Question about Brother SE-270D Computerized Sewing Machine
The top thread will not grab the bobbin thread to complete a stitch.
I have cleaned my machine several times. I changed the needle, I have taken the whole shuttle apart, tried to thread manually, and played around with the tension. It still does not work. I have noticed when the thread is self threading the needle it is not catching on the thread bar above the presser foot. I manually slipped it in there. The machine will go about 2 inches and then says to check the upper thread. When you take the material out the beginning stitch has sewn but nothing else. I have had my machine for about 14 months. Absolutely love it but this is very frustrating. I noticed others having different problems after having their machine a while. Is this a common problem?
  • 397 Answers
Its common, but easy to fix,,,ok......first things first, 1. bobbin in bobbin case correctly 2. machine threaded correctly 3. tension set around 3-4 upper 4. when was the last time machine was serviced
Posted on Jan 21, 2008
Bobbin thread shows
have you tried to tighten the bobbin tension spring??
Dec 23, 2012 | Brother PE770 Computerized Sewing Machine
Bobbin thread is not being caught by top thread.
try changing the needle
rethread the machine top & bobbin
it's also a possibilty that the machine could be out of time &
that the machine needs to be checked at a sewing machine repair
shop
Aug 22, 2012 | White Sewing Sewing Machines
Singer melodie 20 is not stitching
have you tried to adjust the top tension?
is it the right needle for the machine?
it's very possible that the machine is out of time
Mar 29, 2012 | Singer Sewing Machines
Stitch tension problem - bobbin thread lies flat or bunches. If you increase the needle thread tension there is no improvement - even at the highest needle thread tension the bobbin thread is a mess. Any...
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 16, 2011 | Consew 7360R-1 Mechanical Sewing Machine
My singer curvy 8780 has a timing issue the needle is scraping on the bobbin casement and will not sew,cleaned and oiled, changed needle turned off and on. any suggestions?
Good day!
Good day!
Jun 06, 2011 | Singer Curvy 8770 Electronic Sewing...
Sewing machine will not stitch. The thread goes into the material but does not make a stitch. I've changed the needle, cleaned the bobbin, rethread the bobbin and the top thread.??????????????
Is this the first time you have used the machine? If so you need to bring up the bobbin thread by hand before stitching. Only when both bobbin and top threads are up through the needle plate nad pulled towards the back of machine, will the machine form a stitch.
Dec 17, 2010 | Singer Confidence 7467 Mechanical Sewing...
Sewing machine not stitching
Sounds like you need to retime the machine, if you email me I can attach instructions drivewithken@blueyonder.co.uk
Jun 26, 2010 | Kenmore 15212 Mechanical Sewing Machine
Stitches not even
the needle bar on my sewing machine is loose not sure how to adjust will not go through the fabric to grab the bobbin thread
please help
Aug 31, 2008 | PfaFF Sewing Machines
Skipping stiches
1) It’s possible the machine is threaded incorrectly. Remove the thread completely and rethread the machine. Be sure to use good quality thread--don't buy the cheapest you can find. A good thread will help your machine perform better and your projects last longer.
2) Poor stitch quality can be caused by the needle. Make sure you're using a new needle that's right for the job. Many times machines are taken in for repairs and all they need is a new needle. If you can't remember the last time you changed the needle--it's past time. Needles should be changed at least every eight hours of sewing.
3) When inserting a new needle, make sure the flat side of the needle faces away from the bobbin area. For example, if your machine has a frontloading bobbin, the flat side of the needle faces the back of the machine. If your machine has a side-loading bobbin, the flat side faces the right side of the machine. Some older sergers require special needles that don't have a flat side. Refer to your owner's manual to properly install a serger needle.
4) Thread that shreds or breaks can be blamed on the needle. Use a good thread and make sure the needle eye is large enough for the thread type. Also use the right type of needle for the fabric;
5) The machine tension adjustments put stress on the thread so it doesn't simply flow through the machine. When the upper and lower tensions are balanced, the stitch forms correctly. Tension is easy to adjust--stitch on fabric samples with a different thread colour for the upper and lower threads. Observe the stitch, adjusting the tension until the stitch is formed correctly. As a general rule, adjust the upper tension first. If the stitch still isn't right, adjust the bobbin tension.
Feb 26, 2008 | Singer 2662
Bobbin
Hi Sally,
Don't forget to change your needle too. It may not look bent, but it probably is.
Nov 06, 2006 | Rex RX-1804
Brother SE-270D Computerized Sewing Machine Logo
372 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
