Question about Harman Kardon AVR 510 Receiver
Our Harmon Kardon AVR 510 has had a low hum since we first set it up 4 years ago. We suffered with it until recently, when the overall sound seemed to be degrading. My wife (the family techie) replaced all the wiring, tested all the speakers, and confirmed that it was correctly wired. The speakers now work again, but the hum is still there. Is there anything we can do about it?
  • 1 more comment
  • rdowner Dec 13, 2009
    If there's an HK power supply problem (with HK replacements likely to be the same) is there an after-market replacement that's not HK? Where could we get one? Is there a filter or regulator that can be put between the HK and speakers to regulate the voltage? Where get?
    It had a hum the first time we turned it on, although it's grown in intensity over the years.
    Sorry, I didn't understand your question when I answered before. We got it new.
  • Harman Kardon Master
  • 11,800 Answers
The hum (60 Hz) is probably induced in the speakers wires by the power wires in your house - try shielding them with tin foil.
Posted on Dec 13, 2009
    Brigadier General:
  • 5,158 Answers
Sounds like you have a bad capacitor in the power supply section of the amp. was that making a humming sound from brand new or was it used when you got it ?
  • 1,068 Answers
I have seen these have this problem alot. it is due to a power desing in the power supply and the replacement usally have the same issue. sometimes there fine and sometimes they just stink. hit or miss with this unit. to bad because it looks so nice. but other than looks it really lacks inside. hth
please ask any more question you have.
  • michael schultz
    michael schultz Dec 13, 2009
    no after market ones. but not all hk do this so a replacement is less likely to do this but there is a chance. this is what i was trying to get across. hth
Harman kardon avr 1500
Try using the RCA outputs once and see if that works..One other thing don't use the phono input on the receiver as it could damage the amplifier
Feb 16, 2018 | Audio Players & Recorders
Trying to connect samsung smart tv to harmon kardon avr 330 with toslink cable, but i'm not gettting any sound through the receiver to speakers
The inputs may be assignable on the Harman Kardon. Make sure you have selected the proper analog or digital input type for the cable you are using. For more information, or should you have further questions, please visit my website at audioserviceclinic.com. You may contact me directly through the website. Thank you.
Dec 14, 2013 | Harmon Kardon Harman Kardon Avr 330 5.1...
My Harmon Kardon AVR 500 sound doesn't work, I disconnected speakers, re connected & reset protection. Nos ound not even on test mode
Hi it is seem there is no output from your device. Please check the circuit components and wires for malfunction in your Kardon then. Regards
Feb 09, 2011 | Harman Kardon AVR 500 Receiver
Just bought a Sharp LED TV and there is a slight delay between hearing sound and seeing lips move. Have cable box hooked up to tv by HDMI and have cable box hooked to AVR (Harmon Kardon AVR125) by optical...
Hi if there is an optical out on the television i would use that direct to your Harmon Kardon AVR 125, the sound would be in sync with picture, as the source is the same.
Jan 31, 2011 | Harman Kardon AVR 125 Receiver
Problems with setting up Harmon Kardon AVR 146????
in what display i need to put reciver when i use the optical digetal
Oct 19, 2009 | Audio Players & Recorders
Harmon kardon 745 displays "unlock" no sound for tv or movies
I also had this UNLOCK message on my Harman Cardon AVR 130.
The reason for this error was - in a hurry I've plugged the optical input into optical OUT! Double check that your connections in the back are correct and hopefully it fixes your problem.
Cheers,
Sergey
Jan 11, 2009 | Harman Kardon AVR 130 Receiver
Humming noise
Usually Humming noises come from frequency interferance.  In this case it is being caused by your input sources.  A smiply solution is to replace the cables and or seperate the source cables away from any electircal cords or sources.
Jan 07, 2009 | Harman Kardon AVR 225 Receiver
Hooking up an amp
plug eash units sound in red whites from dvd tv main out the set speaker wires in place front ch a ok turn it on make sure ch a speakers on only select corect video input dvd ect turn it up
Feb 11, 2008 | Harman Kardon AVR 130 Receiver
Harman Kardon AVR 510 Receiver Logo
482 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
