Question about Kenmore 24.9 cu. ft. / 705 liter Chest Freezer 13551
Compressor on Kenmore freezer tries to start but overload kicks
The compressor on our 6 1/2 yr old 24.9 cu ft Kenmore freezer tries to start but the overload kicks out in about 4-5 seconds. It sounds like the compressor is locked up. Is the compressor bad or could it be the run capacitor that is bad.
  • 10,515 Answers
Do you Hear anything when you ON the Freezer like Clicking Noise or Humming Noise. If NO, follow the Below steps :-
Check to see if the thermostat has continuity when turned to the coldest setting, if that is okay then you will want to disconnect the wires going to the compressor and see if you get 120 volts there after is plugged in, if you get that I would replace the overload / relay on the compressor and see if that gets it to work, if that does not work your compressor is shot and not worth fixing.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Dec 12, 2009
Kenmore upright freezer quit freezing would work intermitantly and then quit cooling altogether, Approx 10 years old trouble shooting advise or most likely cause would be appreciated
Sorry to read about your problem. you can have many different problems.
Here are some areas to troubleshoot
1. Bad temp control
2. Failing compressor
3. Defective start cap
4. Defective overload protector
5. Defective control board
I suggest you call a service company. for compressor issues
I have tried to help you. Please help me, by Vote/Rate my response. Thanks.
If you live in the Denver area, I can help you.
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 04, 2011 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Replaced run cap, motor windings ohm out good, condenser fans work. when i power up unit the compressor overload trips after 5-6 seconds
Probably locked rotor. This happens sumetims when the connecting rod breaks or seizes up on the crank shaft. Seperate your power cord ar some point so that you can put an amp meter around just one of the hot wires. It should be 10.2 amps maximum. I think you will see it spike to 25 amps for 2 to 3 seconds when the compressor tries to start. That almost immediately kicks out the overload. This compressor is not rebuildable. so it will require a new one if it is what I think.
Sep 28, 2010 | True 49 cu. ft. / 1388 liter Commercial...
Light inside on thermostat not working
If the compressor is not working and the unit has a electronic control board try and replace it.the other thing to check is the over load relay and the start ptc on the compressor. make sure there is power to the compressor.If it is still under warranty set it up for service and it will not cost you any money. you can put a 5 to 10 pound block of dry ice in the cabinet to keep things cold for about 24 hours until you get it running
Jul 09, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Compressor kicking on and off now not anything
Make sure you have 120volts at relay if not jump out thermostat if it starts to run and stays running Replace the thermostat. If you have 120volts at relay and it is not running or it's kicking off and on replace Start Relay/Overload but a bad compressor can make a Start Relay go bad so if you have the same Prob. after replacing Start Relay/Overload Compressor is bad
May 20, 2010 | Kenmore 13.7 cu. ft. / 388 liter Upright...
My kelvinator upright freezer stopped freezing and it just kicks on and kicks right back of what could be wrong with it?
Start Relay/Overload or Compressor is bad. A bad compressor can make a Start Relay/Overload go bad but the only way to find out if compressor or Start Relay/Overload is bad is to replace the Start Relay/Overload if it starts and stays running you fixed it if Prob. returns in a week or so or if you have the same Prob. after replacing the relay the compressor is bad.
May 20, 2010 | GE 13.7 cu. ft. General Electric Upright...
Start up current draw
Lock motor Amps ( LMA ) is the current draw when the compressor starts.This draw of current is less then 1sec.The amp amount shoud be on the compressor Name Plate.This amp draw is also the amps used when the compressor goes bad and locks up then the overload kicks out.
May 21, 2010 | Kenmore 5 cu. ft. / 142 liter Chest...
Red light blinking with audible alarm. Compressor
That is the compressor starting relay trying to start the cooling cycle and the overload protector kicking off. You can try installing a new start device for about $50.00 but you are most likely looking at a compressor replacement which runs about $400.00
Sorry for the bad news
Apr 17, 2010 | Kenmore 22.7 cu. ft. / 643 liter Chest...
Freezer get start but shut off after couple of seconds
This sounds like the compressor tripping on overload.It will make a "click" sound.This is the sound of the clixon (overload protection) on the compressor.Only way to solve this problem is to replace the compressor.
Regards
Andre Nagel
Mar 22, 2010 | Danby 3.6 cu. ft. / 102 liter Chest...
I have a freezer chest the compressor comes on but it never cools
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Nov 10, 2009 | Kenmore 8.8 cu. ft. / 249 liter Chest...
HI I HAVE AN OLD 13 CU. FT KENMORE UPRIGHT FREEZER. AFTER I DEFROSTED IT YESTERDAY AND AFTER IT HAD BEEN PLUGGED IN FOR ABOUT 6 HRS I NOTICED THAT THE SIDES OF THE FREEZER FELT VERY HOT . IS THIS NORMAL ?...
It had to run longer than normal to cool down the freezer again. The heat from the compressor running is what you feel.
I would not worry about it unless it is still hot after 24 hours. Then there is another problem.
May 03, 2009 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Kenmore 24.9 cu. ft. / 705 liter Chest Freezer 13551 Logo
196 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Jay Finke
Jay Finke
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
