Question about Bissell 1697-7 Powersteamer Pro Deluxe Vacuum
Cant get any water to floor or hand dispenser on my bissell power pro steam cleaner
I have 2 = 1697 cleaners. I finally located the problem by switching tanks from one to the other. The small red seal on the bottom of one tank was bad[ tiny checks on ribbed part of seal] causing the unit to loose vacuum & prime. Simple problem but not something they tell you in troubleshooting. Could have saved lots of time spent checking pump, belts, hoses etc.
Posted on Jan 18, 2010
  • 701 Answers
That means that the pump belt is worn or stretched and needs to be replaced. Here is a link to the belt you need and the manual which has instructions:
Bissell ProHeat Belt and Manual
Posted on Dec 13, 2009
SOURCE:
Bissell pro heat steam carpet cleaner, not releasing water.
That means that you need to replace the pump belt. Here is the belt you need and a manual you can view:
Bissell 7901 Belt and Manual
Mar 01, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
Water and cleaner dispenses from handheld attachment only
He could be right but most of the time when it doesn't dispense water and cleaner it means that the pump belt is worn and needs to be replaced. I would try that first (only $4.99) before I spent $100. Here is the pump bet you need, it comes with instructions:
Bissell 1699 Proheat Belts
Dec 31, 2009 | Bissell 1699 ProHeat Clear View Upright...
Model 1699-1 ProHeat Clearview Plus -water and cleaner do not dispense when using trigger on handle. The turbobrush hand tool works fine.
When it doesn't dispense water an cleaner like that it means that the pump belt needs to be replaced. Here is a link to the belt you nee and the manual:
Dec 28, 2009 | Bissell 1699 ProHeat Clear View Upright...
Bissell ProHeat Rug and Floor cleaner. Won't
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
sf
Oct 20, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
I have a bissell steam cleaner. the hand piece
heatman101
a
Sep 26, 2009 | Bissell 1699 ProHeat Clear View Upright...
Bissell Pro Heat Turbo will not dispense cleaning solution
heatman101
fss
Dec 05, 2008 | Bissell ProHeat Turbo Deep Cleaner Upright...
Bissell 8930 Pro-Heat wont dispense water/cleaner onto floor, but attachment works fine.
The water solenoid that controls the flow of water to the floor nozzles is prone to and known for failure. Replace it. Less than $12.00 part.
Jul 21, 2008 | Bissell Vacuums
Bissell power shoot carpet cleaner
It sounds like the heater may be plugged. This is a problem for an experienced technician. The heater is located in the handle and they are prone to plugging at the tubing connections. The heater is heating soap and water solution and this can cause the soap to coagulate and plug the lines. It must be addressed carefully to avoid damaging the heater.
Mar 23, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell 1697-7 Powersteamer Pro Deluxe Vacuum Logo
368 people viewed this question
Top Bissell Vacuums Experts
CJ C
CJ C
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
