Question about Frigidaire PLCS389DC Dual Fuel (Electric and Gas) Kitchen Range
Frigidaire ples389ece range
My range stop working it flashes code F 20
  • Lance Healy May 22, 2008
    My oven is flashing code f90 and needs to be reprogrammed??? Not sure how to reprogram. Shut off circuit for several days....error has not changed. Anyone know how to reprogram a Kenmore Electric Range 790.9091? Please help.
  • bmachot Dec 17, 2008
    Mine says Error code, which I have no clue to fix.
My oven is flashing code F10
Posted on Nov 24, 2009
Stopped working, flashing code F7 and beeping
Hello Michelle, thank you for your inquiry!
Typically error code F7 indicates that your Frigidaire range is experiencing a failure with either the potentiometer or UIB (User Interface Board). Let's try resetting you range by unplugging it or flipping the household circuit breaker off. This usually clears most false error codes. It is best to wait approximately ten minutes and then turn on your appliance. If the error code persists, it would be advisable to contact an experienced appliance repair tech to assist further.
Best regards - Z
Mar 16, 2014 | Frigidaire Stove/Oven/Range Cooktop -...
That website has a manual for your Range and it should explain the F20 code.
I'm gonan look through the manual and check out what F20 means so ill be back in a bit.
Jan 20, 2008 | Frigidaire PLCS389DC Dual Fuel (Electric...
Frigidaire oven won't work. top range works fine, but digital clock and digital display stopped working which works oven, so oven also will not work f11 code
Hello steve o - Typically error code F11 indicates a shorted keypad. Try resetting the range by unplugging it or flipping the household circuit breaker off. This usually will clear most false error codes. Wait approximately ten minutes and if the error code does not clear contact a professional to move forward accurately. Most likely the EOC on the range will need replacing.
Nov 12, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Request Onwers Manual/Troubleshooting Guide: [FEF366CCE]. PROBLEM: Oven locked in code [F9] & [F1] w/ the the [Door Locked] LED flashing w/ beep. Stop top functional, oven inop.
Here is the Owners Manual for your model:
Here are all of the error codes and solutions for Frigidaire ranges: Range / Stove / Oven Fault Codes#ixzz1Dxy4q2ze
Feb 14, 2011 | Frigidaire FEF366 Electric Kitchen Range
I have a frigidaire PLES389ECE oven with runaway temp. when I set oven temp.,the oven will exceed set temp to 450' ++
Check oven sensor-- 10-11K ohms at room temp. Check wiring to sensor.
If ok - replace electronic control.
Affordable Appliance Repair
Orange County, CA
Aug 22, 2009 | Kitchen Ranges
Frigidaire Professional Series Range - F30 ERR
door will not unlock after cleaning
Jun 11, 2009 | Kitchen Ranges
F30 ERR message on Frigidaire Professional Series Range
I am a tech and just had this happen to me, so I can feel your frustration. I have replaced the temp probe, erc, and still had the problem.
Open the back, with the unit unplugged. On the lower right hand side there is a relay, beside the relay there is a "safety T-stat" disconnect from the circuit by removing one wire and read for continuity. If none is detected, replace t-stat and voila... stove works. Much cheaper than erc and probe...
Jun 11, 2009 | Frigidaire FEB27S6DC / FEB27S7DC Electric...
Stove beeping
You have a fault in the range electrical system
Range/Stove/Oven Fault Codes Version 3 Failure
Condition Check/Repair F0 & F1 EOC (Electronic Oven Control) failure Replace EOC (Electronic Oven Control)
Jun 04, 2008 | Frigidaire FEF376 Electric Kitchen Range
Frigidaire PLCS389DC Dual Fuel (Electric and Gas) Kitchen Range Logo
600 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
