Question about Lakewood (5500) Oil Filled Radiator Heater
Lakewook oil filled radiator heater
We have a lakewood oil filled radiator heater and it just quit working for no reason. Is there a reset switch on it? If not what could the problem possibly be? This is the second one I have bought that just quit working for no reason.Please help
Thanks,
Billie in PA
  • atgrissom21 Feb 07, 2008
    It shows there is power but I get no heat. What could this mean? and can it be fixed?
Here is your problem and yes it can be fixed.
More than likely your thermal cutoff tripped because your heater got too hot.
Solution:
1. Unplug unit.
2. remove front support feet and screw underneath face plate will slide off.
3. You will see the heating element, a white wire is coming out of it. There is a white sleeve on the wire tucked up into the element. Pull the wire out and slide sleeve off to expose the thermal switch labeled (S.W.C. sw-120t ect.) You can google it to learn more about the cutoff. If you know how you can test the cutoff with a ammeter or voltmeter, If you don't google how to test electrical systems. Remember "first do no harm"
4.
a. If you can replace the cutoff do so (this is the recommended way)
b. If you don't want to replace it cut the cutoff out and solder the wires back together. (be warned that this will bypass the safety system) If you do this be careful to not leave your radiator unattended.
5. After soldering the wire, taping it will electrical tape. Replace face plate from step 1 and 2 and your heater will work.
P.s. If your heater is still under warranty just contact lakewood.
Posted on Feb 20, 2008
  • mhowell
    mhowell Jan 04, 2014
    My husband and I ran across this same situation with 2 of our heaters. We followed the steps that Engrstdnt had posted except we didn't have access to a soldering tool. So, here is what we did. We didn't remove the sleeve we striped a section to the bare wire on each side of the sleeve then twisted them together. We also applied black electrical tape to this. Understand this could be a FIRE HAZARD so please if you do this use caution and DO NOT leave your heater unattended for any reason. Hope this helps someone else!
  • 3 Answers
Could this part be related to a microwave thermal fuse like these?
http://www.electronix.com/catalog/product_info.php/cPath/435_238_256/products_id/5400
Posted on Feb 25, 2008
KSD301
Try Grainger - snap disc controls.
Also, see my post, in response to "The heater does not work when switched on I have", under this same topic, 'Problem with: Lakewood Oil-Filled Electric Radiator Heater'.
Nov 07, 2012 | Lakewood Oil-Filled Electric Radiator...
Lakewood oil filled radiator heater repacement switch
Here is a tip about space heaters that will also help you...
DeLonghi Space Heater does not Heat
heatman101
Jan 26, 2011 | Lakewood Oil-Filled Electric Radiator...
The rolling feet are missing. Any idea how to find replacements
I have a Lakewood 7096 heater. We purchased it used and got 8 to 10 years of service out of it. It was never heavily used while in our possession, just to heat the bathroom for showers.
The 900W switch quit working after used it and showered Sunday. The 600W switch still works fine, but the unit doesn't produce much heat at any speed.
After looking at various posts on fixya today, I decided to pull the pair of switches out. The 900W switch is burnt. The wire attaching to the 900W switch is burnt and bare!!! I don't know what happened. I would be scared to use it again, even if I replaced the switches and the bare wire. I don't know if it's even safe to use the 600W setting.
Anyway, I purchased a sunbeam radiator heater this morning. The ol Lakewood has the wheels you are missing. If were to come to an agreement on price, I would be happy to ship them to you. They are in good shape, just a little squeeky, which a little oil would fix.
Jan 17, 2011 | Lakewood Oil-Filled Electric Radiator...
Lakewood quit working
Make sure unit is sitting flat. some have ttip over switches on the bottom. check to see if switch is being depressed as it would be when sitting upright.
Jun 09, 2009 | Lakewood Oil-Filled Electric Radiator...
Switch
Try this link   http://www.nelsonappliance.com/Space+Heater+Parts.html
Mar 24, 2008 | Lakewood Oil-Filled Electric Radiator...
Lakewood (5500) Oil Filled Radiator Heater Logo
1,070 people viewed this question
Top Lakewood Heating & Cooling Experts
jay kaye
jay kaye
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
Are you a Lakewood Heating and Cooling Expert? Answer questions, earn points and help others
