. When you turned the gas back on there was a rush that let the over sensitive safety valve kick out.
Some models have an electric safety valve connected after the regulator and it is controlled by the gas leak detector. If that detector is set off by anything..hairspray, Frebreeze, bug spray, silicone spray etc... it will turn off the gas at that electric solenoid. Clear the offending spray and reset the detector.
Apr 13, 2012 | Heating & Cooling
Fault code says pressure switch lockout
This more often than not, indicates that your pressure switch is gone and needs to be replaced. Watch the YouTube video for a fuller explanation and heed the warning to use OEM parts! Gas Furnace Pressure Switch Failure and Replacement Amazon com gas furnace parts
Feb 06, 2010 | Heating & Cooling
Garage furnace (standing Pilot) pilot stops after 30 mins.
it sounds like the afc the fan control not working could be dust on the afc
Jan 10, 2010 | Dayton Gas Furnace Heater
My Goodman furnace wont light.
Open up the unit to get to the control board. Make a short jumper wire and disconnect the wires going to R and W terminals on the board. Connect the jumper to R and W. Depress the door safety switch. The circuit board should indicate a call for heat and the furnace should start. If it doesn't, look for a fuse that may have blown either on the circuit board or in the wiring. If the unit started by jumping the W and R but does not when you reconnect the thermostat, you either have a bad thermostat or a bad thermostat wire.
Dec 02, 2009 | Goodman GMS90703BXA Heater
Gas Furnace Will not light
Hi, normally when you turn the gas off at the flex line valve and leave it off for awhile, the gas has to clear the gas valve and lines up to the pilot. Purge its self of air before it will light again. It will take the electronic ignition several clicks and more before there is enough gas to light the pilot and then open the main gas valve to fire the burners. Tell me, what kind of gas furnace is this when you speak of water? you say the site glass was full and you had to drain it and then the ignitor kept on clicking when it normally only took one click to light it. Please let me know the style as in a split system, a package unit, all in one, or what you have. I will wait to hear back from you. If the pilot does not light right away, then yes let it continue to click and see if it will light. On a heater with the electronic ignition control module on it or a circuit board, this is what tells the pilot coil to energize to light the pilot. It will send power to the pilot coil to open and let gas through to light and same for the main gas valve, will get a signal to open when the pilot is on. It will not open unless the pilot is lite for saftey. I will wait for you're responce.
Shastalaker7
Nov 27, 2009 | Honeywell CT87B ROUND HEATING&COOLING...
My coleman floor furnace will not stay on
Have the thermocouple replaced, ensure the pilot flame is blue - not yellow, yellow indicates blockage in pilot
Oct 08, 2009 | Heating & Cooling
Floor furnace
That is the control for the main gas valve. These old ones have a gas valve separate from the pilot. Also the regulator is separate unit. You have to turn these controls with a long rod, right?
Dec 27, 2007 | Heating & Cooling
Heating & Cooling Logo
55 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
