Question about Minuteman PRO1500E/1500VA/1050W/USB/RS232 /AVR 6 BATTERY BACK-UP OUTLETS (0784755151827) UPS System
Have a 2000 Chevy s10 pick up (flex fuel)replaced fuel-pump and fuel filter, and i'm getting no power at all to the pump. I checked all the fuses and exchanged the horn relay with the fuel pump relay, they both seem to work. What should I do next? Is their something I have overlooked?
    President:
  • 1,755 Answers
Well, First turn the ignition to ON and listen for a faint hum.
If you don't hear anything. The pump is not running. (2) Have your mechanic check the wires to the fuel tank.(under the vehicle) and see that the pump is getting power. If no power, look around battery and wire connections. Hope that helps.
Posted on Mar 02, 2018
2 Suggested Answers
SOURCE: 99 chevy s10, fuel pump?
This happened on mine and at first i had 4v at the harness going into the tank then it eventually went to 0v im prettysure thats why the pump burnt up but anyway after much head scrtaching i tied into the ground wire coming out of the tank and grounded it to the frame and the truck is running fine there vehicles are known for bad wire looms
Posted on Mar 07, 2011
What would cause you to lose fuel pressure while driving.
Chevrolet S-10 Questions - Fuel System Loses Pressure ...
www.cargurus.com > Questions > Chevrolet > S-10
CarGurusJul 28, 2012 - Fuel System Loses Pressure - I have a 2003 Chevy S-10 Pick Up with the 4 ... car a few times, what essentially you are doing is priming the fuel pressure. ... A dirty fuel filter will not cause the lines to lose pressure after the engine is shut off. ... I have a 98 s10 2.2 liter and it was driving fine all day then when ...
Chevrolet S-10 Questions - My 2001 S10 has a hard starting ...
CarGurusSep 16, 2012 - My 2001 S10 has a hard starting problem if the truck sits between 1 ... Vacuum leak, have you checked fuel pressure while it sits? ... Would the spider alsocause a misfire at low rpms? .... at an idle, or squeaking while driving and it gets faster as you go? ..... 1994 Chevrolet S-10 2 Dr STD Standard Cab LB.
Chevy S-10 Won't Start - Repalced Fuel Pump and Pressure ...
www.cartruckinfo.com/chevy-s10-wont-start.html
Chevrolet S-10 pickup won't run and has no fire unless I jumper the fuel pump relay. ... Once the truck starts and is running you can remove the jumper to the fuel pump ... Iwould get the fuel pressure checked to start with, because that's where the ... 93 gmc 4.3l FI runs but dies out loss of power after 5 mins of running then ...
Stalling S10: I Have a 1994 Chevy S10 2.2l It Stalls After 35 ...
Dec 10, 2015 | 1994 Chevrolet S-10
Where is the fuel pump fuse located on a chevy s10 1996 pick up
Fuel pump relay gets power from the ECM Batt fuse number 9.
Dec 06, 2012 | Cars & Trucks
1993 chevrolet pick up fuel pump relay location
Hey, quick question my friend have a 93 chevy S10 fuel problem i notice tha volts is low on the purple wire no power on the gray one black wire r ground on tha fuel pump check the fuse its good run it diret with the battery runs strong not sure where tha at relay tho?
May 02, 2012 | Chevrolet 1500 Cars & Trucks
My 2000 chevy s10 pickup won't start it acts like it wants to but wont
scanned wont pick up failed fuel pump--or clogged fuel filter check and test wiring --relays--connections and fuses
Jul 16, 2017 | Cars & Trucks
My 2000 chevy S10 wont start I changed the battery and it ran fine for 2 days now it will turn over but won't start
Check Fuel Pressure. First turn key to on position (without starting) and listen for the fuel pump motor. If no motor sound, your fuel pump is not working. Check fuel pump fuse and relay. If fuel pump works, check for pressure at the fuel rail (schrader valve on fuel rail for pressure testing). If no pressure, or not enough, fuel filter might be clogged or fuel pressure regulator may not be working properly. IF fuel is not the problem, start checking electrical, such as ignition control and proper spark to plugs.
Aug 14, 2010 | 2000 Chevrolet S-10
1997 chevy s10 blazerdash wont light up when key
the dash sound's like a fuse, check the fuse box under the hood and in the door jamb on the side of the dash, also check your fuel filter and fuel pump, im betting on the pump because i have a 2001 chevy blazer that has had two replaced and it has 233000km on it!
Jun 04, 2010 | 1997 Chevrolet Blazer
Having problems with chevy s10 replaced fuel pump
Check the cable that goes from your battery to the fuse box the relay that is clicking is on. Check for lose bolts or corrosion of the contacts or something like that. If the relay is clicking it sounds to me like it is a voltage issue going to the relay.
Oct 05, 2009 | 1998 Chevrolet S-10 Pickup
2003 chevy pick up 2.2l s10 turns over but won't start has spark but no gas getting up to the injecktis only 50,00 miles on it it just stop runing and how do I fix it
if you take a hammer and hit the gas tank flat side of hammer, while someone else is turning it over. it should start. if it does start the fuel pump is shot.
Jun 26, 2009 | 1998 Chevrolet S-10 Pickup
1991 chevy s10 blazer
Check the fuse under the dash. Did you replace the inline fuel filter? If not, you could loosen the line going into the filter then turn the key to the on position. The pump should run for about 2 seconds then the relay should kick off. Turn off the key for approx. 5 seconds then cycle key back on and the pump should cycle again. If you get a 2 second burst of fuel each time then the pump is cycling. Install a new fuel filter and check the grounded wire by the tank. Hope this helps. :)
Nov 03, 2008 | 1993 Chevrolet S-10 Blazer
Fuel pump
Did you check the fuse and relay? It can't work unless it gets power. Did you check the harness and make sure pump is getting voltage?
Sep 16, 2008 | 2000 Chevrolet Astro
Minuteman PRO1500E/1500VA/1050W/USB/RS232 /AVR 6 BATTERY BACK-UP OUTLETS (0784755151827) UPS System Logo
181 people viewed this question
Top Minuteman Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a Minuteman Computer and Internet Expert? Answer questions, earn points and help others
