Question about Whirlpool GHW9100L Front Load Washer
Odor problems with whirlpool front load washer
Why do towels/heavy items like coats, jackets washed in whirlpool front load washer smell bad ?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 107 Answers
Is the smell of mildew?
Run the washer on empty with beach and soap.
This is a common problem when the front door is left closed after use.
When the washer is not in use leave the front door cracked open. This will help in preventing mold & mildew.
Posted on Dec 13, 2009
How do I remove odor from duet front load washer?
Assuming the odor is not a burning rubber smell or some other type of odor caused by a mechanical malfunction:
Remove the bottom of the washer (three screws I believe and above the drawer if you have one) and then open up the drain pump catch and clean it. You may want to put down some towels or even a bowl to catch water that will spill out. There are videos on how to clean this on youtube "Whirlpool Duet Water Pump Drain Catch". I believe this will solve the problem.
Oct 16, 2014 | Whirlpool Duet GHW9150P Front Load Washer
My bath towels have an unpleasant smell after washing and drying. I have tried a few things but am sick of trying,
If you have a smelly front loading clothes washing machine, toss in a Finish Geltabs (the ones that are all liquid) and run the machine on a hot wash cycle, medium to heavy load (to get more water in the tub) with no clothes in the machine. You don't need to use much of a spin cycle so set it on low. The washing machine will come clean and even the moldy spots on the rubber gaskets will disappear. A second treatment may be needed if the smell is not completely gone. We tried everything from vineger to bleach to baking soda to borax to commercially available odor removers from Whirlpool and Tide. Nothing worked until I hit on this idea. It's cheap, easy and can be done anytime your machine needs a refreshing. I used the orange Geltabs but any fragrance would be fine. Keep the door on your washer open a bit when possible to air out to help preclude those nasty smells.
May 12, 2014 | Samsung Washing Machines
Whirlpool calypso washer smells how to get rid of ordor
Removes odor causing residue in front loading (HE) washers. Keeps your machine fresh and clean. Package includes 3 tablets. For front load washers only.
Here is what you need.
Oct 18, 2012 | Whirlpool Calypso GVW9959K Top Load Washer
Strong Odor, almost organic smelling, coming from my Fridgidaire Energy Star stacked Front Load Washing Machine, 5 cycle, Heavy Duty Model# FTF530FS1, Serial # XC90201067. It is in the townhouse that we...
This smell usually comes from items caught in the hose. If you can remove the bottom front panel, (usually 2 screws holding this down) then you will see a rubber acordian piece attached to the water pump. If you remove and clean this the smell should not remian. I just removed mine and found many coins and a huge ball of stinky lint, hence the smell. Good Luck!
Jul 21, 2011 | Frigidaire FTF530FS Front Load Washer
Our towels and clothes have a mildew/musty smell. when I spin the stainless drum inside, i can hear water sloshing around.
Towel mildew odor is transferred from the washer to towels and clothes. The washer must be cleaned first. After cleaning the washer and towels washing habits must change to stop mold smell from returning.
Washing machine mold / mildew is caused by:
#1 cause is overuse of detergents. Detergent companies are notorious for instructing to use too much detergent. Especially with soft water or when using liquid detergent no more than 1 tbsp of any detergent should be used.
#2 most common cause is using fabric softener because it's dispensed in the rinse cycle and will coat the inside of the outer tub with residue that is a food source for mold to grow.
#3 using only cold water for washing is fine but makes preventative maintenance very important. A weekly hot soak will dissolve odor-causing residue from inside your washer.
#4 not using the washer. If the clothes washer isn't used very often maintenance is especially important. If leaving for a vacation it's a good idea to clean your washer. Do a search to "remove washer odor" to read just how big the problem is. There are all natural washer cleaners that will also remove mildew odor from towels and clothing after the washer has been cleaned.
Oct 06, 2009 | Maytag Neptune MAH5500B Front Load Washer
Stale odor in machine and on towels and clothes. I have used the affresh, Bleach, baking soda, use powder HE detergent, no liquid fab softner, I am at the end of my rope with this stinking machine ready to...
Towel mildew smell is being transferred from the washer. The washer must be cleaned first. The problem is not "brand specific" all clothes washers have mold growth to a certain degree. Bleach or vinegar will kill the mold inside your washer but won't remove it or the residue it grows on thereby making the situation worse because it leaves a "base" for more detergent to collect on and more mold will grow.
Washing machine mold / mildew odor is caused by:
Sep 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
The washer has a very bad odor. I have tried using different soaps, but it still smells bad. The clothes smell "flat"----no odor----but the laundry room is getting to smell harsh. There is nowater outside...
thedrain has sludged up causing partial blockage. soap powders cause this . check the fall on your drainage. Either attempt self cleaning or get a drainage company to investigate.
Aug 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Clothes and towels don't smell fresh after washing
If you are sure that the pump is not blocked then try running the machine on a quick wash on its own with a little bleach in the drawer.
Jun 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Laundry
Interesting article explaining the problem associated with Front Loader Washing Machines and new products to combat the mold/fungus build up inside them.. Check it out....------------------------------------------------------------
Consumers who own front-loading washing machines should use only about one-quarter of the recommended amount of high-efficiency, or HE, low-sudsing detergent. Standard, non-HE detergents in front-loaders are too sudsy.
Why don't top-loading machines have this problem? Less efficient top-loaders that use more water typically flush out excess suds, soil, detergent and fabric softener.
Class-action lawsuits against manufacturers such as LG, Whirlpool and
Maytag have been filed, alleging mold and mildew problems in front-loading washers.
Some suits have been settled while others are pending, affecting hundreds of thousands of consumers, said Rob Shelquist, a partner at the Lockridge Grindal Nauen firm in Minneapolis.
According to Whirlpool, the low water use and airtight seals on HE front-loaders create the potential for odor-causing mold and mildew. Whirlpool has its own anti-odor product, Affresh, which sells for $7 for three treatments. SmellyWasher is more expensive than Affresh initially ($16 for 24 treatments), but Flynn's product lasts a year.
SmellyWasher can be used as a preventive monthly or less often if smaller amounts of detergent are used. Affresh is also used monthly, but a $7 packet of three tablets lasts only three months. Flynn's product will remove musty odors from towels or clothing, which Affresh does not claim to do.
Getting rid of problem
To eliminate odors, Smellywasher users should put a capful of Flynn's product in the detergent dispenser, select the hottest water temperature and the extra-large load to fill the empty washer with the largest amount of water. Let the water agitation start and then stop the washer and allow the solution to soak for two to four hours. Repeat as necessary and allow to soak overnight if needed.
Flynn said that the product works best in hot water. Consumers might want to run the faucet closest to the washing machine until the water is hot before starting the process or turn up their water heater temperature until the load is finished. (Remember to turn the temp back down to avoid scalding.) Flynn offers a money-back guarantee. Stubborn cases of mold and mildew might require five to seven treatments.
Susie Thymian is such a believer that she now sells SmellyWasher in her own store, McGinnis Appliance in Morris, Minn. Thymian had blamed the musty smell from her towels on her teenagers, who often leave wet towels in a pile in their bedrooms. Her kids' solution to the stink was to use more towels. Thymian's answer was to use more bleach in the laundry, but nothing got rid of the mystery mold odor until she found Flynn's product.
Only a few of Flynn's customers are from
Minnesota so far. Most come from regions with higher humidity. Sharon Turner, who lives in steamy San Antonio, said SmellyWasher worked after several cycles. "I was ready to throw out my plush towels and my front washer. It saved my sanity."
Link to this article..http://www.chicagotribune.com/business/chi-smelly-washer_chomes_0912sep12,0,7369054.story
Sep 14, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Order in clothes
Put a half a cup of vinegar into wash load, with soap. It removes the smells.
Jan 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool GHW9100L Front Load Washer Logo
281 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
