Question about Tappan TGF320 Gas Kitchen Range
Tapan gas range oven doesn't ignite
Oven glow coil get red but burner doesn't come on. How do I know if the glow coil isn't pulling enough amps to open the valve or if the valve is defective?
  • Anonymous Jan 22, 2008
    We have the same problem. Coil gets red but the oven won't light.
    Gently tapped on the gas valve.
    Burners work fine.
  • 770 Answers
Should have at least 3.5 amps min to open the safety valve
Posted on Jan 25, 2008
6ya staff
SOURCE:
Oven igniter will not spark
most oven igniters dont spark at all. they have "glow bars" that are connected to a gas safety valve. the bar will glow red hot and once it pulls enough amps it will tell the gas valve in the oven to open up and when the gas hits the hot glow bar it will ignite. the glow bar can still glow red and the valve wont open. it is still a bad glow bar because it's not drawing enough amps. if you replace this part yourself do not touch the actual "element" with you hands because it will cause it to break the first time you use it. you can only touch the base.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Mar 12, 2014 | Kitchen Ranges
Oven does not heat but broiler does
First thing to suspect would be a weak igniter....see if the amp draw while the igniter is glowing matches the amp rating of the gas valve, the value will be on the side of the valve, if the amp draw of the igniter is lower than the rating of the valve you would need to replace the glow coil/igniter.
Mar 22, 2008 | Bosch HGS 255 Gas Kitchen Range
Our GE profile oven model JGsp31wet1ww oven will not heat up. When i set the oven to say 400 degrees, it just stays at 100 and never heats up. The broiler seems to work fine and the stove top gas burners...
pull out the racks and remove the bottom floor of the oven,turn it on bake,if the ignitor doesn't glow most likely it's bad,if it does glow and it doesn't ignite within 40 to 60 seconds the ignitor is bad.even though it glows doesn't mean it's good,it works by amps.it takes 3.2 amps.for a flat ignitor to open the gas valve and 2.5 amps for a round ignitor to open the gas valve.
May 15, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
Maytag oven will not ignite
If its a square glow bar it must pull 3.5 apms to open the gas valve. Round ones pull 2.5 apms. even though the glow bar is on it must be real bright. Has it been taken over 45 second to light the oven. You will need some way to check the amps. If its getting enough amps the safety valve is bad.
Apr 27, 2010 | Maytag MGR5750 Gas Kitchen Range
Igniter in oven will try to ignite. Hear gas flow. Can see spark on upper burner assembly but it does not ignite. Use custom broil and it will ignite the upper burner but will not stay lit after ignition...
the ignitor may be faulty and not pulling enough power to keep the as valve open in order to light them oven, even though it is getting red or glowing the power is not enough.try and replace the ignitor
Jan 24, 2010 | Whirlpool GS460 Gas Kitchen Range
My stove will not ignite...but the burners do
There is no pilot. The oven has an electric ignitor to light the flame. This ignitor is very common repair.
You can remove the floor panel inside the oven and start the oven. Watch to see if the ignitor glows. Even if the ignitor glows, it should ignite the flame with in 30 seconds. They get weak and don't pull enough amps to open the gas valve.
I hope this helps you. please let me know if I can assist you further.
Vic
Jul 03, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Thermostat seems ok, but gas won't flow from oven burner.
Hi, Even tho the ignitor is glowing, it is getting weak and will need replaced. The ignitor is not pulling enough amps to open the gas valve.
This is very common problem with the gas ovens.
If I can assist you further, please let me know.
Vic
May 29, 2009 | Garland H283 Gas Kitchen Range
How do I utilize the self cleaning part? Do I just press ''clean
  1. After self cleaning the range the door won't open
  2. Amana gas range conversion from NG to propane
  3. A tip on cleaning the surface grates
  4. Checking an common oven temp sensor
  5. Checking an common oven temp sensor: What does an oven temp sensor look like?
  6. Gas range repair aid - such as, my oven won't work or heat up, which style of gas oven do I have, the glow coil gets red but my oven burner will not light.
  7. GE gas range conversion from NG to propane
  8. How to change the oven temp on some common electronic controlled ovens
  9. How to re-light a surface or oven pilot light
  10. How to change a common oven glow igniter coil
  11. How a common gas valve works - click here.
  12. How Ranges, Ovens, and Stoves Work
  13. Help for storing an appliance
  14. Important Disclaimer
  15. Installing a gas flex line connector
  16. Maytag, (some) Magic Chef, (some) Jenn-Air gas range surface spark module - new module kit
  17. Maytag ( Magic Chef - Crosley - Jenn Air ) gas range conversion NG to propane
  18. My gas range flames die when I turn on more than one thing at a time
  19. My Range is flashing an " F1 F2 F3 F4 F5 F7 F9 " something, what does this mean?
  20. My surface burners keep "clicking" even after the burner is light
  21. Oven door and door hinge help
  22. Oven temp sensor - how to change helps
  23. Repair tips and information on surface burner spark modules and igniters
  24. Some "how to set the self clean" on my range
  25. Stainless Steel Cleaning
  26. Surface burners wont work
  27. This morning I noticed the range top ignition was clicking all by itself every 15-30 seconds
  28. Test for F1 fault code
  29. WCI - Frigidaire ( some Kenmore's ) gas range conversion from NG to propane
  30. WCI - Frigidaire /open burners/ (some Kenmore's) gas
  31. Whirlpool Direct Spark Ignition (DSI)
  32. Yes, your glow bar igniter can glow red and still be bad!!
Apr 01, 2009 | Maytag MGR5765QDQ CleanDesign Gas Kitchen...
GE Profile Gas Range oven light doesn't work even after changing
Apr 01, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Tappan TGF320 Gas Kitchen Range Logo
103 people viewed this question
Top Tappan Kitchen Ranges Experts
Paul Carew
Archie Ferrarini
Archie Ferrarini
MARLON KELLER
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
